Purchasing a taco at 290k?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Trevorfox34, Jul 26, 2013.
  1. Jul 26, 2013 at 2:45 PM
    Trevorfox34
    Trevorfox34 [OP] Member
    Trevor
    Louisiana
    '96 taco
    None yet, recently purchased
    I recently found a 96 taco and the guy wants $3,000. The truck is stock with road tires. He has never done anything to it besides regular maintenance and he just replaced all the ball joints. 4X4, A/C and cruise all works like a champ. Its in good condition, no big dents, carpet could be taken out.. He said out of the last year 4X4 has been used 3 times maybe..The only problem is the clutch is going out...He said its a daily driver for work and back. Do yall think this is a good deal? It is my first taco.
  2. Jul 26, 2013 at 2:48 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    What engine is it?
  3. Jul 26, 2013 at 2:53 PM
    somethinboutayota
    somethinboutayota Dorthy left Kansas for a reason
    Parker
    Dodge City, Kansas
    Go to get alignment- replace whole front end
    Debadged and painted, plasti-dip bumper , Sock monkey decals, tool box, K&N cold air intake, flag holder/fishing pole holder, Satoshi, magnaflow 40 series, spidertrax wheel spacers, map lights, led reverse lights, led dash assembly lights, roof top LED bar
    Talk the price down for the clutch, ask him about maintenance too like the last time he replaced the belts and such
  4. Jul 26, 2013 at 3:04 PM
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    ^^This is important. Also is it reg cab or ext cab? That normally constitutes a big price diff.
    With that many miles check things like rear main seal, valve cover gaskets, and rack and pinion so you can get an idea if any maintenance will be needed right away.
    High miles isn't always a bad thing. I bought my truck with 222k on it..
  5. Jul 26, 2013 at 3:43 PM
    Trevorfox34
    Trevor
    Louisiana
    '96 taco
    Well it's an extended cab with the v6 in it. How much is a clutch for these things?
  6. Jul 26, 2013 at 3:49 PM
    Trevorfox34
    Trevor
    Louisiana
    '96 taco
    He started at 3,900
  7. Jul 26, 2013 at 4:00 PM
    cmj
    cmj Well-Known Member
    Tucson
    98 Tacoma 4x4
    considering that it was his daily driver, and he's selling it when the clutch is going out might give you an idea of his attitude towards spending money on it. At this mileage, there is likely a lot of wear on suspension components that will need attention for it to drive nice and not chew through tires. I would need full records of all work done on the truck to buy it. Ask him when/if he's replaced the upper and lower ball joints, tie rods, steering rack, wheel bearings, brake pads, brake fluid, coolant, belts, hoses, timing belt, VALVE ADJUSTMENT, greased the slip yokes and u joints, changed the transfer case, diff, and trans fluids, shocks, etc. I wouldn't hesitate to buy it if it was someone who kept their vehicle in top shape, but I would not buy a vehicle from someone trying to stretch their dollars by driving it in to the ground.
  8. Jul 26, 2013 at 4:01 PM
    somethinboutayota
    Parker
    Dodge City, Kansas
    If you do it yourself I think its around 200 or 300 but if you have it done somewhere its anywhere from 5-800, depends on where you go
  9. Jul 26, 2013 at 4:33 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    $800 or buy something else. Don't be afraid to walk. He's not doing you any favors.
  10. Jul 26, 2013 at 4:34 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    marlin crawler builds a pretty good clutch kit.
  11. Jul 26, 2013 at 4:49 PM
    Trevorfox34
    Trevor
    Louisiana
    '96 taco
    Ok I asked him about the maintenance...hopefully he replies positively...he said he got a new truck and no longer needs this one...only reason I haven't walked, is because I can't afford any other 96 at this price...If I wait, it could be next hunting season before I got one and I need it this season...
  12. Jul 26, 2013 at 8:27 PM
    toastyjosh
    toastyjosh Well-Known Member
    northern New mexico
    95 dark green taco(sold), 2005 chevy 2500HD duramax
    Do it!
    I got a 95.5 beat with 268K for 3500.
    Runs great, needs afew things.
    Seafoam it, do a full tune up, change fluids and go.
