pushing the limits of tire fitment, what are my options?
Discussion in 'Wheels & Tires' started by stunt man hans, Jun 14, 2011.
  1. Jun 15, 2011 at 10:18 AM
    #41
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  2. Jun 15, 2011 at 10:43 AM
    #42
    stunt man hans
    stunt man hans [OP] DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    yes he did didn't he! don't get me wrong thats ideal i would not mind that except i don't know any one who could weld for me down here in south jersey after i modified it though. this has to be cut and boxed in right? i could cut but to have some one weld a 1,200 dollar bumper seems sort of strange to me. a 33 inch tire would be standard for most if not all 3 inch lifts maybe relentless can hook me up with something either way i will keep you guy's posted this is all going to get real interesting real fast! haha there is now literally a shit load of stuff happening to my truck in a very short period of time. once again thanks for all the help guy's:)
  3. Jun 15, 2011 at 11:06 PM
    #43
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Forget about CVs, if you lift the front 4" you're downtravel will be gone. Your front end will ride like a skateboard in the rough stuff, or even just cracks on the pavement.
  4. Jun 15, 2011 at 11:37 PM
    #44
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    pro comp says its a 3 inch kit i have heard more than one guy say that they got more though. trust me i'm hoping that it does not go above three for multiple reasons. the kit is getting professionally installed by a reputable 4x4 shop in central jersey so i'm sure they will do a good job i hope. should i do a shackle flip when the guy;s sre in there as well if so which one would be the best. i'm not a high speed off roader if that helps.
  5. Jun 16, 2011 at 7:17 AM
    #45
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    i thought all pro has one? oh thats a ubolt flip:facepalm:
  6. Jun 16, 2011 at 11:54 AM
    #46
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    all pro sell the timbren kit with the flip kit so its everything included. would this be the best way to go for my pro comp lift kit? i think the all pro flip and bump stop kit is like 240$
  7. Jun 16, 2011 at 12:01 PM
    #47
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I just bought Daystars there about 50 bucks shipped. I think 240 is ridiculous for a flip kit and bumps unless your doing are bumps.
  8. Jun 16, 2011 at 12:04 PM
    #48
    JLee
    Jerry
    Grass valley CA
    Yep there about 5" long
  9. Jun 16, 2011 at 12:05 PM
    #49
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    ok i will check into that so basically i would be doing all pros u-bolt flip then buying bump stops on my own right. what bump stop would work best for up travel and is there any fabrication involved when it comes time to instal?
  10. Jun 16, 2011 at 12:08 PM
    #50
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    once again its a 3 inch pro comp lift so i would imagine that a 5 inch bump stop would really impede me being able to stuff the rears. seems almost counter productive doesn't it? it makes me wonder what application the timbrens where designed for. seems like they are more for the high speed desert guy's who are looking for air lol.
  11. Jun 16, 2011 at 12:14 PM
    #51
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    the timbrens actually compress to stock height. those jaring hard hits also become much smoother
  12. Jun 16, 2011 at 12:14 PM
    #52
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    they dont... 1/8" is about it...or .3 degrees on the cv angle
  13. Jun 16, 2011 at 12:21 PM
    #53
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    so you are saying go for the timbrens? or go for a different set-up at this point 250 is a drop in the bucket for something that can have a negative impact on the ride. if the timbrens smooth things out thats the way i want to go then. and the diff drop was recomended to me pro comp they said it was nessary to do when installing this lift. idk about it making much of a difference all i know is i don't want to be having issues with my cv boots tearing constantly or any other hard or undue stress of the front diff if i can help it.
  14. Jun 16, 2011 at 12:28 PM
    #54
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i've had nothing but good things to say about them. my truck gets a very versitile use out of them. when you have a heavy load in the bed or tow a trailer with a higher toung weight, the the timbrens are tall enough to add a little extra support to help your springs out. however they are still soft enough to allow full compression of your rear suspension when wheeling. and lastly, they are very good at slowing your suspension down on a jump or similar action than the stock rubber ones or aftermarket poly ones which jar you a lot more. i'd ridden in trucks with all three types of bump stops before buying, and chose the timbrens as a result
  15. Jun 16, 2011 at 12:35 PM
    #55
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    what? i know there are inherent downfalls to lifting truck. it changes the geometry of the truck completely and there for you are at the mercy of a host of drive train anomalies and problems. here is what the guy at pro comp or 4wheelparts told me. he said that toyota executives and engineers where present through out the entire process when they developed and tested the pro comp suspension lifts for the second generation tacomas. he said it never would have been allowed to be produced if it caused any problems. that sounded like a line to me so i did some looking around and toyota did in fact over see the development of the kit. they recommend a diff drop so i ordered the one they sold me and its going in it could be anything idk i'm just using the recommended parts.
  16. Jun 16, 2011 at 12:38 PM
    #56
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    cool then that sounds like it's all good stuff man thanks for the help reps to you:D lol i just got the last high clearance ifs skid they had delivered today i ordered the thing like over a week ago lol. i'm going to have to choose expedited shipping so that they get here in time for next friday when the lift is installed.
  17. Jun 16, 2011 at 12:42 PM
    #57
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    you'll like the skid, expecially when you compare it to stock. i got one about 6 months ago and have since put it through it's paces
  18. Jun 16, 2011 at 12:46 PM
    #58
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    lol yeah it looks like it's about a 1/4 inch thick hardened steel! its bad ass to say the least. i was going to hold off installing it due to the diff drop going in i think it might need some type of billet spacer for it to mount up right. once again thanks again for the help on the flip kit i appreciate it alot man.
  19. Jun 16, 2011 at 12:54 PM
    #59
    Yoytoda
    Roland
    completely stock
    if thats the allpro its 7 gauge hot rolled steel...
    ato makes a real 1/4" steel plate way stronger
  20. Jun 16, 2011 at 1:12 PM
    #60
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    regardless it's way more beefy than the factory skid thats for sure. ato makes some wild stuff i was checking their website last night now i want a bumper i was considering the arb but i heard you have to cut and box the ends to fit 33's and thats not cool so then i was looking at relentless sent him two messages one on his website and one pm and i have not heard back from him yet. if erics bumper prices out to be equal to the arb once its all shot with line-x i will go for it today.
