Pulsing sounds near Air Intake Filter? [SOLVED]
Discussion in '1st Gen. Tacomas (1995-2004)' started by RoscoeTT, Oct 6, 2021.
  1. Oct 6, 2021 at 8:54 PM
    RoscoeTT
    RoscoeTT [OP] Well-Known Member
    New York
    2002 Toyota Tacoma
    Truck: 4cyl 2.7L (3RZ)
    Been restoring this truck for the last few months. Doing lots of testing, tuning, etc. Trying to work out this rough idle I have. Recently noticed I have this pulsing sound coming from my air intake filter, which can be heard when putting your head close to the air filter box. It doesn’t change pattern when I throttle the engine. Tacoma’s are new to me so I thought it might be normal until I realized two throttle body hoses connected to the EGR were accidentally crossed causing a p0402. I corrected them, codes went away, truck drove like a dream and the pulsing sound went away immediately. However, next day it came back and I can’t figure out why its doing it or where its coming from. Anyone ever dealt with this pulsing sound before, is it normal?
    I’ve tested the whole EGR system (factory manual)
    Replaced the IAC & cleaned the MAF
    Cleaned the Throttle Body
    Tested the Temp Sensor and ECT (all correct resistance)
    Completed a Smoke Test, Compression Test, Leak Down Test & Coolant Pressure Test (passed)
    Confirmed Injectors are pulsing & have correct resistance
    Exhaust Manifold was inspected and confirmed to be sealed
    I’m lost as to what part might be causing a pulsing sound or echoing into the air intake filter box.
  2. Oct 6, 2021 at 9:39 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    While I have a different motor (v6 3.4L) I was listening closely after replacing my valve cover gaskets & replacing my fuel injectors, and also noticed a "puff puff" pulsing pattern to the air being drawn into the air box. In the stock configuration, there are J traps for catching water, and resonator boxes attached to the intake tube to reduce pulses / smooth out the air flow. Do you have the stock intake, or a aftermarket intake system?
    12TRDTacoma likes this.
  3. Oct 6, 2021 at 9:58 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Why don't you post a video of it so we can give it a listen? That probably might be the best move unless you have an aftermarket intake, that would somewhat explain the pulsing sounds if you do indeed have one.
  4. Oct 7, 2021 at 9:25 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    No codes now correct?
    My best guess is the EVAP system purging
  5. Oct 7, 2021 at 6:55 PM
    RoscoeTT
    New York
    2002 Toyota Tacoma
    I have a stock intake. I inspected the J traps and resonator boxes attached to my intake hose but nothing was out of ordinary. Is there something I should be looking for? I did notice the fuel injector system has a hose that connects the air intake, could it be causing this pulsing sound?
  6. Oct 7, 2021 at 6:58 PM
    RoscoeTT
    New York
    2002 Toyota Tacoma
    I can try, but I think the engine is too loud to record the pulsing sound.
  7. Oct 7, 2021 at 7:44 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    My comment wasn't as much of a suggestion to inspect the resonator, but more a the intake makes noise to the point where Toyota did something about it.
    I don't think the pulsing is an issue.
    The vac line that runs "to the fuel injector system" is going to the fuel pressure regulator.
    How many miles have you put on the truck after all the items you've listed? Have you reset the ECU since completing those fixes? It might just take some time for your ECU to adjust to the newly cleaned/replaced items.
  8. Oct 9, 2021 at 6:59 AM
    RoscoeTT
    New York
    2002 Toyota Tacoma
    The reason I point out the air hose to the fuel line is because I wonder if the fuel pressure regulator is showing signs of deterioration? As the pulsing sounding does resonate in some form the throttle body/fuel injector area. Obviously sound and vibration travels so its possible I’m just dealing with some resonance, but a rough idle can come from poor fuel/air ratio. Maybe its worth the testing the regulator.
    As for the ECU I did disconnect the (-) terminal on the battery but I’m reading online the (+) is better for resetting the ECU? I’ve put roughly 350 miles on it, highway and city. Should be enough to have the ECU adjust, right?
  9. Dec 19, 2021 at 6:32 AM
    RoscoeTT
    New York
    2002 Toyota Tacoma
    [SOLVED] After all that lovely time spent testing and diagnosing. Took it to a diagnostic shop who happened to have an extra and did a swap while testing the throttle body. The IAC out of the box was trash, door was only opening half way.
    Never would of known unless I did exactly that. Lessened learned, major engine rebuilds means lots of new parts. Limit how much you swap at once if you can do so!
    Bivouac likes this.
