Pump brakes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mrcheap, Jan 6, 2024.
  1. Jan 6, 2024 at 8:28 AM
    mrcheap
    mrcheap [OP] Well-Known Member
    Helping a buddy change brake pads
    should I pump the brakes after each corner is complete or in pairs?
    or does it not matter
    getting old and not remembering if there is a “proper” way
  2. Jan 6, 2024 at 8:35 AM
    Bishop84
    Bishop84 Well-Known Member
    The only reason to pump after each corner is to prevent overflow if there's too much fluid in the reservoir.
    Just do the brakes as you see fit and pump after.
    A quick bleed to get fresh fluid through the system isnt a bad idea though.
    Good luck!
  3. Jan 6, 2024 at 8:35 AM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    You mean bleed the brakes ? Or is your buddy soon going to be 6 feet under ?
