Push Button Start for 2012 Tacoma TRD OR. Want modify so key stays in pocket
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Joe Conrad, Apr 8, 2018.
  1. Apr 9, 2018 at 1:01 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
  2. Apr 9, 2018 at 1:06 PM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    Welcome to TW, I'm actually surprised you got a bunch of non sarcastic answers to start with. Took a little long for the derailment to happen, but that occurs in every thread.
  3. Apr 9, 2018 at 5:49 PM
    Joe Conrad
    Joe Conrad [OP] Member
    Joe
    Tacoma, Charcoal 2012, double cab, 4WD,
    Panasonic Touch screen, w/GPS,/map, siriusXM, FM, AM, Steering wheel controls etc. installed tool box
    Welp,.... guess I mighta, sorta, done, did, maybe, .. Looka c'here around a bit mo........ yup
    After some preliminary searches...., in the likes of 'ebay' and 'Amazon' for instance, There seems to be several "remote start' (as much as a half mile away) w/'keyless entry' and 'automatic door locks' etc. sold in kits.
    But once you get in the drivers seat,... even though the engine is already running YOU STILL HAVE TO PUT THE KEY IN.... if you want to put the vehicle in gear and drive away
    Go figure....
  4. Apr 9, 2018 at 5:51 PM
    Hunter.415
    Hunter.415 Well-Known Member
    Pete
    Western mass
    2012 Tacoma short bed 4x4
    Cooper t/a 3
    Did try searching you tube?
  5. Apr 9, 2018 at 5:57 PM
    motodude95
    motodude95 Well-Known Member
    Jim
    2012 MGM TRD Sport DCLB, OME 886s, 33s
    Buy a ridgeline get your luxurious push button
    TacomaMike37 likes this.
  6. Apr 9, 2018 at 6:03 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    After driving my wife’s Acura RDX a bit I can see how push button start is kinda nice but hardly such an inconvenience for me to go looking for a key alternative....
    But....
    Different strokes....so report back here when you’ve got this figured out OP. Good luck.
  7. Apr 9, 2018 at 6:16 PM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    You can get a compustar remote start system with ez go module. The ez go allows proximity lock/unlock. Not expensive but install I've heard is a pain in the urethra. Each power door lock has to be tapped into. I personally believe push button is a gimmick. My wife has a push button civic and I don't see the convenience in it. You still have to carry the "key" on you. Proximity lock/unlock would be a godsend.
  8. Apr 9, 2018 at 8:41 PM
    Joe Conrad
    Joe
    All hail "Kyledamon",
    He just might be on to something, regarding just hanging a key from the wiper stock and lock/unlock doors with the 2nd key or Fob. (if only, it had a proximity lock release).
    What an obvious solution, that I had not noticed.
    Yes sir, it will do in a pinch. Not a fancy idea, but done simple, like the jitterbug, it plump amazed me. In the mean time, I can continue the seach for a push button start kit that will cover both bases (entry and ignition).
    There has to be one, wouldn't ya think...??? Most all other Toyota's from, say 2010 on have it. Why not Tacoma ?
    toucan and kyledamon like this.
  9. Apr 9, 2018 at 8:58 PM
    Joe Conrad
    Joe
    Just saw "Thyces" remarks above.
    Will study up on the Compustar remote start with
    ez-go module that he mentioned. Might guess the dealership would install that, but would surely overcharge for it. Can surely find alternatives.
    Thankye kindly to Thyces
    Thyces likes this.
  10. Apr 10, 2018 at 2:01 AM
    N2DesignsInc
    N2DesignsInc --------------------------- N2 Designs, Inc. Vendor
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
    Who here has had or knows anyone that has experienced this hacker stalking? Although it’s true, is that really a reason to denounce the technology? Seems a bit of an overkilled imagination although theoretically true, odds are slim that this would happen!
    TacomaMike37 and Black taco. like this.
  11. Apr 10, 2018 at 2:11 AM
    Black taco.
    Black taco. Well-Known Member
    4x4. MT.
    The clowns always come out of the wood works.
    Ask a question and get nostalgic metal key nonsense.
    Keyless keys are advertising ploys for feeble women?
    What a joke.
    TheCochese likes this.
  12. Apr 10, 2018 at 2:12 AM
    Black taco.
    4x4. MT.
    It’s like not using a credit card or computer because of hacking.
  13. Apr 10, 2018 at 6:42 AM
    fritzthecat
    fritzthecat Well-Known Member
    Virginia Beach
    07 PreRunner Auto AccCab Indigo
    I looked and have yet to find a true Pushbutton Start (PBS) system for a Tacoma. Remote start yes, and there was a writeup on a homemade pushbutton engine start but all require key insertion.
    The complication is that the Tacoma is designed with mechanical ignition. A Prius and other PBS cars are factory build around a electronic start system.
    In the Tacoma you would need to completely bypass the key ignition module (mechanical steering lock, key security, rotating cylinder etc). The PBS module would be wired into the ignition harness with the mechanical ignition permanently set to "Run". The PBS module would sense a transponder in your pocket and upon pressing the button turn on the truck first (from Off to Acc to Run) and then start the engine (reverse on shutdown).
    Don't know if somebody somewhere makes this system but it would be insanely expensive.
    Fritz
    Joe Conrad[OP] and Thyces like this.
  14. Apr 10, 2018 at 9:54 AM
    N2DesignsInc
    Los Angeles, CA
    Exactly and I still carry my credit cards without an rfid shield. I live on the edge so I’ll take push to start over key any day!
    Joe Conrad[OP] likes this.
  15. Apr 10, 2018 at 10:06 AM
    #35
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    I’d love to have remote start and proximity steering wheel unlock.
    Texas is hot AF, and having my AC running when I walk up to the truck would be amazing.
  16. Apr 10, 2018 at 11:20 AM
    #36
    Joe Conrad
    Joe
    Like to thank 'fritzthecat' for approaching the inquiry in a serious manner.
    And for presenting the dilemma so succinctly, as well as sugggesting possible solution and cost restrictions.
    And OBTW, its hot as hell here in South Central Florida too !
    It's forcast to be over 90° today, and summer isn't even here yet !
  17. Apr 14, 2018 at 11:09 AM
    #37
    Joe Conrad
    Joe
  18. Apr 14, 2018 at 2:29 PM
    #38
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    I support you OP
    I don't see how this is such a difficult task, at least for my 2005 PreRunner (no transponder). If you can read diagrams, they're available if you look.
    :thumbsup:
    :popcorn:
  19. Apr 14, 2018 at 2:36 PM
    #39
    Itchyfeet
    Itchyfeet Well-Known Member
    That just sounds junky
    I rented a car with push button start, it was nice. I could see my next vehicle having it, but retrofitting it? Nope f that, I'm not a fan of chopping into wires to add something like this only to still be stuck turning a key unlock the wheel. It's like something a ricer would do because race car
  20. Apr 14, 2018 at 2:42 PM
    #40
    05Taco4x4
    2TR-FE Enthusiast
    Its been years, but I think Toyota's install instructions for their own system requires cutting wires.
    There's no reason it couldn't be plug'n play, if the connections are procurable.
