Put 2 stroke in the Taco, no bueno, Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Konabomber420, Dec 6, 2017.
  1. Dec 6, 2017 at 10:57 AM
    Konabomber420
    Konabomber420 [OP] Member
    Ben
    Washington
    Sr5 v6
    6" Fabtech K&N intake, Full exhaust, grill, bull bar, nerfs, rhino lined bottom 8" of body, DVD, tint dadadadada...........secret missile pods, smoke screen
    Need some advice, here is the situation
    I put about 10 gallons of clean 2 stroke (50:1) in my 2006 Taco, 4.0L V-6 a few weeks ago. Yes, I know, this is not a real smart move, depending on who you ask, but this isn't the first time I've done this, actually. When I did this about 2 years ago, It ran fine for a while then when climbing the local Mtn pass she started bogging and sputtering a bit until I pulled it over and shut her down. She started right back up and took off, the following few days after that episode the truck did the sputter and die maybe 3 more times, but when I burned the remaining gas out of her, she ran like a top and no further issues.
    Fast forward to two weeks ago, I put some 2-stroke in her and pretty much expected the same or similar results as the last time I tried this. There was 1/2 tank of gas when I put the 10 gallons in. The truck smoked a bit for the first few days, and didn't run any better/worse. After about a week when the tank got below half, she started doing some light bogging on the HWY, but not to the point of pulling over and dying/shutting her off. A few days later I topped the tank off w/ high octane and injector cleaner in her to clean up the tank, figuring it would burn out the rest and be done w/it. The following week the truck has been sputtering and dying on me almost daily. It will be running fine then, suddenly just bog way down (when you give it gas it just losses RPMs and eventually dies) . I shut off the motor, wait a second, then she fires right back up and takes off no problem. The bogging/dying is pretty random, seems like it does it more on an incline which makes me think she has particulate/gunk in the tank. Ive swapped the plugs, and a few of the old ones def looked shitty and fouled, but this AM she bogged and died going up an incline w/ the new plugs. Im now thinking its time to pull the bed and clean the tank / swap the fuel pump/filter unit.
    ANy advice (besides don't put 2-stroke in her anymore) would be rad and appreciated.
    Thanks
    KB
    scottalot likes this.
  2. Dec 6, 2017 at 11:00 AM
    98tacoma27
    Ben
    Not Beech Creek
    Why run two stroke to begin with? This wasn't by accident?
    And yes to pull the tank, clean, and new filter.
  3. Dec 6, 2017 at 11:01 AM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Eh...why’d you do it?
    Never mind. Your username is a tell.
    DanoDavis, 14489, MtnMan307 and 16 others like this.
  4. Dec 6, 2017 at 11:02 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Possibly gummed up filter, might get away with running some seafoam through the gas tank.
    LABEL YOUR 2-Stroke cans BETTER!!!!
  5. Dec 6, 2017 at 11:04 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    ** Don't need to pull the bed to pull the tank
    DanoDavis and twotwentyswift like this.
  6. Dec 6, 2017 at 11:04 AM
    ChadsPride
    Sponsored by TacomaWorld.com
  7. Dec 6, 2017 at 11:05 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    I don’t understand why you’d put that in the tank in the first place?
  8. Dec 6, 2017 at 11:05 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Trying to be like the "cool" kids
    Black Taco, DanoDavis, DGXR and 5 others like this.
  9. Dec 6, 2017 at 11:07 AM
    Argo98
    Argo98 Well-Known Member
    Argo
    2017 Toyota Tacoma TRD-Sport 4x4
    Rough Country 3" spacer lift w/ shocks 285 KO2's wrapped around 16' ProComp Series 7069 Misc. bibbidybob lights
    I'm turd gen, however... This is quite interesting, thus I am subbed
    EatSleepTacos, Coot83, Nick17 and 3 others like this.
  10. Dec 6, 2017 at 11:08 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    No, this is not a cool mod. Not even for turds. Don't do it, leave now. lol
  11. Dec 6, 2017 at 11:10 AM
    SRQ_TACO16
    SRQ_TACO16 Well-Known Member
    David
    Sarasota, FL
    2008 Tacoma
    3rd gen SR5 wheels
    Two strokes are faster and weigh less? Makes sense to me.
  12. Dec 6, 2017 at 11:10 AM
    TREspalding
    TREspalding Well-Known Member
    The part that I don't comprehend is that you apparently did this on purpose?
    DanoDavis, cytocycle and outxider like this.
  13. Dec 6, 2017 at 11:10 AM
    JTS2016TACO
    JTS2016TACO Well-Known Member
    Jamie
    Chandler, AZ
    2016 MGM 4x4 TRD Off Road Double Cab Short Bed
    See my build thread in my signature
  14. Dec 6, 2017 at 11:12 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    injectors may be clogged
  15. Dec 6, 2017 at 11:13 AM
    TREspalding
    TXpro4X4, jv_74, stealthmode and 3 others like this.
  16. Dec 6, 2017 at 11:14 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    DanoDavis, smw62891, QChawks and 3 others like this.
  17. Dec 6, 2017 at 11:14 AM
    Argo98
    Argo
    NO!! I wanna seeeeee whyyyyyyyy, must know why!:rofl::rofl::rofl:
  18. Dec 6, 2017 at 11:15 AM
    JerryTaco
    JerryTaco Well-Known Member
    Put diesel in it this time, will reverse the effect of the 2 stroke and you'll be good to go.
  19. Dec 6, 2017 at 11:16 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    My truck was smoking and then turned off on me lol. There was supposed to great BRAAAP, where is earth shattering BRAAAP?!?!?!
    TacoFMS likes this.
  20. Dec 6, 2017 at 11:22 AM
    youcantseeme
    youcantseeme Well-Known Member
    E
    Colorado
    2015 SSM Taco TRD
    13 cupholders for beer. All the Weathertechs.
