Pushing truck in garage
Discussion in 'General Tacoma Talk' started by JustADriver, Sep 4, 2024.
  1. Sep 4, 2024 at 8:29 AM
    JustADriver
    JustADriver [OP] Well-Known Member
    1996 Tacoma 3.4L V6 2WD 5-lug AT 5VZ-FE
    When working on the engine bay in my garage, it's easier if I can back the truck up a few feet towards the door. If I have to leave the truck apart overnight, I'd like to be able to push it forward so I can close my garage door. It's a typical slope. Trying to push it forward I'm standing on my very sloped driveway just outside the garage, so I can't plant my feet.
    Any trick I don't know about? I don't want to install a concrete anchor, but I'll buy something else.
  2. Sep 4, 2024 at 8:54 AM
    Tacoma Mike
    Southern Maine
    Small Winch from harbor freight.
  3. Sep 4, 2024 at 9:12 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Is it mobile before the work? Back it into the garage so you don't have to push it back and forth.
    Edit: If its near a slope and you or anyone else is walking on the downhill side... do yourself a favor and chock all four wheels. It sounds silly, but many people have run themselves over when doing far less.
    soundman98 likes this.
  4. Sep 4, 2024 at 10:58 AM
    JustADriver
    That would have to be bolted to the concrete, right? Also I don't have any extra room in the end of the garage to mount it.
  5. Sep 4, 2024 at 11:06 AM
    JustADriver
    Backing it into the garage does sound like a good idea, but I get nervous turning my back to the open side too long, like facing away from restaurant doors.
    I'm thinking of somehow levering the rear tire to roll it forward slowly, resetting the chock as I go. I don't think a pry bar would work, but something.
  6. Sep 4, 2024 at 11:08 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
  7. Sep 4, 2024 at 11:11 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    what about something like this?
    Car Dolly 4 Pack, [Upgraded] Towallmark Car Dolly with Nylon Wheels, 6000lbs Load Bearing, Tire Wheel Dolly Vehicle with 360¡ã Rotational Wheel for Moving Cars, Trucks, Trailers, Motorcycles, Red https://www.amazon.com/dp/B0CTQ6W9J3
  8. Sep 4, 2024 at 11:14 AM
    545 Well-Known Member
    2015 Access Cab
    Roll one of the tires with your hands. I use that to move trailers that are stuck
    theesotericone likes this.
  9. Sep 4, 2024 at 11:14 AM
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
    Reverse onto some ramps before you start working.
    joeyv141 likes this.
  10. Sep 4, 2024 at 1:21 PM
    Tacoma Mike
    Southern Maine
    Nope, if you’re stupid and try to yank it up the hill then yes.
    3 or 4 feet across flat cement then you can put a 1 x 12 across the wall studs and quick mount to it. We did it in one garage and was no problem but, we had common sense.
    Just threw it out there.
    Knudsen likes this.
  11. Sep 4, 2024 at 6:47 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    there's also all-inclusive winches that are designed like come-along's, but without the physical effort.
    this one is rated to 2000 pounds, i don't know what the rolling load would be with a steep driveway(likely around 250-500 pounds?), but it's 12v powered, so you'd need a healthy 12v battery, or a running vehicle to use it this one runs off 120v, so you just need an anchor point, and an extension cord.
    https://www.amazon.com/WARN-885000-Corded-PullzAll-120V/dp/B0043OV0IA
    this one is only rated to 1,000 pounds, but runs off a cordless drill
    https://www.amazon.com/FITHOIST-Portable-Drill-Winch-Dragging/dp/B0CSFBHPW8/
    i will say, the come-along linked earlier has only about 8' of reach. i purchased one specifically to pull a tool box onto a trailer during a job change, and it didn't work because it needed to be re-set right at the point where the front of the tool box would be on the trailer, but the back would still be on the ramps yet--the absolute worst place to need to reset a load...
    i ended up borrowing a 20ft chain hoist from my neighbor to get the job done. but even my 500-ish pound tool box was an extreme arm workout..
    https://www.amazon.com/FITHOIST-Capacity-Warehouse-Automotive-Machinery/dp/B09KY2ZQZW/
  12. Apr 10, 2025 at 8:07 AM
    truckmike26
    truckmike26 New Member (2009)
    Toronto
    '21 DC TRD Off-Road, '94 Pickup (Hilux) V6/Auto 4WD
    I bolted this to my concrete floor with concrete lags to pull vehicles onto the four-post lift:
    https://www.dutton-lainson.com/proddetail.php?prod=11001
    I measured the pulling load with a force gauge pulling up my old truck (it weighs approx. 4,000 lbs.) and the peak was around 600 lbs., well shy of the 2,000 lbs. rating. A sturdy floor is key, though.
