Pulstar Spark Plugs? 2.7L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BobSaget916, Dec 12, 2009.
  1. Dec 12, 2009 at 1:41 PM
    BobSaget916
    BobSaget916 [OP] Active Member
    Seth
    Lafayette, LA
    06 Access Cab PreRunner 4-cyl MT
    Volant CAI Magnaflow Cat-Back HID's 6000k bi-xenon Fog Light Kit mod w/6000k HID's Tinted Tail Lights Kicker CVR 10'' Sub in Super Crew Sound Sub Box Alpine MRP-350 Monoblock Amp Pioneer Premier Head Unit JL 6x9's up front 6.5's in the back Tweets up front Mud Flap Delete 5 over 20% Tint in the back, 20% on the front, 35% on the WS EGR In-Channel Wind Guards Coming Soon -Doug Thorley Headers -Color-Matched Front and Rear Bumpers, Overfenders, Mirrors, Door handles, and Grille -Billet Grille or Mesh Grille -Bilstien 5100's front and rear -OME Coilover Springs -Rear Add-a-Leaf -33's after suspension work is done -TRD Skidplate
    Hey guys, i'm looking to change my spark plugs pretty soon, I have 63k miles. I was either going to get a set of Denso's or NGK's knowing that they both make good products. I was just curious if anyone has experienced first hand how the Pulstar plugs work. I've never used them but I see them advertised and a few friends swear by them. Has anyone used them? Should I put em in the taco? They are kinda pricey, around $14 per plug.
  2. Dec 12, 2009 at 1:45 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Just regular old NGK's will do the job just well. NGK is some good shit. I have always run NGK plugs in all of my vehicles.
    All those fancy plugs with the extra electrodes and stuff aren't worth the money.
  3. Dec 12, 2009 at 1:49 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you have the 4cyl...so you have iridium plugs from the factory, which are good up to 100k miles, so no real need to change them yet. other than that....i'd stick to denso plugs.....or ngk....over any other plug out there.
  4. Dec 12, 2009 at 1:49 PM
    BobSaget916
    Seth
    Lafayette, LA
    Well I run NGK in all my other stuff and never had a single problem with an NGK plug. Plus I work at a motorcycle dealership and we're an NGK dealer so I can prob get em at cost lol.
  5. Dec 12, 2009 at 8:32 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    I use Denso Iridium U-Gap plugs they work great and they are not to expensive. What ever you use get Iridium plugs according to Toyota that is what you are supposed to use, plus they last longer.
  6. Dec 12, 2009 at 8:54 PM
    j1999t
    j1999t Well-Known Member
    Justin
    Northern Colorado
    traded it in
    a friend of mine that works at a mechanic shop showed me the pulstars he had pulled out of a customer vehicle, they were broken... and after they replaced them with oem plugs, the vehicle ran better than ever
  7. Dec 12, 2009 at 9:13 PM
    tacopuppy
    tacopuppy Well-Known Member
    I would just go with regular NGK or Denso in the red OEM Toyota box from your stealer. Do the Pulstars work? Sure they do, just as well as the OEM versions. But, if you want to spend the extra $ to get a warm fuzzy, and a possible .5% increase in mpg, go for it. the fancy spark plugs are just snake oil for common drivers like me
  8. Mar 13, 2010 at 3:44 PM
    jammc83
    jammc83 New Member
    Marysville, WA
    04 4x4 Yoda
    added 3" lift, bed liner, white turn light, so far...
    Ya i bought some for my Yoda and they suck!!! i should have just gone with what toyota say to use!!! DONT USE PULSTAR PLUGS!!!!
  9. Mar 13, 2010 at 5:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Aside from the PulseStar plugs being fragile...They also can cause a lean out condition in the engine....Thus triggering a CEL
  10. Mar 13, 2010 at 5:58 PM
    Anthony
    Anthony San Antonio Detailer :)
    Houston - Spring/Tomball area
    06 prerunner access cab 2.7L M5
    Nfabs Afe Pro Dry UWS linex'd toolbox
    plugs as well as most other maintenance parts, its best to go with oem.
