Put a hole in rim
Discussion in '1st Gen. Tacomas (1995-2004)' started by oneguyonetaco, Jun 15, 2013.
  1. Jun 15, 2013 at 6:43 AM
    oneguyonetaco
    oneguyonetaco [OP] Member
    James
    Eden Prairie, MN
    01 Tacoma DLX
    Airaid Jr Intake w/ Filter. Electric Fan. Modified Stock Throttle Body Gasket. Royal Purple Oil. NGK Iridium Plugs. Grey Wire Mod.
    Went out last night for some late night mudding and had a fabulous time. This morning I woke up w/ a flat(Yay Me) . I inspected the flat and realized that the flat wasn't coming from the rubber but the rim itself. Some how a rock must have wedged between the front caliper and the rim and actually punctured a hole into the metal on the inside of rim. Now the tire is muddy and I have to leave to work this morning so cant fix it this min. I could get it welded right? Maybe bring it were they weld aluminum. I can post pics at a later today.
  2. Jun 15, 2013 at 6:49 AM
    WHPLSH3
    WHPLSH3 Fortified with horsepower-adding goodness...
    Vance
    Alberta
    Supercharged Spruce Mica 6spd 4x4
    Build thread coming soon!
    Ask around to see who repairs wheels in your area... they can fix stuff you can't even imagine! A wheel shop would be best because they won't let it go with a major out of balance issue- you may not be so lucky @ a regular welding shop
  3. Jun 15, 2013 at 7:10 AM
    Swimmerboy2112
    Swimmerboy2112 Well-Known Member
    Brian
    Walnutport, PA
    02 TRD V6 5 Speed X-Cab
    Borla exhaust, K&N intake, ARB bumper, 16x8 Konig Countersteer Offroad wheels, 20% Tint
    Find a local wheel repair shop. The one near me does some amazing stuff, you should see what they fix!
  4. Jun 15, 2013 at 11:35 AM
    oneguyonetaco
    James
    Eden Prairie, MN
    01 Tacoma DLX
    Yes, That's what I'm going to have to do. should be very simple now that I cleaned the tire and got a look at it(was smothered in mud). Its pretty small, small enough I drove home and notice a flat in the morning.
  5. Jun 15, 2013 at 11:36 AM
    oneguyonetaco
    James
    Eden Prairie, MN
    01 Tacoma DLX
    I actually glued it with some solder and seems to be holding for now!
  6. Jun 15, 2013 at 5:38 PM
    Seventh
    Seventh Insert witty title here
    Boston, MA
    2001 Reg Cab 4x4
    I wouldn't rely on that to hold very long.
