Push Start Ignition Button
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacochoco, Jan 21, 2020.
  1. Jan 21, 2020 at 7:58 AM
    tacochoco
    tacochoco [OP] Member
    Hi TW! I just purchased a 2002 Taco yesterday and ready to get started working on this. One of the first things i wanted to do is install a push button along with remote start/alarm. Have you done this to your 1st gen tacoma? How is the experience getting it installed? Do you have a recommendation of a kit?
    Amazon has this kit that has it all that I've looking at so far.
    https://www.amazon.com/dp/B00IF1N314/ref=emc_b_5_t
    Also curious if we I could hook a TRD button to this kit. I haven't seen much around this and once I get started, I would probably do a write up on how I installed it.
    Any help would be appreciated and pictures of where you position the button!
  2. Jan 21, 2020 at 8:09 AM
    e.deCastro
    e.deCastro Well-Known Member
    Eric
    San Diego
    '01 S-Runner original owner
    Exterior TRD 5 Piece body kit Grillecraft grill DDM Tuning HID retrofit Custom etched Lexus HID Projectors Custom two-tone pin stripe by Jprints Chrome Rocker panels Wheels/ brakes 99 Lexus RX300 OEM wheels converted to 3 piece by ChamorroBoy86 Cadillac ATS Brembo 4 piston calipers Cadillac CTS-V Ceramic Brake pads Mitsubishi EVO IV 12.6” rotors provided by BR Autoworks modified by ChamorroBoy86 Subaru WRX STI Stoptech Stainless Steel brake lines Suspension Custom FBSS air suspension Accu-Rate manifold Dual 444c Viair compressors Accuair Chrome tank Custom Polished Hardlines Streetacos weld on c-notch Custom front shock mounts Custom airbag brackets Streetacos ball joint flip kit Engine TRD supercharger URD 2.2” Supercharger Pulley 312cc NA 2JZ Supra fuel injectors JBA Ti Ceramic Headers Spectre Carb Legal CAI LCE Pro Clutch LCE lightened flywheel 16” electric fan HPS silicone radiator hoses Yellow Top Optima battery Custom Battery tie down Universal oil catch can Denso 105 amp alternator AEM 320 LPH Fuel Pump Interior 02 Lexus SC430 trispoke woodgrain Steering wheel Japanese Rose Wood dash kit Authentic JDM Tsurikawa Nishijin Sakura Gold Black (heart version) Authentic JDM Suichuuka shift knob Authentic Junction Produce Fusa Authentic Junction Produce seat cushion Authentic Influenced VIP satin Pillow set Broadway mirror Custom Aloha print door jamb decals from BigHeadzdesigns LCE Short shift kit Electronics Soundstream VRCP-65 Double Din Multimedia entertainment center Alpine MRV-F545 4-channel amplifier Alpine MRD-M1005 monoblock amplifier NVX VCW124 12” Subwoofer MB Quart DSH216 6.5” 2-way component speakers Black Vue 650S Front and Rear Dash Camera AEM boost gauge AEM Uego wideband O2 controller URD Mass Air Flow Fuel and Timing calibrator
    the only thing I can see being a problem is not having a physical key. most new cars have a hidden key in the fob. my truck the drivers side door actuator is going bad after 18 years. and when it goes out completely I will need a key to unlock the door (which already is happening) one way around that is install aftermarket door actuators. but still doesn't address the malfunctioning door actuator. i have contemplated this for awhile. my fail safe will be what I did in highschool is keep a spare key in my wallet just incase.
  3. Jan 21, 2020 at 8:14 AM
    tacochoco
    I had that thought as well as I was just going to keep the actual key on the keychain along with the aftermarket fob.
  4. Jan 21, 2020 at 8:19 AM
    e.deCastro
    Eric
    San Diego
    i'm a minimalist when it comes to my key's. just my truck key, alarm fob and my tonneau cover key. i don't even like key chains on my keys. I don't even carry a house key just my garage door opener. yes we had a power outage once and I was locked out. but I rather be locked out at home then locked out of my truck esp if i'm out of town.
    but as far as alarm install it's not hard as long as you have a meter and wiring diagram. i didn't do my truck alarm, my buiddy did it but I did all the rest of my cars. I have had remote start on all my cars but living in socal, I have not needed to use it. when i lived in VA yes everyday i used it.
  5. Jan 21, 2020 at 8:28 AM
    tacochoco
    I don't carry much either. I'm use to have having a push start button on my others cars and my buddy has changed his '17 tundra from a key to push button but it cost him $1500 which is a not a bit outrageous at all (sarcasm). But if you know how to read wire diagram and match them to the alarm diagram. Should be clip and play. the push start button feature is something I really want in the truck.
  6. Jan 21, 2020 at 8:32 AM
    e.deCastro
    Eric
    San Diego
    i feel you. despite my arguments for not doing it, I will most likely end up doing it myself. I have a viper ESP 550 in my truck now but never use my alarm since I don't park it outside and the only time i take it out of the garage is for car shows. I just want a good module. not some flyby night company. I already disengaged my clutch so I don't need to step on my clutch to start (for remote start) but I will look for a non remote start version.
  7. Jan 21, 2020 at 12:41 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    We have gone Full Circle back to push button starters
    Maybe the push button will move to the floor so you can use your foot??
    Yes indeed toggle switch for the ignition and Push button
    RedManRocket likes this.
  8. Jan 22, 2020 at 2:55 AM
    Indy
    Indy Master of all I survey.
    Read the reviews.
    It looks like a rip off of a system I used 4 or 5 years ago, made by digital guard dog. It was more expensive than that one. I still have it in the garage somewhere.
    They're a little more complicated to install than an alarm, took a bit longer to get set up as well.
  9. Jan 22, 2020 at 6:44 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    I'd rather they move the dimmer switch back to the floor. Even after all these years, I still have trouble getting my foot up to the steering column to dim my lights. :rimshot:
    Wyoming09[QUOTED] and det107 like this.
