Push button start- need wiring diagram
Discussion in '1st Gen. Tacomas (1995-2004)' started by Colchicine, Oct 19, 2018.
  1. Nov 20, 2023 at 10:36 AM
    #41
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    What time are we eating?
  2. Nov 20, 2023 at 10:42 AM
    #42
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Anytime you want.
    If you wait on me, you'll get hungry.
    I'm bad to not eat if I'm busy. People tell me all the time I'm starving them. :rofl:
    Bivouac[QUOTED] likes this.
  3. Nov 20, 2023 at 11:42 AM
    #43
    Bivouac
    i can also get that focused.
    TnShooter[QUOTED] likes this.
  4. Nov 20, 2023 at 12:04 PM
    #44
    Mpstickers
    Mpstickers Well-Known Member
    Yeah I’ve got maybe 3-5 hours into it. And no I’m not the best at reading electrical schematics….thus the reason why I’m here asking all these questions.
  5. Nov 20, 2023 at 12:05 PM
    #45
    Mpstickers
    I’m just south of Seattle, in Tacoma, WA. Come on.
  6. Nov 20, 2023 at 12:13 PM
    #46
    Mpstickers
    It’s not really a schematic issue though. It’s the translation barrier that was mentioned earlier. Did you try reading those at all. They are laughable at best. Combine that with my not so vast knowledge of automotive electrical system stuff (I know just enough to get myself in trouble)…..and that brings me to sherei
    So you’re really not seeing a problem, and I suck at electrical stuff (clearly) is it too much to ask for you just go down my list of wires and tell me what color wire from the push button kit should go to which spot on the trucks ignition plug? You’re definitely making it sound like this is petty simple and it sounds like you can see the solution that I cannot. Or am I misunderstanding you.
  7. Nov 20, 2023 at 2:57 PM
    #47
    TnShooter
    Deogee
    STOCK
    I'll do my best later tonight.
    I will say, should you wire it how I post it.
    Do so at your own risk.
    Give me an hour or 2. I just got home.
    I been out since 7am and reek of 2-stroke exhaust and mulched leaves.
    Plus, I haven't eaten all day.
  8. Nov 20, 2023 at 4:08 PM
    #48
    TnShooter
    Deogee
    STOCK
    Push start ------ Ignition Connector
    White -> Black/Red Pin #6
    Yellow -> Black wire Pin #1
    Red -> White wire Pin #2
    Blue -> Blue/Red pin #3
    Black -> Ground
    Brown -> Black/Yellow pin #4
    Let's hope for the best.
    Again, Do so at your own risk.
    I did the best I could going off the "not so good" directions.
    jackn7 likes this.
  9. Nov 20, 2023 at 6:44 PM
    #49
    Bivouac
    This is the type of thing I dealt with at work for 40 plus years just maybe 20 or more pages. **I Think a Footnote is what your calling the translations*** you have a few footnotes. Some jobs I had to deal with footnotes for footnotes.
    Experience really helps What is simple for me could very well be almost impossible you must have something that you can do that makes me look like a idiot.
    This is a hands on in person problem trying to tell you online is so very difficult.
    Where do you live I am quite serious if your east of the Mississippi I will come help.It might take me a few months to get home.
    I can offer no more then to come help.
    Best of Luck.
  10. Nov 25, 2023 at 2:00 PM
    #50
    Mpstickers
    I do appreciate all of everyone’s help, I’m going to try to wire it up tonight when I get home. As far as you coming to help, I don’t think that’s an option as I am in Seattle my friend.
  11. Nov 25, 2023 at 8:17 PM
    #51
    Bivouac
    Don't bet on it
    Maybe not soon enough I will be much closer ASAP
    Best of luck
    TnShooter likes this.
  12. Dec 7, 2023 at 6:10 AM
    #52
    Bivouac
    we are waiting to find out how this worked out?
    I lost a computer acting up so was off line.
    So I just go opposite of my plans go west on US route 2 instead of returning back east that way,
  13. Dec 11, 2023 at 6:37 AM
    #53
    Mpstickers
    Holy sheet I do believe that worked my friend. So far so good at least. Thanks so much, I hope I can answer something and help you out some day. I’m a happy camper
    jackn7 and TnShooter[QUOTED] like this.
  14. Dec 11, 2023 at 6:38 AM
    #54
    Bivouac
    Does this mean it now works???
  15. Dec 11, 2023 at 6:55 AM
    #55
    Mpstickers
    Yes it works. but I think something isn’t 100% right because I should be able to push the button once to take me to ACC then push it and hold to start the truck(while holding the brake pedal down of course). Then push it again to stop. The way it is right now, the truck starts on the first push, as soon as the key fob is near the transponder I put under my cup holder. So so essentially can’t just sit and listen to the radio with the truck off. But I know that can be fixed it’s probably something simple, and I don’t sit in the truck and listen to the radio with it off really anyways. So yeah, all good
  16. Dec 11, 2023 at 7:46 AM
    #56
    Bivouac
    Progress in any case!!
    Better then not working at all!
    I still think the problem is in the push button rather then anything you did wrong!!
  17. Dec 14, 2023 at 3:54 AM
    #57
    Mpstickers
    ok, problem solved, final conclusion is it works as it should, I just had the procedure wrong in my head, duh. I have ACC, and it starts and kills the motor just as it should. Only starts with the RFID fob present that I have on my key chain. Throw my keys in the place where I hid the RFID transponder and it fires right up. So thanks one last time guys for your help and input.
  18. Dec 14, 2023 at 7:30 AM
    #58
    Bivouac
    Glad it all works like it should.
    Just way to much frustration to get to that point.
    Good luck moving on.
