Pulsing front end vibration
Discussion in '1st Gen. Tacomas (1995-2004)' started by fouillard13, Aug 21, 2014.
  1. Aug 21, 2014 at 7:20 PM
    fouillard13
    fouillard13 [OP] Well-Known Member
    Riley
    Canadia
    1998 tacoma 4x4
    I have a what seems to me is a front right tire pulsing vibration when driving straight and speeds between 30mph and 40 mph
    Truck has 3 inch coil over lift, 33 10.5 15 toyo MTs. Brand new
    I swapped front diff out due to old one being totalled and now it's doing this
    Any ideas?
    I have greased everything
  2. Aug 21, 2014 at 7:23 PM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
  3. Aug 21, 2014 at 7:51 PM
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
    So is it a cv shaft issue or a wheel bearing? It never did this before. But I did use the cv shafts that came with the used front diff
  4. Aug 21, 2014 at 7:58 PM
    ImplicitlyAlberta
    David
    edmonton
    Not likely a cv. Might need to pick up the ECGS bushing or dig into your bearings.
  5. Aug 22, 2014 at 3:57 AM
    JAGER91374
    JAGER91374 Well-Known Member
    Des Plaines
    3 TRD O/R
    OME 883's and Dakars, OME Shocks, Gray Wire, Deck Plate, Blacked Out Chrome, RAT Skids, BAMF BPV Bracket, Toytec Diff Drop, Braided Extended Brake Lines Front and Rear, In-Dash Nav.
    When you say pulsing do you mean the truck sounds like it's rolling over rumble strips?. Does the noise go away if you put the truck in 4WD?
  6. Aug 22, 2014 at 8:53 AM
    jspansel
    jspansel Just duct tape it
    Jay
    Central OR
    01 V6 Xtra Cab Tacoma, 5 Speed, 4x4, Lifted
    5100s front at 2.5" with Moog replacement springs, 5100s in rear with 2" Wheeler's AAL
    See if it goes away in 4wd. If it does, its most likely your driver side needle bearing in the diff.
  7. Aug 22, 2014 at 9:55 AM
    BVCOTaco
    BVCOTaco Well-Known Member
    BV, CO
    02 Xtra Cab SR5 TRD
    ARB Bullbar
    I wonder if this is causing the vibration in my truck as well??? I will try it in 4WD and see what happens.
  8. Aug 22, 2014 at 10:57 PM
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
    I put mine In 4wd and it went away, seems like I need a bearing, what's the way to fix it.
  9. Aug 22, 2014 at 11:01 PM
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
    Will these bearings also cause a grinding noise,when turning? Sounds like a dust shield grind but it's not
