Push button start, NO!!! Remote start, Yes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RockieTacoMama, Aug 6, 2023.
  1. Aug 7, 2023 at 2:58 PM
    twtaco$
    twtaco$ Well-Known Member
    Does it have a aftermarket remote start system. Someone could have added one if so disconnect it and see if that solves the issue.
  2. Aug 8, 2023 at 10:58 AM
    RockieTacoMama
    RockieTacoMama [OP] Member
    2021 Tacoma TRD off-road
    Front camera & smartcap
    It's the Toyota Factory remote start system.
  3. Aug 8, 2023 at 2:05 PM
    vnix
    vnix Well-Known Member
    2021 white Tacoma DCSB XP Predator
    blind spot mirrors, center tray, bedrug, more to come
    I would think you have a switch problem on the brake pedal itself. For safety reasons, all vehicles have two switches on the pedal. One for the main brake lights and a second one for the 3rd stop light. It accounts for brake light switch failure. Have someone stand behind and watch as you press the brake pedal. I'm thinking maybe your 3rd brake light or regular brake lights aren't working either due to bad/disconnected/loose connection switch. Not a fuse. The check charging system message I get on my taco (key based) when I turn on the ignition to on but don't start the engine. In the case of remote start, the pedal switches don't play into the equation. Keep in mind the loose connection could be at the other end and not the pedal switch itself.
    Good luck and drop us a line either way.
  4. Aug 10, 2023 at 11:23 AM
    RockieTacoMama
    Thank you very much! With our situation this seems to be making the most sense so far. We'll have to wait until it happens again to test. thanks!!
