Put my engine in water
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chris20, Apr 1, 2012.
  1. Apr 1, 2012 at 11:03 PM
    Chris20
    Chris20 [OP] Well-Known Member
    Pensacola,Florida
    2010 Tacoma Trd off-road
    Arb front bumper SAS swap all-pro rock sliders Warn winch
    Ill put up some pick tomorrow.
    Got a new altenator the old one was no good. Starter is good. But I need a new battery and need to take my truck to toyota and have it looked over.
    Now along with a Solid axel swap I decided i will be buying and installing a snorkel
  2. Apr 1, 2012 at 11:10 PM
    Rmesa1
    Rmesa1 Well-Known Member
    Sounds likevMud in the alternator to me it clogs he brushes and keeps it from charging. Ha explains the battery light. The battery probably drained out on the drive back. Clean out the old one so you will have a spare. If here was no water in the intake and he truck runs fine now I wouldn't waste the money on the trip to the dealership
  3. Apr 2, 2012 at 6:06 PM
    tocomapopo
    tocomapopo Tar Heel
    North Carolina
    05 Tacoma TRD Sport SR5
    Body lift, Suspension lift/leveling kit, Some Custom interior
    Not too long ago something similar happened to me. I didn't know get stuck but I did get plenty of water in the engine compartment. I thought it was the alternator too. Had it tested and the bearing was bad. Long story short after a lot if headache, I found the problem. The wire going from the fuse box to the alternator had a break in it cause by the water. Not sure how that happened but I ran another wire from the fuse to the alternator clip and problem solved.
  4. Apr 3, 2012 at 10:46 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    What's going on with this?
  5. Apr 3, 2012 at 10:08 PM
    Chris20
    Pensacola,Florida
    Replaced alternator and jumped it off. Runs and drives fine. I pulled all my interior out and cleaned it and i am going to put it all back in later.
  6. Apr 3, 2012 at 10:22 PM
    Chris20
    Pensacola,Florida
  7. Apr 3, 2012 at 10:25 PM
    Chris20
    Pensacola,Florida
    Im taking it in to Toyota Monday to get everything changed.
