Pulsing lights
Discussion in '4 Cylinder' started by jambet, Sep 3, 2010.
  1. Sep 3, 2010 at 5:15 PM
    jambet
    jambet [OP] New Member
    I need some help here. My mech doesn't have much of an idea of what's going on. I have an 03 2.4 with 160K. When I start up in the am, my lights' odo, and ashtray light pulse. It is not necessary for me to turn on the lights as the dome light will exhibit the same problem. Battery, starter, and alt check out ok. Anybody else experience this? Thanks.
  2. Sep 3, 2010 at 5:26 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    sounds like you have a bad ground somewhere.
  3. Sep 3, 2010 at 5:38 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    x2....maybe try pulling the less important fuses to try to isolate the culprit. Do they pulse when the engine is runing and/or off? Try turning the headlights and blinkers on and off, maybe you'll be able to trace where the problem may be coming from. This could be a tough one to track down.
  4. Sep 5, 2010 at 5:33 PM
    gooberpeas
    gooberpeas Active Member
    Georgia
    2010 PreRunner SR5
    as a general rule, pulsing lights indicate a defective voltage regulator, which is usually built into the alternators these days....
    might want to recheck that alternator......just a thought.
  5. Sep 6, 2010 at 5:29 AM
    larryde09
    Larry
    Rochester, NY
    x2...good call, I was thinking of some sort of grounding issue. What if you disconnect the alternator? You should be able to start and run the truck on the battery alone for awhile. In theory, if the alternator is disconnected, the pulsing should stop.
  6. Sep 6, 2010 at 5:38 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    correct. i had this issue after replacing my mud gunked alternator and getting one from advanced that had a bad voltage regulator. luckily i have a head unit that will show the voltage and i could see it pulsing. if the battery is disconnected, everything should be fine.
    when the auto places check the battery/alt, they always have you turn your truck on mid-test. for me, it wouldnt start acting up until a few minutes after turning on. i made them wait until i could hear it cycling from under the hood and it finally registered as a faulty regulator.
  7. Sep 8, 2010 at 8:57 AM
    jambet
    Thanks fellas. Been so busy at work that My first chance to check out the Alt. was this am. Doing the easiest thing first, I disconnected the alt and, bingo, the pulsing was eliminated. Reconnected the alt and the pulsing returned. Now to find a good alt. Thanks again.
