Put a lock on a 2011 Tacoma tailgate
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hawaiian Shrek, Apr 25, 2011.
  1. Apr 25, 2011 at 1:53 AM
    Hawaiian Shrek
    Hawaiian Shrek [OP] Member
    Kailua, HI
    11 PreRunner Sport
    Tube Steps, Bed Extender
    Hello Tacoma World,
    I am looking to get a Pace-Edwards retractable tonneau cover to make use of the bed for storage. Is there any way to put a lock on the tailgate itself? I looked at older model Tacomas and there lock is in the same location as the 2011 Tacomas backup camera.
    Please help.
    Thanks
  2. Apr 25, 2011 at 1:57 AM
    808matt
    808matt Well-Known Member
    hawaii
    15 crew cab
    pop a lock
  3. Apr 25, 2011 at 1:59 AM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    Yes there is a way. I have a Pop & Lock (PL5300) installed on my truck. It was an easy install. I'm not sure if it'll work for the 2011 tacoma so hopefully others will chime in
    Here is a youtube video http://www.youtube.com/watch?v=EbwtKOZYeHY
  4. Apr 25, 2011 at 5:43 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Dynolock....works with the key fob.
  5. Apr 25, 2011 at 6:26 AM
    Kauluwela
    Kauluwela Well-Known Member
    Dave
    Seattle, WA
    07 TACOMA DOUBLE CAB V6 6SPD TRD
    TOYTEC SPACER, OME 885'S, OME STRUTS, TOYTEC DIFF DROP KIT, TOYTEC CARRIER BEARING DROP KIT, LIGHT RACING UCA'S, DEALER TSB'S, OME AAL, OME SHOCKS, VISTA TOP, GROM AUDIO IPOD INTERFACE, ALL PRO EXTENDED BRAKE LINES, ALL PRO SLIDERS, FULL LIMO TINT, AMERICAN RACING MOJAVE WHEELS, WILD COUNTRY XTX 285-70-17, HI-LIFT, TOYTEC HI-LIFT SLIDER ADAPTER
    You have a backup camera on your Tacoma? Why?
  6. Apr 25, 2011 at 6:55 AM
    KPT
    09 Prerunner
    Because it comes standard on 2009+ Tacomas? :confused:
  7. Apr 25, 2011 at 7:02 AM
    darrmill
    darrmill Well-Known Member
    MA
    11 MGM DC SB
    Pop N Lock, Weathertechs, Viper remote starter, Intermittent wiper switch, devil horns, Access rollup tonneau, Wet Okoles, Rocky Mounts, EGR vent guards
    I installed a Pop A Lock tailgate handle in my 2011, no problem. No real difference based on the year.
  8. Apr 25, 2011 at 7:08 AM
    masshole taco
    masshole taco Well-Known Member
    Big Daddy
    Massachusetts
    2011 Tacoma Sport
    Fox 2.5 C/O's Fox 2.0 rear shocks Total Chaos UCA Trifecta Tonneau Cover K&N FIPK Sirius Satellite Radio Toyota OEM roof rack Wet Okole Seat Covers Homer Taco Custom Grill w/ M1 Mesh and Toyota Emblem
    x2
  9. Apr 25, 2011 at 7:10 AM
    Caduceus
    Caduceus Well-Known Member
    the Lowcountry
    09 DCSB TRD 4x4
    At least some Tacoma's. I know my TRD Sport does, I don't know if the base models do too.
  10. Apr 25, 2011 at 7:14 AM
    KPT
    09 Prerunner
    It comes on all SR5's I believe.
  11. Apr 25, 2011 at 7:14 AM
    TeXian
    TeXian Shifting Member
    Christian
    Texas
    2010 Pyrite Mica TRD Sport DC 4X4 6spd
    bone stock
    and it makes parallel parking a breeze.
  12. Apr 25, 2011 at 8:10 AM
    Capita
    I thought all the tacomas had them now, i may be wrong
  13. Apr 26, 2011 at 4:33 AM
    greyhound
    greyhound Member
    Mass.
    2011 V6 4X4 SR5
    Why would a tailgate lock be needed? Is theft of it a problem or is it something else?
  14. Apr 26, 2011 at 6:34 AM
    808matt
    hawaii
    15 crew cab
    you can steal a tailgate in like 5 seconds
  15. Apr 26, 2011 at 6:35 AM
    808matt
    hawaii
    15 crew cab
  16. Apr 29, 2011 at 1:12 AM
    infidel
    infidel Member
    Todd
    North Carolina
    2010 SR5 4x4
    Lock-N-Roll bed cover Nerf Bars
    Have you looked at the Roll-N-Lock retractable tonneau?
  17. Oct 7, 2011 at 7:29 PM
    DenisSeattle
    DenisSeattle Well-Known Member
    TRD Off Road
    I just installed the Pop& Lock PL5300 Tailgate Lock "with Camera" on my 2011 TRD Off-Road short bed. It went in smoothly, took about an hour to do. It works like a lock should -- bypassing the mechanism instead of blocking it. You can't muscle the handle open, like with the add-on remote power locks.
    Install is just like the YouTube video above, but with a few differences for the camera.
    You will re-use your existing camera, which takes some care and a tiny phillips screwdriver to transfer to your new handle.
    The instructions referred to "prying and slightly bending" a clip to remove the wiring plug from the camera. In my truck, at least, that doesn't apply. The plug has a spring-loaded metal piece that you have to squeeze hard to get it to release. Once it releases, the plug falls right off.
    The camera has tiny plastic studs that fit (or don't) into tiny holes that look just like 2 screw holes. I had to bore the holes slightly larger with the tip of a razor knife to get the pegs to go in. It's easy to get the camera mounted backward, so dry-fit this whole assembly before inserting screws.
    Other than that, I'd say, transfer the little red and black plastic clips before you put the handle into the tailgate, so you have more room to work. Lube them before you put the rods in.
    Be careful tightening the Torx screws. Note how loose they seemed when you took them out. As you'll see, they go into small nylon inserts, and it's incredibly easy to strip those out. (Hardware stores with bulk fasteners probably have steel and nylon replacements.)
    The handle looks like it has a lot of little gaps where moisture can get inside. This is not good if you live where they put de-icer the roads in winter. One could carefully apply a sealant to some of the openings, but not all. I expect to have to replace the handle in a few years; at that time I'll check the inside of the tailgate for rust.
  18. Oct 8, 2011 at 5:41 AM
    Chris135
    Chris135 Well-Known Member
    Regina,Sk
    2011 Tacoma DCLB SR5 TRD Sport
    Debadged Bilstein 5100 shocks in front OME 885 coils Icon 1.5"aal 16" fj cruiser Trd rims 285/75/16 duratrac tires 1.25" spidertrax wheelspacers (4) Tinted front windows Grillecraft upper grille Custom Trd boxside decals Allpro front bumper Piaa 510 fog lights Box mounted ammo can Rear diff breather BHLM Tinted front windows Rolltop tonneau cover Hand controls (for wheelchair users)
    ^^ nice write up. Any pictures of the gaps around the handle after installation?
  19. Oct 10, 2011 at 3:10 PM
    DenisSeattle
    TRD Off Road
    Thanks Chris135. Sorry, I didn't get daylight photos before I sewed up the patient. There's a small gap around the camera, but a much larger one around the plastic lever that moves when you lift the handle.
    If I had some adhesive plastic film, like floor protectant, I would have cut a square foot and laid it over the handle from the inside to keep the salt spray from spreading throughout the innards of the tailgate.
  20. Oct 11, 2011 at 5:33 AM
    Chris135
    Regina,Sk
    I see, I might have to consider this when I get a cover in the future. Not too keen on having open gaps but I guess I'll have to see what's out there. Sorry shrek for the detour in your thread.
