Puppypunters idea hole
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Puppypunter, Mar 9, 2021.
  1. Mar 9, 2021 at 12:01 PM
    Puppypunter
    Puppypunter [OP] Well-Known Member
    Johnny
    2019 Black SR
    My roller is really just a solid piece of aluminum that is tapped on each side so it bolts to the bravo rack, and then there is an outer tube over it that rolls. Mechanically very simple. The inner piece is 3/4” diameter and the out is 3/4” ID and 1” OD. So snug, but still rolls. Mainly just to keep stuff from rubbing off the powder coating on the rack from being slid across it.
  2. Mar 9, 2021 at 12:01 PM
    Tacospike
    Two Trucks
    Just a complete harness for the kick key amp.
  3. Mar 9, 2021 at 12:03 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Send me the specs and I'll build it. Assuming I can acquire the connectors. I can T into the OEM stuff already and I know the pinouts there, just don't have any interest in owning anything under the Kicker label :)
  4. Mar 9, 2021 at 12:03 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Thats my issue too. My kayaks hull dragging across the tailgate panel has worn a nice deep groove in the plastic. I built a giant drawer that bolts to the bed, then slides out 3 feet to load and unload my kayak with, but I hit a road block and put it on hold for the winter.
  5. Mar 9, 2021 at 12:10 PM
    Tacospike
    Two Trucks
    It was in my post on the first page.
    I think that link had the list on the first page of that thread.
    That would be great :D
  6. Mar 9, 2021 at 12:30 PM
    daveeasa
    David
    PNW
    Ah, I see now, you built a nice guide.
    We need to locate the pins and connectors for the kicker 12 and 8 pin. They look like molex from what little I know. Johnny, any help locating them? I just got some digikey molex so I can probably hunt down 8 and 12 pin females.
    @Tacospike given a nice short 4" T, how long did you want the fed to the kicker? Your harness looks way long to me but it all depends on placement of this thing.
    Tacospike[QUOTED] likes this.
  7. Mar 9, 2021 at 12:33 PM
    Tacospike
    Two Trucks
    Not sure but, no further than under the driver / passenger seat?
  8. Mar 9, 2021 at 12:34 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    :eek:
  9. Mar 9, 2021 at 12:36 PM
    daveeasa
    David
    PNW
    I'd need a number, 5' perhaps? 6'? 2 meters?
    This all seems super doable. 16 TXL and some wire loom, all of which I have and could use some practice with. One hour tops, you did a nice guide. Kind of nice to not have soldered connections.
    So, I'd build one for you to test out and if it's good to go then you wanted to bulk produce these for others? Or just a one-off for you?
  10. Mar 9, 2021 at 12:38 PM
    Tacospike
    Two Trucks
    6'
    lol, I didn't make the guide. Sorry if it came across that way :(
    Just a one off for me.
    Skydvrr likes this.
  11. Mar 9, 2021 at 12:38 PM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    Plug and play line out converter with adjustment knob? For 2021
  12. Mar 9, 2021 at 12:45 PM
    daveeasa
    David
    PNW
    I've read that the connectors are different but haven't seem them. A close up of the positions and shape might help. If it's 090II 15 pin or something I may have a pair already.
    I do have a line out converter from the kit I bought off eBay.
    Something like this just with the correct connector?
    https://www.ebay.com/itm/Toyota-Lex...Amp-Amplifier-Plug-Play-Harness-/143574942483
  13. Mar 9, 2021 at 12:47 PM
    Puppypunter
    Johnny
    2019 Black SR
    They look like Molex for sure. @Tacospike Any way to get a better picture?
    Tacospike likes this.
  14. Mar 9, 2021 at 12:48 PM
    Evostaco
    Nebraska
    Something like that yea, truck is still on order. I'm just trying to get ducks in a row while I wait
  15. Mar 9, 2021 at 12:53 PM
    #35
    daveeasa
    David
    PNW
    Maybe find a friend with a 2021 and get some good photos of the connector and maybe even a part number? Unless Caribe can pull that for us.
  16. Mar 9, 2021 at 12:55 PM
    #36
    Puppypunter
    Johnny
    2019 Black SR
    An adjustment knob on it wouldn't be really useful. You're better off adjusting your gain. Any adjustment on the line level would just be equivalent to turning down the volume, as it isn't going to go past 100%, only down. Make sense?
  17. Mar 9, 2021 at 12:56 PM
    #37
    daveeasa
    David
    PNW
  18. Mar 9, 2021 at 12:56 PM
    #38
    Tacospike
    Two Trucks
    I don't have anything yet. Was just going off the pics in the thread
  19. Mar 9, 2021 at 12:58 PM
    #39
    Evostaco
    Nebraska
    Yea, I like to be able to turn it down easily for kids, etc
  20. Mar 9, 2021 at 1:01 PM
    #40
    daveeasa
    David
    PNW
    You do that via amp gain rather than signal attenuation. You want a strong signal through the wire.
    Think of it like water supply to your house. You don’t want to decrease pressure until it enters the home. Then pressure reducer for your internal plumbing.
