Push start question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mmelaney, Jan 24, 2016.
  1. Jan 24, 2016 at 10:29 AM
    Mmelaney
    Mmelaney [OP] Well-Known Member
    Waynesboro, GA
    2016 TRD Sport DCLB
    Here's a question. If I go out on a cold day to start my truck and warm it up what stops someone from jumping in and driving off. You can't lock the doors while it's running and the truck doesn't turn off after a certain period of time without the key fob in the truck.
    If someone jumps in and drives off the only limitation to how far they can get is how much gas is in the tank.
    Am I wrong? (Please say yes)
  2. Jan 24, 2016 at 10:38 AM
    Mmelaney
    Waynesboro, GA
    2016 TRD Sport DCLB
    From what I can tell the only limitation is if the ever shut it down they can't restart it.
    Bigger question is why can't you lock the doors while it's running.
  3. Jan 24, 2016 at 10:45 AM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    I'd like to lock mine also... when it's -40 it takes a few minutes to warm up enough to be able to see thru the windshield..
  4. Jan 24, 2016 at 1:15 PM
    gsxxr
    gsxxr Well-Known Member
    2016 tacoma trd sport
    3" lift, goodyear wrangler duratracs 285/70r17, k&n filter, bakflip vp tonneau and tint.
    Well my truck locks when running and I leave it with the key. It also turn off after 20 minutes.
    I leave mine running every morning and lock nit when bi go get coffee.
  5. Jan 24, 2016 at 2:03 PM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    Remote start, lock with manual locks, lock with key, buy non-push start model
    We just went through this the other day
  6. Jan 24, 2016 at 4:19 PM
    over60
    Muskoka, Ontario
    How do you do that..???? Do you take the Key from the fob with you..??:help:
  7. Jan 24, 2016 at 5:24 PM
    Mmelaney
    Waynesboro, GA
    2016 TRD Sport DCLB
    I wonder if it's different by model.
  8. Jan 24, 2016 at 5:27 PM
    spp
    spp OC, Kalifornia
    OC California
    Take the key out of the fob and lock it from the outside with the fob on the outside with you should work.
  9. Jan 24, 2016 at 5:45 PM
    over60
    Muskoka, Ontario
    HuH...????
  10. Jan 24, 2016 at 5:48 PM
    gsxxr
    My fob and key never leave my pocket. I get out with it running and hit the sensor. It beeps for a bit but then shuts up
  11. Jan 24, 2016 at 5:50 PM
    over60
    Muskoka, Ontario
    Do you mean by "I hit the sensor"...as I used the fob to lock it..??
  12. Jan 24, 2016 at 5:52 PM
    Eagle keeper
    Eagle keeper Well-Known Member
    Va. Beach
    2011 dcsb
    I have an aftermarket setup. If you press on the brake to put it in gear which you have to do it shuts the engine down. Key must be in ignition...... Maybe oem works the same ?
  13. Jan 24, 2016 at 5:55 PM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    If u start the truck and leave the fob nearby on your counter lets say, and someone drives off will the truck sense that the fob is not close and shutdown?
    It does in my moms venza, she will start it set the fob in the kitchen approx 10-15 feet from car. If she forgets the fob the venza shuts down about 80feet from the house
  14. Jan 24, 2016 at 6:00 PM
    Aussiek2000
    2016 Offroad AC
    No that doesn't work. If the fob battery died going down the highway, Toyota would be in big trouble
  15. Jan 24, 2016 at 6:38 PM
    Broccoli
    Airdrie Alberta
    I was told yesterday when i bought the truck if the fob battery ever died the fob must be very close to the pts in order to start so the truck can be started with a dead fob. Maybe i just dont understand
  16. Jan 24, 2016 at 6:53 PM
    over60
    Muskoka, Ontario
    That is totally correct, but has F-all to do with this thread..!!
  17. Jan 24, 2016 at 6:54 PM
    over60
    Muskoka, Ontario
  18. Jan 24, 2016 at 7:12 PM
    Broccoli
    Airdrie Alberta
    The thread is about starting your truck and having it stolen/locking the doors. From my understanding if the fob is not in the truck and someone drives off, the truck will die...
    BMWags likes this.
  19. Jan 24, 2016 at 7:18 PM
    over60
    Muskoka, Ontario
    Where did you get that info...??
  20. Jan 24, 2016 at 7:21 PM
    Broccoli
    Airdrie Alberta
    From my family members brand new venza that uses the same pts system.
