Purchase advice - 2012 Tacoma TRD Off Road
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ALine14, Jun 16, 2020.
  1. Jun 16, 2020 at 1:35 PM
    ALine14
    ALine14 [OP] Member
    2012 black Tacoma TRD OR
    Afternoon,
    I’m brand new to this forum, post number one, but I’ve been reading on here for a bit. I’ve been in the market for a Tacoma since early this year and finally found one that I believe fits the bill. It’s a 2012 TRD Off Road w/130000 miles for 16500 (double cab). Although I really like this one and have read enough reviews to feel comfortable, i would just like to get a last sanity check from experienced taco owners before I pull the trigger. My main concern is longevity. I know tacos last forever, but what are your thoughts on the mileage for this? It’s been a daily driver, one owner , no off roading at all. I intend to use it to build an overlanding rig for use on moderate trails across the Southwest.
    Thanks for your advice/input!
  2. Jun 16, 2020 at 1:38 PM
    Hikerbox
    Hikerbox Well-Known Member
    2015 SR5 Access Cab
    Pay for your local mechanic to perform a pre-purchase inspection. If everything's good or there are only minor problems i would go for it and not worry about the mileage, 130k in 8 years is only 16k a year.
    Also never believe someone selling you a vehicle when they say "never been off road"
  3. Jun 16, 2020 at 1:38 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Welcome to TW.
    Tacomas may last, but not their frames. Check the frame very carefully for rust.
  4. Jun 16, 2020 at 1:59 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    2012 V6s were the first year of the v6 that saw the introduction of the SAIS smog pump (injects clean air into exhaust on startup to help cats do their job better on startup). the 2012's did not have the shutdown purge like the 2013-2015 trucks and often the 2012's experience valve failure quicker due to this.
    Just a consideration.
    magneticwhite88 likes this.
  5. Jun 16, 2020 at 2:00 PM
    Big_Red_Taco
    Big_Red_Taco Well-Known Member
    SoCal
    Rad Red '08 DCSB TRD Off Road
    Mostly stock: AP rear plate bumper, CR D-Lights, 4600s
    I bought my '08 OR at 124K 3 years ago for more (I'm the 2nd owner), and I purchased it with a really impressive exclusive warranty. From my own cursory inspection at the time (and subsequent experience since), it was off-road quite a bit in its previous life. That being said, all the repairs I had done were covered under the warranty, and were pretty much age related. Not unexpected.
    At that age, especially check the driveshaft U-Joints, wheel bearings, timing chain cover (4.0s tend to weep), CV boots. All these, save the TC cover, are items that wear with age.
    If you're from a snowy, road-salted area, check for frame rust. And like others have and will say, have it inspected by a mechanic if you can.
    I had a 2010 2.7 single cab that I bought brand new and took all the way to 200K before it was taken out in an accident. :facepalm:The above wear items needed to be addressed for both of my trucks. My current truck just rolled over 200K and since the initial repairs, I haven't really had any issues, except age related stuff.
    Enjoy the truck. It's barely broken in!!!
  6. Jun 16, 2020 at 4:31 PM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    True but this is an easy fix with the secondary air filter uni mod
  7. Jun 16, 2020 at 5:15 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    100% depends on location.
  8. Jun 16, 2020 at 5:36 PM
    ALine14
    ALine14 [OP] Member
    Good inputs from all, thank you! This vehicle is from Texas, so no initial rust concerns. If I feel good after an inspection it will be tempting to pull the trigger. The other option is a 2016 with 60k, similar background, dealer will go 27000 out the door. Not sure if half the mileage is worth 11000 more though..
  9. Jun 16, 2020 at 8:33 PM
    toytaco112
    toytaco112 Sup
    Cedar Park, TX, US
    2012 Tacoma DBLCB 4x4 short bed
    King 2.5 Extended travel coilovers, JBA UCA's Deaver stage 2 leaf pack, All pro Aluminum replacement front with 9500lb smittybilt winch, cheap ebay rear replacement, 285.75x16 BFG All- terrains on Method NV wheels, Air ride bags light bars, rock lights bumber light bar And the list goes on..
    I have a 12 trd offroad 103k bought it brand new tons of mods and literally havent had one issue with the truck besides normal wear n tear items and normal maintenance items love the truck
    ALine14[OP] likes this.
  10. Jun 16, 2020 at 8:39 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I’ve had mine for 5 years. Dead reliable. The smog pump is covered by a warranty enhancement on the 2012, but not on the 2013-2015. The 2012 frame is also covered by a warranty enhancement so you’ll be good for several more years in that regard.
  11. Jun 17, 2020 at 4:53 PM
    ALine14
    ALine14 [OP] Member
    Thanks for the inputs. My mechanic is taking a look tomorrow so we will see what comes of that
  12. Jun 17, 2020 at 5:43 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    Seems like a decent deal as long as you've checked things out and test drove it. Good points though brought up from everyone.
    I'd recommend a good test drive on a 3rd Gen before considering it. Driving a 2nd Gen and a 3rd Gen are two different things.
  13. Jun 17, 2020 at 6:19 PM
    ALine14
    ALine14 [OP] Member
    What have you found to be the biggest differences? I’ve never driven a 3rd gen is there some warrant to paying 11k more for a 2016 with half the miles (65k)?
  14. Jun 17, 2020 at 8:34 PM
    Shadowray
    Shadowray 3rd Gen back to 2nd Gen...
    Arkansas
    2012 Tacoma TRD Sport
    I sold my 2015 for a 3rd Gen and had nothing but problems and hated the transmission in that truck. After a serious of recalls I went back to a 2nd gen and glad I did.
  15. Jun 17, 2020 at 11:38 PM
    Dacapster
    Dacapster Well-Known Member
    Hugh
    14 trd
    Many coming
    And make sure it's not
    a Harvey flood truck ....
