Put Non-Energy Conserving Oil In...Any Issues?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by iJDub, May 16, 2013.
  1. May 16, 2013 at 8:37 PM
    iJDub
    iJDub [OP] Well-Known Member
    I switched to full synth at 120K miles and I saw the Mobile 1 5W-30 for high mileage. Not wanting oil leak issues I was going to try this for 1 cycle before switching to the regular one...
    Is there any problems or will it cause any issues? The only thing I can think of is that I may lose a bit of fuel efficiency but it shouldn't cause any wear or anything right?
  2. May 16, 2013 at 8:56 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Won't hurt anything.
    But even with the 120k, that's not a lot for a Toyota that has been properly cared for. You don't need the high mileage, and go by the weight indicated on the oil cap and the weight/temperature range in the manual.
    Use the recommended 5w30, 5w20, or 0w20 as indicated.
  3. May 26, 2013 at 8:17 PM
    iJDub
    I've lost about 2 mpg because of it.
