Pulsing noise coming form the rear of truck
Discussion in '1st Gen. Tacomas (1995-2004)' started by Andrew m, Jun 15, 2023.
  1. Jun 15, 2023 at 3:23 PM
    Andrew m
    Andrew m [OP] Guaco Taco
    Grant
    Tennessee
    95 taco 2.7L manual 4x4 AND MORE!
    6in fab tech lift kit, 6in skyjacker leaf springs rear, fab tech stealth shocks rear, posi front and rear, ring and pinion reduction, warn locking hubs, raptor liner olive green, rear X brace, aftermarket front and rear bumper with led marker lights, 3in bolt on bushwacker fender flairs, 1 1/4 wheel spacers, new energy body bushing and lower and upper control arms bushing, custom glass pack exhaust, pace setter header 4 in 1 full length, K&N air filter, center-force clutch, manual swapped cab, pioneer dmh-1770, jl-audio C1-650 door speakers and tweeters
    I’ve started to notice a pulsing noise coming the rear end of my truck when accelerating around 60+ lately and I’m having some trouble tracking down the problem. I originally thought it was my diff since I just had east coast gear supply rebuild it and after the 500 mile break in period and about 1000 miles after that I had vibration from 60+ that got worse with speed and a slow pulsing noise (about a second intervals). Even after sending the dif back, since it was under warranty, the pulsing noise was still their bud no vibration so I did the rear wheel bearings which were going but that wasn’t the problem. The only other things I can think of are a u joint is going bad or maybe the difs fluid level is to high. Since the truck is lifted 6in and the fill plug on the axle is much lower I parked the truck on a incline and filled it but I’ve tested the truck with normal fluid level and about normal fluid level and the noise is still there. Any thoughts on what could be the problem?
  2. Jun 15, 2023 at 3:27 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Belt in a tire, maybe
  3. Jun 15, 2023 at 3:30 PM
    Andrew m
    Grant
    Tennessee
    The noise also comes in around 40-45 sometimes but goes away it the speed range. I seem to remember testing the truck out on a different set of tires and my current ones have been balanced in the last 6 months but it could be
  4. Jun 15, 2023 at 3:45 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Maybe just switch tires front to back and test again? Tires seem to be the next culprit worth ruling out
    rocknbil likes this.
  5. Jun 15, 2023 at 4:11 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Have you inspected the center support bearing? Referred to as the 'carrier bearing' on TW.
