put a turbo or super charger on a 4 cyl?
Discussion in '4 Cylinder' started by Red_Taco33, Sep 22, 2013.
  1. Sep 22, 2013 at 6:51 PM
    Red_Taco33
    Red_Taco33 [OP] Well-Known Member
    Upstate New York
    2021 TRD Off-Road MT
    Would it be a waste? Is there even enough power to feed the super charger or turbo?
  2. Jan 2, 2017 at 5:55 PM
    tacoburrito
    tacoburrito Well-Known Member
    boston
    2013 regular cab
    5100s. eibach coils. 285/75/16 km2s. leer cap
  3. Jan 2, 2017 at 6:05 PM
    Clearwater Bill
    Billy
    Largo Florida
    What does that even mean? Either will work.
    Choice is based on how the vehicle will be used.
    The critical thing for engine safety, with either, is engine management and the tune.
  4. Jan 2, 2017 at 6:51 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    NAWS
    Clearwater Bill likes this.
  5. Jan 3, 2017 at 9:56 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    Its possible and it would add a bit of under hood complexity.
    URD makes a bolt up super charger system for the 2TR and has all the supporting components you will need.
    A turbo kit as far as I know is fabricated to your needs. I have yet to see a full bolt up kit for the 2TR including fuel and electronic upgrades.
    ChadsPride and tacoburrito like this.
  6. Jan 4, 2017 at 6:23 PM
    2.7taco
    Texas
    Just as an FYI when adding more air you will need additional fuel. The stock injectors are fine for about 230 horsepower. Some trucks can get more.
    There is a company that is selling new fuel injectors for the 2TR-FE that are built specifically for this engine. They go from stock replacement to radical. For more information PM me.
  7. Jan 8, 2017 at 10:01 PM
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    The 2tr uses the same block as a 3rz. Boost on my friend!! Crank and rods are drop forged, and the pistons are hypereutectic.
    ChadsPride likes this.
  8. Jan 9, 2017 at 6:45 AM
    2.7taco
    Texas
    Just remember block is the same but the pistons rings and wrist pins are completely different. The rings are 1.2mm if I remember correctly. If you have high mileage do a compression test. Also check fuel trims with a scangauge or something to that nature. If your trims are over 10% there is a problem that needs to be attended to first.
  9. Jan 9, 2017 at 7:28 AM
    tgear.shead
    tgear.shead Well-Known Member
    I have never understood this... if you wanted something more powerful, wouldn't it be smarter to start off with a 6-cyl?
  10. Jan 9, 2017 at 8:03 AM
    MrCrowntown
    Alyn
    Ky
    Why do you want to troll a thread that you have no intention of staying on topic with? I never understood this...
    Torspd, ManBeast, Large and 4 others like this.
  11. Jan 9, 2017 at 8:07 AM
    MrCrowntown
    Alyn
    Ky
    I would say you are definitely correct, but the OP Was a very basic question so it gets the short answer lol
    2.7taco[QUOTED] and ChadsPride like this.
  12. Jan 9, 2017 at 9:08 AM
    tgear.shead
    Why would you want to ruin a perfectly good engine when you could start with one that is more correctly matched to what the owner wants?
  13. Jan 9, 2017 at 9:16 AM
    2.7taco
    Texas
    Your always Debi Downer. Some people just want to mod things. Leave them to it.
    Large likes this.
  14. Jan 9, 2017 at 9:18 AM
    2.7taco
    Texas
    I was just responding to the other gentleman's post. All info so far has been very positive for boosting. I would not be surprised to see the OP running boost before years end. :burnrubber:
    MrCrowntown[QUOTED] likes this.
  15. Jan 9, 2017 at 9:19 AM
    2.7taco
    Texas
    Maybe the owner wants a turbo 2TR-FE.
    Large, tacoburrito and MrCrowntown like this.
  16. Jan 9, 2017 at 9:20 AM
    MrCrowntown
    Alyn
    Ky
    Because its the 4cyl section, and the description of the 4cyl reads:
    4 Cylinder
    Discussion for questions and issues specific to 4-cylinder Tacomas
    So now that being said, you are totally allowed to lay your opinion down wherever you are, but don't be condescending towards people who don't have your personal goals in mind.
    Large, 7r41lbr34k3r and BKill like this.
  17. Jan 9, 2017 at 9:21 AM
    MrCrowntown
    Alyn
    Ky
    This.
    It's what I will have by years end :burnrubber:
  18. Jan 27, 2017 at 11:28 AM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    Just put one of these on the back and be done with it.
    MrCrowntown likes this.
  19. Jan 27, 2017 at 11:54 AM
    MrCrowntown
    Alyn
    Ky
    Is that the japanese sign for boost?!
    :dancingbacon:
    Nedrolls and ManBeast like this.
  20. Jan 27, 2017 at 12:10 PM
    Mitch76
    Mitch
    San Angelo, TX
    Slow Moving Vehicle. HAHA
    Nskcorona likes this.
