Pulsating hum at low speeds
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Travlr, Apr 28, 2021.
  1. Apr 28, 2021 at 8:12 PM
    Travlr
    Travlr [OP] Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    I bought a wrecked 2012 Taco that got hit from the side hard enough to break the left rear wheel.
    I got what looked like a good axle from a wrecking yard and installed it, replacing the one on the side that got hit, and after a few miles there is a pulsating hum (maybe the start of a grind?) at low speeds.
    So three questions... Anybody know from the description if this sounds like a bad wheel bearing?
    And... is there a possibility that it is an internal bearing or damage to the carrier?
    Any other ideas?
  2. Apr 29, 2021 at 1:42 PM
    Eastkat808
    Eastkat808 Well-Known Member
    Esket
    2012 DCLB 4x4 sr5
    bilstein 5100 cranked up
    Does the sound go away when making turns
    does it sound like it coming from one corner of the truck or can you hear it in the middle and in your seat
  3. Apr 29, 2021 at 1:50 PM
    Travlr
    Middle'a Utah
    No vibrations at all. Just a low humming noise at about thirty mph more or less. Vooom...vooom...vooom... kind of steady and slow. Hard to describe.
  4. Apr 29, 2021 at 1:54 PM
    Eastkat808
    Esket
    2012 DCLB 4x4 sr5
    When my wheel bearings were going bad on the left side, it started out as more of a hum. And making a right turn on the freeway it would go away, try listening for that.
    As for a failing bearing in the third member my only experiences were a hum/ low vibrating at around 60mph felt in the seat/center of truck
    just take a listen while taking corners, and you could also Jack up the truck and spin all 4 tires to listen for a bad wheel bearing individually also for any play side to side movement when you grab the tire
    Check for play in the center support bearing and ujoints
    Travlr[QUOTED][OP] likes this.
  5. Apr 29, 2021 at 1:55 PM
    Parma
    Parma Well-Known Member
    Adam
    Utah
    2019 TRD Off Road
    Just turn your radio up more...problem solved!
  6. Mar 30, 2024 at 4:15 PM
    Nbattis
    Nbattis Member
    2008 Tacoma
    Purchased from original owner who special ordered. Factory Trd off road suspension, skids, and rear diff lock.
    I know this is a few years old, but did you ever find the source?
    BOLT_THROWER likes this.
  7. Mar 31, 2024 at 3:38 PM
    BOLT_THROWER
    BOLT_THROWER Member
    Menifee
    2014 Tacoma
    Also curious on this issue. I think I have same going on.
