Pulsing "Humming" Noise Post Bilstein 5100 OME install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hender107, May 17, 2021.
  1. May 17, 2021 at 9:09 AM
    Hender107
    Hender107 [OP] Member
    Northern VA
    2014 DCLB SR5
    Just finished up doing the front struts with the 5100 OME 886 Coils and upon getting it back on the ground and doing a test ride I noticed a bit of a pulsing noise, almost sounding like tire rub but the tires are complete clear of everything, only have 265/70/17s. There is no vibration and it is correlated to the speed of something rotating, from 20-50 mph the pulsing speeds up and then becomes very hard to notice sub 15 mph unless I really listen for it. I'm assuming it is the needle bearing issue as when I put it in 4-High it goes away as many have described. but before I rip back into anything I wanted to see if anyone had any other thoughts on things to check first that could be causing the noise.
    Cheers!
  2. May 17, 2021 at 9:10 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Did you get a front end alignment after the lift?
  3. May 17, 2021 at 9:13 AM
    Hender107
    Northern VA
    2014 DCLB SR5
    I have not yet but I do plan to this week. I suppose that would likely be a good place to start before ordering new bushings and specialty tools.
  4. May 17, 2021 at 9:38 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    needle bearing for sure.
  5. May 17, 2021 at 10:03 AM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    if you haven't gotten it aligned, it's most likely and alignment issue and tire wear on the road.
  6. May 17, 2021 at 10:07 AM
    fourfourone
    If it was an alignment issue it most likely wouldn't go away by putting the truck in 4wd.
    SR-71A, gsubioguy and tacoman45 like this.
  7. May 17, 2021 at 10:10 AM
    Hender107
    Northern VA
    2014 DCLB SR5
    That was my thought, I know it should be aligned regardless, since I've got it from bone stock I've done wheels/tires and the level so I know it needs it. But the noise subsiding with 4wd vs 2wd is what didn't make sense to me.
  8. May 17, 2021 at 10:13 AM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    ahhh, my bad. I stopped reading half way through the post.
  9. May 17, 2021 at 10:13 AM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    Needle bearing for sure. The 4wd test confirms that
    wi_taco, bulalo and gsubioguy like this.
  10. May 17, 2021 at 10:14 AM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    are you getting the vibe at all speeds from zero to highway?
  11. May 17, 2021 at 10:17 AM
    Hender107
    Northern VA
    2014 DCLB SR5
    Yea, its very slow 5-15, maybe a second in between pulses then quicker and quicker up to 55 60 then it almost goes away. But I assume that's just bc the pulse has become so fast it is just constant at that point.
  12. May 17, 2021 at 10:31 AM
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
  13. May 17, 2021 at 10:49 AM
    Hender107
    Northern VA
    2014 DCLB SR5
    With that known, is the ECGS bushing the best fix for that or does anyone have any better solution?
  14. May 17, 2021 at 10:51 AM
    whiteknight4x4
    whiteknight4x4 Well-Known Member
    Drew
    Missouri
    2008 SR5 Reg Cab Taco
    2.5 inch lift: Full Dobinson's suspension kit, Freedom Off-road UCAs, 265/75r16 tires on factory Baja alloy wheels. x2 Baja Designs Squadron Sport Led Pod lights. CBI Moab 2.0 Aluminum Bumper w/full hoops, Warn Evo 8k winch. Ultraguage. Midland CB radio with 3ft Firestick Firefly. Tacomabeast/Spyder Headlights. Rear diff breather. Cruise mod. A.R.E. Topper. Prinsu topper roof rack. Hail damage mod.
    really sounds like needle bearing. for me it sounded like a rumble strip that was intermittent. another way to tell is if it goes away or lessens after the truck is warm. ecgs bushing is the best fix
    gsubioguy likes this.
  15. May 17, 2021 at 2:36 PM
    NBourque
    NBourque Well-Known Member
    Nick
    Maine
    ‘21 PRO
    ECGS bushing 100%
  16. May 17, 2021 at 3:28 PM
    gsubioguy
    gsubioguy Well-Known Member
    Evan
    Maine
    '21 TRD OR
    I get it: I did "x" to my truck and now "something ain't right" can be very unnerving but a quick Google search would have resulted in multiple threads on here alone regarding this very issue.
    As multiple others have said: ECGS bushing. Ask on here or your state's thread and bet someone has a puller they'll loan you or even find folks that will be happy to help w/ install in exchange for beer.
    tacoman45 likes this.
  17. May 18, 2021 at 5:45 AM
    Hender107
    Northern VA
    2014 DCLB SR5
    Appreciate the advice, I just posted on my local page to see if anyone has the tool by chance. I did the quick google search and a search on this forum which led me to the needle bearing issue and egcs bushing as a solution, this post was more to just confirm what I suspected and to be sure there wasn't anything else that could be the cause as I have ripped into projects before on suspicion alone only to replace everything but the problem piece until last, trying to learn from past lessons finally.
    gsubioguy[QUOTED] likes this.
  18. May 18, 2021 at 5:59 AM
    Hender107
    Northern VA
    2014 DCLB SR5
    side note, not sure if it was admin or other that removed that post about tracking posts of "modifying a well engineered vehicle", but props to this forum on weeding out comments that provide no value...
  19. May 18, 2021 at 10:13 AM
    gsubioguy
    Evan
    Maine
    '21 TRD OR
    Feel your pain there! My most recent involved losing >$500 in tropical fish to a faulty heater that I finally replaced after replacing a nearly new pump w/ a new $500 one and doing hours of water chemistry research. Hell, I even had a pathology work up done on one dead fish to find out there was NOTHING wrong with it pathologically.
  20. May 18, 2021 at 10:23 AM
    krtek
    krtek Well-Known Member
    Steven
    Snoqualmie, WA
    2021 Tacoma TRD Sport - 6MT
    GFC V2 Platform Teraflex Falcon Shocks + OME Springs/UCAs Ricochet and RCI skid plates Tuned by @tonered And more...
    Im not near ya, but doing my ecgs this week and could send ya the tool after I’m done.
