Push Start Button Install (Instructions Pg 3)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Takoma2015, Mar 14, 2021.
  1. Mar 14, 2021 at 11:43 AM
    Muddinfun
    Muddinfun Well-Known Member
    How are you going to deal with the steering lock and the immobilizer? Also are you going to make provisions so that the engine can’t be turned off unless the shifter is in park?
  2. Mar 14, 2021 at 11:52 AM
    Takoma2015
    Takoma2015 [OP] Active Member
    2015 Tacoma anthracite ext cabin
    Thank you!
    I did look for threads on the subject here and everywhere in general but no specifics. Also seems like other people have been looking for the turbo timer harness part number but no luck.
  3. Mar 14, 2021 at 11:54 AM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    My wife's new car has push to start. My Tacoma does not. I must say I am not a fan and dread the day I need to replace my Tacoma. Too much tech, not enough smart.
  4. Mar 14, 2021 at 12:16 PM
    Takoma2015
    Once you remove the ignition cylinder it removes the steering lock or you can leave the cylinder in there and leave the cut the key on the on position, removing it completely is better imo.
    My truck doesnt have an immobilizer, in case yours do there are ways to go around it, easier way might be to unplug the small oem unlock-lock unit in the passenger side of the car but i haven't looked into that since I don't have one.
    The push start unit doesnt let the engine turn off unless you are pressing the brake pedal and in N or P since you have to run a wire from the unit to the brake pedal wire.
    Muddinfun[QUOTED] likes this.
  5. Mar 14, 2021 at 1:02 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Seems like a lot of work for stuff that the keyed ignition does just fine at, as well as a lot that could go wrong when in use.
    No thanks.
    Muddinfun likes this.
  6. Mar 14, 2021 at 2:02 PM
    Takoma2015
    Not a lot of work at all. It takes less than an hour if you know what youre doing, nothing has gone wrong in my year of use, definetely nothing to worry about if you do it correctly.
    CassND likes this.
  7. Mar 14, 2021 at 2:08 PM
    Bob1971
    Bob1971 Well-Known Member
    Tim
    KY
    White 2020 Trd OR
    Bed cover, step bars, SCS SR8 wheels
    Is there an easy way to add a proximity key or key fob? The push to start thing doesn’t really matter to me but you got me thinking about the proximity key. It would be a nice addition.
  8. Mar 14, 2021 at 2:13 PM
    TeXanTRD
    TeXanTRD Well-Known Member
    2013 TX TRD
    Not gonna lie. I’m jealous every time I’m with my buddy and his 2020 Tacoma and he just reaches for the door and it unlocks.
    A system like this wouldn’t allow for remote start would it? Or it would just complicate things? I’m using the 12 Volt Solutions kit and living in AK it’s sadly not something I want to do without in the winter.
  9. Mar 14, 2021 at 2:18 PM
    Takoma2015
    Yeah, you need to connect the 2 wires for the lock and unlock and the door trigger wire. Also the power and negative. So i think those 5 wires and youre done.
  10. Mar 14, 2021 at 2:23 PM
    Takoma2015
    Yeah it has remote start, after connecting the ignition wires another wire controls the remote start so super easy to enable as well.
    TeXanTRD[QUOTED] likes this.
  11. Mar 14, 2021 at 9:24 PM
    nd4spdbh
    SoCal
  12. Mar 14, 2021 at 9:33 PM
    Takoma2015
  13. Mar 14, 2021 at 9:47 PM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    Not a lot of responses probably because no one has any experience with putting one in a Tacoma. Rather than no one caring about your question.
    Most people are very friendly and helpful, with a few smart asses mixed in.
    All in all this is a great community to get info from. Sorry l couldn't help you at all.
    Welcome to Tacoma World :thumbsup: Good luck
  14. Mar 14, 2021 at 9:51 PM
    Rick's 2012
    Rick
    Costa Rica
    Stock
  15. Mar 15, 2021 at 5:05 AM
    #35
    bw4706
    bw4706 Well-Known Member
    Illinois
    09 Toyota Tacoma DCSB
    Bilstein 6112's , Eibach Coils,Hankook Dyna Pro MT 265/75/16, SPC UCA's, General Spring HD leaf packs, De-Badged, Ranch Bed Cap, Mag Light Seat Mount driver and passenger, Mini Mag Console Mount,Hard wired GPS, LED's in and out, MB TKO Wheels, After market grill, Heated seats, Diff breather relocation mod, LED Under Hood Lighting, LED Bed Lights, Aux. LED Reverse Lights, 30" L.E.D. Light Bar, Redline Tuning Hood Struts & EZ Down Tailgate. 6 Circuit Aux. Fuse Panel W/Circuit Breaker. Front & Rear Facing DVR cameras, High Lift Jack Bed Rail Mount. Clazio Leather Seat Covers. All Pro Heavy Duty Rock Sliders, 4x4 illuminated switch mod, Ignition converted to Push to Start. Bushwacker fender flares, Cali Raised side projector ditch lights. Cali Raised L.E.D. fog lights. 3 x 3 L.E.D. rear spotlights , Anzo headlights and taillights.
    Sorry, no experience installing one.
    I bought a Digital Guard Dog push start system, 5 years ago. Had the local stereo shop do the install. Took about 3 hours. System has the push start , alarm. and remote start. It automatically locks, and unlocks the doors when approaching the truck. ( can be disabled to use F.O.B. buttons ) If you forget your F.O.B. , the kit comes with a credit card type key for your wallet, which you place in front of antenna to unlock and enable the system.
    I'm happy with the results. I believe the system cost was around $1200 installed.
  16. Mar 15, 2021 at 5:15 AM
    #36
    Takoma2015
    Seems like a great community so far thanks!!!
  17. Mar 15, 2021 at 5:25 AM
    #37
    Takoma2015
    Whoa... had no idea it was so expensive but labor is always pricey... that sounds like a great system, very similar to the one im using.
  18. Jul 23, 2021 at 6:14 AM
    #38
    Takoma2015
    Hi Everyone, I successfully completed the pushstart/alarm install. It took me about an hour with zero wiring splicing, the Tacoma uses the same ignition plug as my Supra so I was able to use a Supra 93 to 96 turbo timer plug.
    I will try to do a very simple write up with pictures and part numbers in a bit for those interested.
  19. Jul 23, 2021 at 6:17 AM
    #39
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Sub'd for your write up.. That's my style
  20. Jul 23, 2021 at 8:04 AM
    #40
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
