Pulsating brakes 95 camry
Discussion in 'General Automotive' started by BlackRig, Jul 29, 2010.
  1. Jul 29, 2010 at 9:27 PM
    BlackRig
    BlackRig [OP] Well-Known Member
    Craig
    Riverside, IL
    09 TRD O/R AT
    I'm having trouble with a 95 camry. The brakes have been replaced. Both rotors/pad in the front and the shoes/springs in the back. They still pulsate. You can feel it in the steering wheel also. Mostly at higher speeds, like an off ramp, but it's still there.
    It was recently in a shop for the work but now I've made it my business to correct it. The list had gotten long and the AC went and that's over my head. Anyway, moving on.
    First I'll probably pull the front wheels and make sure everything the mech said he did is new. If it is then I'm stuck.
    What should I look for moving past the obvious Rotor warp?
    Could a frozen caliper cause this? Like one piston is stuck?
    Anyone have a link to a good camry or Toyota forum? I popped into TN but can't find much more.
    Thanks in advance.
  2. Jul 29, 2010 at 10:28 PM
    FearNothing321
    FearNothing321 You gonna eat that taco?
    Tony
    Wesley Chapel, FL
    08 PreRunner SR5 TRD Sport
    Stuff and Things
  3. Jul 29, 2010 at 10:49 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    if they are new rotors you may want to make sure they are seated correctly. also check the lug nut torque. x2 on the break-in of new rotors/pads
  4. Jul 30, 2010 at 5:52 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    If the wheel shakes without touching the brakes, it's the tires. They're out of balance, out of round, or wheel is bent.
  5. Jul 30, 2010 at 8:05 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    How are your wheel bearings? Sometimes bad bearings are more noticable when the brakes are applied.
    If it pulsates all the time even without the brakes applied, then start looking at your tires/wheels (out of balance or bent rim).
    Are you able to determine if it pulsates on one side or the other?
  6. Jul 30, 2010 at 12:35 PM
    BlackRig
    Craig
    Riverside, IL
    09 TRD O/R AT
    Thanks for all the replies so far. I'll start tearing into it next week there's alot to look at.
    Yes that link is great. Thanks.
    While it was in the shop both wheels bearings were replaced. Along with: radiator, AC compressor, both front axels and CV boots, rotors, pads, shoes, and springs. Needless to say the list was long and well worth the shop investment. The mech at the shop gave us the "just so you know the brakes are still jacked" talk b4 we left. He suggested an alignment claiming there's nothing else to do with the brakes. I disagree. I think.
    Do you need an alignment after axel replacement? Would that cause the steering shake?
    My GF will be out of town next week so I'm hoping to have all this cleared up by the time she gets back.
