Put a 3 inch lift/level need new brakes?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Healyj7, Aug 4, 2016.
  1. Aug 4, 2016 at 8:47 PM
    Healyj7
    Healyj7 [OP] 2010TRD Cape Cod
    Cape cod MA
    2010 Tacoma 4x4 crew cab...
    Led third brake light All bulbs changed to LED Blue... Bed cover Extra tie downs in bed Borla 3' aftermarket excuast Blacked out front grill Smoked front lights White turn/running lights Bed security Mod 2 inch front lift and level with bilstein front and rear shocks... 1 Inch wheel spacers BF Goodrich AT tires 270/75/17
    Put a 3 inch lift/level need new brakes? 2010 TRD sport with BF Goodrich at tires and one inch Spencer's feels like I have to brake hard should I upgrade and to what?
  2. Aug 4, 2016 at 8:52 PM
    Pigpen
    Dan
    Northwest Montana
    Time to replace your brake fluid - should be done every 3 years.
