Purple Tank Top Ruthlessly Attacks Tacoma CV Boot.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BigJimmyP, Sep 3, 2019.
  1. Sep 3, 2019 at 10:29 AM
    BigJimmyP
    BigJimmyP [OP] Well-Known Member
    Jimmy
    St. Louis, MO
    2011 Pyrite Mica. 4 Doors. 4 Wheels. 4x4.
    17x9 MT Classic III, 285/70/17 Terra Grappler G2, oem int. wipers, fog light install, window tint, W.T. visors and floor MATS, OME lift front and back.
    Yes, folks. It appears a purple tank top escaped into the wild and cross bred with a boa constrictor. Their only misfit offspring grew up angry and bullied, then committed suicide by wrapping itself around my cv boot and squeezing out evey last bit of grease it could. The other cv boots are very sad. The affected boot, however, is in the ICU with a fighting chance of making it.
    I went to change my oil. Everthing was fine. Then I looked over and saw the crime scene. Grease was eveywhere. But after cleaning up the injured victim, I found no holes in the boot. The only holes were in the shirt. The grease must have slowly oozed from the seal as the death grip tightened. I think it came from the outter seal, and i think more than half is gone. We need a transfusion!
    Ok. So now comes the questions... What do I do now? It's a 2011 with 88k. The grease that came out was... Greasy, but not bad looking. How can get more grease in, and what kind should I use? I dont really want to pull it off if i don't have to. Be gentle with your response, as this is a time of mourning and deep reflection. Thank you.20190902_091638.jpg 20190902_092121.jpg
    EDIT.... SEE POST #58 FOR THE SKETCHY PATCH JOB.
  2. Sep 3, 2019 at 10:33 AM
    rmorse
    rmorse Well-Known Member
    Bobby
    Bowie, MD
    2015 Blue Ribbon Metallic Access Cab TRD Sport
    1 like = 1 prayer :sick:
  3. Sep 3, 2019 at 10:34 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
  4. Sep 3, 2019 at 10:36 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Damn.. Any ideas how long its been in there? Id would wonder about abrasion of the boot where the shirt was rubbing, even though it was covered in grease Im sure it still got pretty warm rolling down the road like that
  5. Sep 3, 2019 at 10:38 AM
    R242
    R242 I have a tortoise
    Rick
    Indianapolis, IN
    2024 SR 4x4 6 spd
    Well if the boot is ok, a regular grease gun with a needle attachment and poke the boot. Works for me, but jeez what bad luck lol.
    llamasmurf, winkel and wilcam47 like this.
  6. Sep 3, 2019 at 10:45 AM
    BigJimmyP
    Jimmy
    St. Louis, MO
    The ridges on the boot looked a tad worn but in tact. No telling how long it was there. Could have been months! Even though it was wrapped up, it was well lubed so maybe friction wasnt as much of a problem.
  7. Sep 3, 2019 at 10:47 AM
    BigJimmyP
    Jimmy
    St. Louis, MO
    Will poking the boot wih a needle make a hole that will leak? A buddy will loan me the needle attacment if i want.
  8. Sep 3, 2019 at 10:47 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Fill your kitchen sink with lukewarm water mixed with plenty of dawn dish soap. Let soak for two hours, rinse with cold water, then refill the kitchen sink and agitate by hand until most of the grease is gone. Spot treat the stubborn stains with a tide stick. That tank top should be wearable in no time.
    glwood6, JimIowa, Acabsurf and 40 others like this.
  9. Sep 3, 2019 at 10:50 AM
    BigJimmyP
    Jimmy
    St. Louis, MO
    Hahaaaa i will post pics of that nasty thang in a little bit. It should have never been bought. I would have thrown it out the window too.
    Rock Lobster likes this.
  10. Sep 3, 2019 at 10:52 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    prob used to wipe up...some "love stains"
    Skyway and Rock Lobster like this.
  11. Sep 3, 2019 at 10:53 AM
    yodataco
    yodataco Well-Known Member
    Alex
    Orange County, CA
    2000 4Runner
    MCM fab 3.5" LT front, OME 861 rear
    OP did you run over someone? Dont lie.
  12. Sep 3, 2019 at 10:53 AM
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    F
  13. Sep 3, 2019 at 10:53 AM
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    Nailed it. Had me in stitches!
  14. Sep 3, 2019 at 10:58 AM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Yes it will cause a leak. A small leak, but a leak nonetheless. More importantly, it'll also provide a way for dirt to get into the joint and cause premature failure. The least intrusive way I can think of to get grease back in the boot would be to carefully cut off the inner clamp and use the needle attachment on the grease gun to slide under the boot and squirt away. The problem is you don't know how much is missing or how much you're putting in there. You can then use a regular hose clamp to seal it back up. This is of course your best option if the boot is otherwise undamaged. But honestly all that grease on the shirt came from somewhere so I'd look for the smallest tear in the boot or damage to the outer clamp. You may need to replace the boot and can regrease the proper way using proper axle grease.
  15. Sep 3, 2019 at 11:00 AM
    Collins
    Collins Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    Def. in for the clean Tank Top photo's.
    I think you slide the grease needle between boot and compression clamp, if not able, remove axle side inner (smaller) clamp and grease and replace clamp.
    I posted a couple weeks ago about a leaky boot, sans the suicidal Tank Top, but only needed to wipe it off, so far no other grease exuding...
  16. Sep 3, 2019 at 11:11 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
  17. Sep 3, 2019 at 11:21 AM
    BigJimmyP
    Jimmy
    St. Louis, MO
    Thank you thank you! Now that is a damned fine write up, sir. I hope not to tear down the whole thing but it may be an excuse to buy me some new tools!
    Any thoughts about just getting the grease from toyota? I see part numbers on those grease packets... Will have to make some phone calls.
  18. Sep 3, 2019 at 11:33 AM
    Extra Hard Taco
    R.J.
    Devil's Island
    Not my write up it was done by @turbodb. Maybe he will chime in on the the grease, keep in mind this is for a 1st Gen but the process should be similar.
  19. Sep 3, 2019 at 11:39 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    I despise purple tanktops... :mad:
  20. Sep 3, 2019 at 12:27 PM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    The white ones tho'!
    Nom-nom-nom... :eek:
