Put in new OEM fuel pump, fuel gauge stopped working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WPDAWG11, Nov 19, 2023.
  1. Nov 19, 2023 at 11:22 AM
    WPDAWG11
    WPDAWG11 [OP] Well-Known Member
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    The instrument cluster has always worked, and the fuel gauge always worked. I tried disconnecting battery, but that didn’t work. Is there a reset on the instrument cluster? Any help from you guys would be greatly appreciated. I know it’s a long shot.
  2. Nov 19, 2023 at 11:39 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    There is no reset, sounds like either something is disconnected or you have a faulty sending unit.
    Torspd, drizzoh and WPDAWG11[OP] like this.
  3. Nov 19, 2023 at 12:42 PM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    we just put a ground on the yellow and black wire off of the pump harness and it did nothing. But figured out the gauge cluster is functioning properly. Toyota parts house sending out faulty pump sending units is a possibility. Gonna email them, sucks I waited like a year and half to put it on, after ordering
  4. Nov 19, 2023 at 1:00 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I'll have to look at the wiring diagrams later, I can't remember what colors the 2 sending unit wires are.
  5. Nov 19, 2023 at 1:02 PM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    Appreciate that, the other smaller wire was orange. The two fatter wires I’m assuming are the actual power
  6. Nov 19, 2023 at 1:16 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    IIRC the orange wire is the signal wire for the gauge and the Yellow/Black is the sensor ground but I'm not 100% sure without looking.
  7. Nov 19, 2023 at 8:02 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yea at the fuel pump connector Pin 2 (Orange) is Fuel Level Sensor Signal and Pin 3 (Yellow/Black) is Fuel Level Sensor Ground, you can briefly short them together to see if the gauge goes to full. If it does but the gauge doesn't work with the pump plugged in you have a bad level sensor.
  8. Nov 20, 2023 at 8:25 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    It sucks but you're probably going to have to pull the tank back down and double check your work
    Torspd, WPDAWG11[OP] and TnShooter like this.
  9. Nov 20, 2023 at 9:21 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Been there, done that.
    I some how managed to get the sending unit float arm in a bind while putting the unit into the tank.
    Tank was reading FULL when got it back in. No way it was full. I drained it all out before I started.
    Of course, that's when they all fail. Just as soon as you fill up the tank.
    Wasn't on a Tacoma, but still a PITA.
  10. Nov 20, 2023 at 9:40 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Few years ago I got stuck with a Ford landscaping truck. Somebody drilled the crap out of the tank to steal the fuel. I installed a junkyard tank but the fuel level never worked correctly. I even tried 2 more different tanks, pulled everything down multiple times, checked all the wiring and float arm.. If i recall there was something about California tanks vs federal.. ugh. Never got it to work right.
    I've never even done a pump on a toyota lol. They rarely fail compared to other manufacturers
    TnShooter[QUOTED] likes this.
  11. Nov 21, 2023 at 2:56 AM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    Regular cabs prop the bed up . But yep you’re likely correct.
  12. Nov 21, 2023 at 3:00 AM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    I am wondering if toyotapartsdeal isn’t shipping out questionable over stock. Second part I’ve had issues with from them. Fml
  13. Nov 21, 2023 at 3:07 AM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    What sucks was my original pump was fine at 238k, but I had this one lying around since I bought it by mistake, ended up being another problem. Since I couldn’t return it I popped it in. And the damn gauge worked for a few days, so I tossed the old pump.
  14. Nov 21, 2023 at 4:27 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Your problem might be quite obvious once you open the tank and pull the unit back up.
    WPDAWG11[OP] likes this.
