Push button start- need wiring diagram
Discussion in '1st Gen. Tacomas (1995-2004)' started by Colchicine, Oct 19, 2018.
  1. Nov 18, 2023 at 7:57 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Think of it as a starting point on a road map.
    TnShooter likes this.
  2. Nov 18, 2023 at 8:22 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It feeds power to the STA fuse. And eventually, if things "check good", It goes to the starter solenoid.
    I can't (don't want to) advise on how to bypass or wire in a push button switch.
    Too much lability and not enough information.
    Mpstickers[QUOTED] and Bivouac like this.
  3. Nov 18, 2023 at 8:54 PM
    Bivouac
    A $ 24.00 switch that should be plug and pay I still think it never worked.
    Things work fine in the stock set up
  4. Nov 19, 2023 at 5:43 PM
    Mpstickers
    Mpstickers Well-Known Member
    Yeah I don’t want to bypass anything.
  5. Nov 19, 2023 at 6:01 PM
    Mpstickers
    Things did work fine in the stock setup, this is correct. And they still do. I’m not adding the push button stat just because so think it’s cool. This particular push button setup requires the the presence of an RFID fob that’s included with the kit. When installed it works just like the push buttons setup does that came stock in my dad’s brand new Tacoma.
  6. Nov 19, 2023 at 6:31 PM
    TnShooter
    Deogee
    STOCK
    Best I can do with what I have to work with;
    Push Start --------Ignition Connection
    Brown - Pin 6 (Black/Red)
    Yellow - Pin 1 (Black)
    Blue - Pin 4 (Black/Yellow) - Need more info. Not sure what "all power" means?
    Black - To Ground
    Red - Pin 2 (White)
    White - Need more info. What is IGN1? -Is is possibly IG1? If so, we use that wire already at pin 4.
    Bivouac likes this.
  7. Nov 19, 2023 at 6:39 PM
    Mpstickers
    Yes IGN1 would be the same as IG1. I believe they also refer to it as “Ignition1” somewhere in the instructions. Thank you for your input. The way you listed things out is extremely helpful. I’m gonna take a look at everything as soon as I get home in a few minutes and see if I can’t make it all work finally.
    TnShooter[QUOTED] likes this.
  8. Nov 19, 2023 at 6:56 PM
    TnShooter
    Deogee
    STOCK
    We need to figure out for sure what the blue and red wire go to.
    Pin 6 is also an ignition wire. It goes to the ignition coils. You need power to those for sure.
  9. Nov 19, 2023 at 10:37 PM
    Mpstickers
    Thank you, you’ve already been a big help, I appreciate your time. Here is the diagram that comes with the kit. Hoping this will help you help me. What do you think?Im I was hoping to be able to just list the push button wires then lost the truck wires and show what goes where, I think you understand what I’m getting at? Thanks again for everyone’s help.
    Bivouac likes this.
  10. Nov 19, 2023 at 10:40 PM
    Mpstickers
    Oh haha! “All power” is actually “ACC power”. So it should go to #3 correct?
  11. Nov 19, 2023 at 10:45 PM
    TnShooter
    Deogee
    STOCK
    The translation barrier is real here.
    That brown wire description is confusing.
    Do they mean no power with the engine running?
    Or no power while the engine is cranking?
  12. Nov 19, 2023 at 10:47 PM
    Mpstickers
    Yeah part of my problem has been the translation barrier. Thank You, lol. They mean when it’s cranking like when I’m turning the key. And I assumed that based on the rest of the instructions Ive read. I’m trying to find those now
    Bivouac likes this.
  13. Nov 19, 2023 at 11:33 PM
    Mpstickers
    So here’s where sim at thanks to your help and my diving back into the simple nightmare…
    PUSH BUTTON……….TRUCK
    Brown wire ———->#6(blk/red)
    Yellow wire————> #1 (black)
    Blue wire—————> #3 (blu/red)
    Black wire————> GROUND
    Red wire————-> #2 (white)
    White wire————-> #4 (blk/yel)
    All this leaves out is #7, AM2. Does that sound right?
    I’m gonna go try this configuration and see what happens
    Bivouac likes this.
  14. Nov 20, 2023 at 1:06 AM
    Bivouac
    I understand but it does not work.
    How much to buy the parts from Toyota and install there switch compared to what you paid.
    You started the end of October your 20 days into the mission it still is not working.
    Granted in that time you may have only been hands on less then 10 hours.
    I wish you the best of luck
  15. Nov 20, 2023 at 1:32 AM
    #35
    Bivouac
    If this does not work I hope it does:fingerscrossed::fingerscrossed::fingerscrossed:
    Where do you live ? If your within a 1000 miles I will make a road trip to help you get this working.:thumbsup::thumbsup::thumbsup:
    I need an adventure it would help me as well.:oldglory::oldglory::oldglory: I feel for you and would love to see this up and running
    jackn7 likes this.
  16. Nov 20, 2023 at 5:19 AM
    #36
    Mpstickers
    Also found these. Checkout the translation barrier here too, this particular kit isn’t just a simple plug and play strictly because of how poor the English is in the instructions I swear! Frustrating because so know it SHOULD be a simple plug n play.
  17. Nov 20, 2023 at 5:19 AM
    #37
    Mpstickers
    And this one
  18. Nov 20, 2023 at 5:20 AM
    #38
    Mpstickers
    Maybe these will help you understand what I’m trying to accomplish and maybe they make more sense to you?
  19. Nov 20, 2023 at 10:18 AM
    #39
    Bivouac
    I am really not seeing a Problem
    .Unless your not up to speed on reading schematics?
    One always has these problems when buying a universal fit product.
    Well I made the offer I can guess your not interested.
    Best of luck
  20. Nov 20, 2023 at 10:32 AM
    #40
    TnShooter
    Deogee
    STOCK
    If you want to drive down to Tennessee and change my spark plugs and do some other "neglected" maintenance . By all means, come on.:rofl:
    I won't stop you.
    Bivouac[QUOTED] likes this.
