Push start fail?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by saltwater taco, Feb 2, 2013.
  1. Feb 2, 2013 at 11:46 PM
    saltwater taco
    saltwater taco [OP] Well-Known Member
    Brandon
    Telluride, CO
    2001 3.4 5spd 4x4 TRD
    softopper, sleeping platform
    So...I left my fog lights on today and killed the battery. My truck has had a little trouble starting when it's cold out. Anyways, I tried to push start it by rolling it down the hill, popping the clutch, etc., with no luck, but after several attempts and ending up at the bottom of the hill in my neighborhood I gave up on trying to start it. I tried it in first and second gear. Is it possible to push start these trucks? (2nd gen, 4cyl, 5spd) Isn't that one of the main reasons to have a standard? Or do I have bigger problems?
  2. Feb 3, 2013 at 12:03 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    ignition on? 2nd or 3rd gear works best.
  3. Feb 3, 2013 at 12:06 AM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Maybe batt so dead no fuel pump action. How long did it sit for?
  4. Feb 3, 2013 at 12:09 AM
    saltwater taco
    Brandon
    Telluride, CO
    Yea, ignition on. Though, the cab lights weren't dim, they were completely off. Connections to the battery were good. Wouldn't have thought about 3rd. I've done it in a Samuri before and it was so simple. Does the switch depressed by the clutch have anything to do with it? Only sat for ~8hrs.
  5. Feb 3, 2013 at 12:19 AM
    jdshockman
    jdshockman Well-Known Member
    juan
    ZIRIMICUARO,MICHOACAN,MEXICO
    09 4x4 TRD
    stock
    same thing happened to me one night, i popped the clutch in reverse and turned on fine.
  6. Feb 3, 2013 at 12:31 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    I'm surprised it worked on yours.
    It is normally impossible to push start a modern EFI engine.
    The fuel pump has to run and feed fuel to the rail.
    The ECU has to boot up and operate the ignition....
    That is not going to happen in a couple of seconds like it used to with mechanical ignitions and fuel pumps... it doesn't take much left in the battery to initiate a usable spark in one of those.
    If the cab lights aren't even coming on, there's not enough to boot up the ECU and operate the ignition or fuel pump.
  7. Feb 3, 2013 at 12:34 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Also, now that you've completely dumped that battery, it will fail much sooner than normal... if it even recovers from this instance.
    Deep cycling a normal battery can kill as much as 20% of the battery's capacity.
    If that battery is more than a year or two old, save yourself the headache of coming out one morning to a dead battery and just replace it today.
  8. Feb 3, 2013 at 12:37 AM
    m3zy6
    m3zy6 Well-Known Member
    Reno, NV
    '17 TRDSport AC 6spd 4x4
    Interesting, I've never had the need to push start a Tacoma, but I've push started many EFI bikes and never had an issue.
  9. Feb 3, 2013 at 12:47 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Dirtbikes or street?
    The Kawasaki Vulcan is a double zinger... the clutch is designed to slip if the wheel is spinning faster than the engine so a moron rider doesn't lock up his rear wheel by downshifting too soon, and add that to the ECU and fuel pump.
    The Vulcan ECU is very voltage-sensitive. It'll give you a warning that the battery is going... you'll start it, it'll run for a few seconds, then die, and when you check, your clock and trip odometer are reset.
    It might go for another week before the battery won't start, or it might be two more trips.
  10. Feb 3, 2013 at 12:54 AM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Used to be able to push start both my '98 Civic and my '02 F-150, both 5 speeds and EFI. Are these not modern enough? :confused:
  11. Feb 3, 2013 at 1:06 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    With the battery so dead that it wouldn't light the cab lights like the OP indicated?
    And the '02 is 10 years old now ;)
  12. Feb 3, 2013 at 1:10 AM
    kirkofwimbo
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    The 2nd gen Taco is almost 9. Don't remember if I had lights or not
  13. Feb 3, 2013 at 1:11 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    You had to have enough to run the fuel pump and boot the ECU.
  14. Feb 3, 2013 at 1:17 AM
    kirkofwimbo
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    I'd suggest you edit your original post as it is clearly not "normally impossible" to push start and EFI engine
  15. Feb 3, 2013 at 7:40 AM
    saltwater taco
    Brandon
    Telluride, CO
    Thanks guys, I can always count on TW! That makes sense about needing a little bit of power. Looks like I'll be buying a new battery, or at least having it tested. Maybe now I'll be motivated to wire my fog lights through the ecu so that they go off with the headlights...
  16. Feb 3, 2013 at 7:52 AM
    jandrews
    '09 FourDubDee TRD OR
    Jumper cables are cheap dude.
  17. Feb 3, 2013 at 12:56 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    If you're looking for an easy "fog lights any time" that'll allow the fogs to run without the headlights, just connect the switched lead to the relay to the ACC buss instead of the BAT buss.
    At least then, the fogs will shut off with the ignition.
    If you want them available with high or low beam, then tie it to the taillights.
  18. Feb 3, 2013 at 1:07 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    does clutch-start button have anything to do with this?
  19. Feb 3, 2013 at 1:32 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Nope. Not necessary to do anything with the button. I've bomb started mine a few times just for "bowel movements and laughter", and it works fine if there is at least minimal battery power.
    As said, the bomb start attempts did not work because the battery was stone dead and did not even power the ECM and fuel pump, or the field winding in the alternator for it to start producing any power.
  20. Feb 3, 2013 at 1:41 PM
    92dlxman
    Kevin
    Visalia, CA
    lol "bomb starts"? "bowel movements and laughter"? im gunna borrow those if thats ok
