Push button start ideas?
Discussion in '1st Gen. Tacomas (1995-2004)' started by MatthewMay1, Dec 20, 2011.
  1. Dec 20, 2011 at 6:44 PM
    MatthewMay1
    MatthewMay1 [OP] I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Has anybody installed a push button start on your frost gen tacoma? I was thinking about doing it to my 2001. I want to use one of those switches like on airplanes with the little red cover on the top that you flip up. I also want it to be where you turn the key to "on" then flip the switch. (I like it complicated and idiot proof) Anyway, if anyone has any ideas on how to do it I would love to know. I don't want to be just messing around and risk a fire.
    Thanks!
  2. Dec 20, 2011 at 6:47 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    did this in my old bronco, only it was out of necessity since the ignition didn't work.
    All we did was splice into the wire that gets power when you turn the key past "on". I had the button under the seat.
    I imagine the tacoma would be similar.
  3. Dec 20, 2011 at 6:52 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    It would have to be similar to this way^
    but then its more trouble than its worth I think, idk Im impatient
  4. Dec 20, 2011 at 6:55 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    Thanks for the thought
  5. Dec 20, 2011 at 6:56 PM
    Toyoghi
    Toyoghi Well-Known Member
    Shoghi
    Calgary, AB
    2011 Tacoma Double Cab
    Solid tri-fold Tonneau, Deezee Bed mat, Pop n Lock.
    But I am assuming you'd want it to only turn on when the key is in the car… so it wouldn't be quite that simple?
  6. Dec 20, 2011 at 7:03 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    I was going to put the key into the ignition and turn it to "On" then I think you could just take the wire for the starter and put it to a switch to put it simply
  7. Dec 20, 2011 at 7:06 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    exactly what I did on the bronco:cool:
    Make sure you use a momentary switch.
    edit: I don't really see the point though if the ignition is still working, unless it's just for added security :notsure:
  8. Dec 20, 2011 at 7:06 PM
    Toyoghi
    Shoghi
    Calgary, AB
    so you still want to put the key in your ignition every single time and turn it to on before you press the button?
    EDIT: Steven your edit made my post look redundant :p
  9. Dec 20, 2011 at 7:07 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
  10. Dec 20, 2011 at 7:17 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    Yeah, I would still put the key in the ignition.... I think it would be kind of cool. Also different.
    And I would want to use an aircraft switch, not a "button"
  11. Dec 20, 2011 at 7:17 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    lol sorry. I just had to get it out that this "mod" seems like a step in the wrong direction.
  12. Dec 20, 2011 at 7:19 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Find an ignition on source of power. NOT accessory power like the radio. Something that only works with the key in the on position. Obviously there is a wire matching this description at the ignition switch, but it's probably pretty thick and going to be hard to splice securely. You don't sound like you've done much wiring and that's the wrong wire to mess up on. I suggest going to Autozone and picking up an add-a-fuse for around ten bucks. You have to go get a switch anyway. Maybe use the windshield wiper fuse. I think that's key hot only.
    Then find the wire going to the starter relay. It's somewhere in that big bunch of wires coming down the steering column. Cut that wire and cap off the end that comes from the ignition switch. The other end is going to get attached to your new switch.
    Connect both the key hot power and the wire going to the starter relay to your new momentary switch. That should produce what you are describing.
    CAUTION: There are airbag wires in the column and under the dash. Use only a volt meter to test wires, not a test light. A test light can blow the airbags. Anything wrapped in yellow is definitely airbag related, but no guarentee that other wires are not. An airbag CAN kill you if it goes off in your face.
    There are wiring diagrams on TTORA under the factory service manual link on their page. Find out what color wire you are looking for and test to confirm. Don't go in there blindly and start testing random wires. See above airbag warning.
    All your are doing is moving the normal operation of the ignition start position to a seperate switch. It should not affect the clutch or neutral safety. Be sure to double check that when you are done.
  13. Dec 20, 2011 at 7:19 PM
    Toyoghi
    Shoghi
    Calgary, AB
    Hahaa all good, I just thought I was the only one who saw this as " a step in the wrong direction" or I was very confused. But glad to see i'm not alone. :D
  14. Dec 20, 2011 at 7:20 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    Yeah it kinda does seem like a step in the wrong direction, but I still think it would be cool. I know of nobody that has it that way
  15. Dec 20, 2011 at 7:28 PM
    snoozeworm
    snoozeworm taco king
    wheeling,wv
    2004 regular cab 4x4 5 speed
    Extra leaf springs in rear Pioneer head unit fj cruiser wheels 1in coil spacers siren
    What you need to do is install a remote start. best of both worlds
  16. Dec 20, 2011 at 7:38 PM
    MatthewMay1
    Matthew
    Lone Star Republic
  17. Dec 20, 2011 at 7:39 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
  18. Dec 20, 2011 at 7:45 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    By that you mean that's it's spring loaded to not stay cranking the engine, right?
  19. Dec 20, 2011 at 7:46 PM
    Toyoghi
    Shoghi
    Calgary, AB
    why would you not try and put one in like the prius' :anonymous:
    so you don't actually need to put the key in the ignition, just have it in the car and push the button... Not that I have any idea how, just a suggestion haha.
  20. Dec 20, 2011 at 7:49 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    yes.
