Put Put Put noise and white smoke!
Discussion in '1st Gen. Tacomas (1995-2004)' started by AsianAnts, Nov 28, 2011.
  1. Nov 28, 2011 at 8:32 AM
    AsianAnts
    AsianAnts [OP] just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    So my 97' 4 banger, pre-runner, stick shift .. started to crap out. the original motor in it ran about 250k miles before the 3rd cylinder died. Had the engine replaced with another 4banger that was said to have about 100k on it..
    anywho, it has been about 1 year since the replacement and now the problems are: white smoke out of the exhaust, engine making put put put or tick tick tick noise.. the more gas you give the faster the noise goes. seems as if it has no pressure/power. Put in first fear, let the clutch off slowly the truck will start to die. give it gas and it barely wants to move.. give it more gas and it moves just a tad bit.. as if it has no power? and the whole time, there is a cloud of smoke in my rear view mirror!
    :help:
  2. Nov 28, 2011 at 8:42 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'd start with the simple stuff, air and fuel delivery. I'm not familiar with the 1st Gens but do they have an in-line fuel filter, if so, was that replaced when you did the engine swap? Check the air filter, make sure mice haven't made a nest in your intake (doubtful but that stuff is cheap to check and you might get lucky)
    Does it burn oil between service intervals that you've noticed?
    Check the coolant, make sure it's all coolant and no oil has made it's way into the coolant.
  3. Nov 28, 2011 at 8:45 AM
    SargeSlapnuts
    SargeSlapnuts SargeSlapnuts
    Nick
    Pooler, Ga
    2003 taco TRD off road 4x4 dbl cab.
    255/85-16 BF goodrich km3's, modified trail gear Bumpers front and rear, 10k winch, ranch rear lift shackles, Rancho coilovers in the front, grey wire mod, aftermarket stereo, camper top on the back.
    valve seats / seals are good place to start if your burning oil and gettign ticking noises that corelate with engine rpm. check compression on cylinders. could be bottom end problem as well.
  4. Nov 28, 2011 at 8:45 AM
    SargeSlapnuts
    Nick
    Pooler, Ga
    valve seats / seals are good place to start if your burning oil and gettign ticking noises that coralate with engine rpm. check compression on cylinders. could be bottom end problem as well.
  5. Nov 28, 2011 at 8:47 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    white smoke and a miss is often a blown head gasket...look for contamination to the radiator and dipstick and for water out the tailpipe.
    Good luck...
  6. Nov 28, 2011 at 9:04 AM
    AsianAnts
    AnT
    while my brother was stranded at a gas station waiting for me to go scoop him up, a local mechanic mentioned it is a high chance that the gasket blew...
    white smoke and water out of the tailpipe is a sign of a blown gasket... and brother said that he heard and started to hear it since the night before! :eek:... the truck recently got an oil change
    what exactly am i looking for when i pull the dipstick?? water im assuming?
    i appreciate the replies! will definitely start looking at the other things mentioned.. especially that sneeky mice ;)
  7. Nov 28, 2011 at 9:18 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    your oil will look like chocolate milk if there is coolant in the oil.
  8. Nov 28, 2011 at 9:25 AM
    AsianAnts
    AnT
    well that was easy. cool! well not cool, but you get what im sayin'. :p
  9. Nov 28, 2011 at 9:27 AM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    glad you figured it out, and sorry for the bad news!
  10. Nov 28, 2011 at 9:29 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Sounds like a blown head gasket to me
  11. Nov 28, 2011 at 9:29 AM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    Another fun way is to remove the radiator cap. Then start the truck with the hood open. If it splashes out. Shoot it directly between the headlights.
  12. Nov 28, 2011 at 9:41 AM
    TacoMX
    Jonathan
    Deltona, Florida
    that statement makes me sad...lol...
    HG's suck, but your motor isn't trashed unless you drive too much on it and overheat the motor badly.
  13. Nov 28, 2011 at 9:46 AM
    AsianAnts
    AnT
    ohh no, i havent figured it out yet...
    when i said easy, i was referring to the fact that it is easy to tell if the oil was contaminated or not. I would have to wait until this weekend to find out if it is or not.. lol
  14. Dec 1, 2011 at 4:14 PM
    AsianAnts
    AnT
    what is the average cost for a repair like this??
    and how much do you think i can get out of the truck if i sold it? besides gasket problem the truck runs great! its a 97' and had another motor installed at around 250k miles.
  15. Dec 1, 2011 at 4:46 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    It's like a $50 gasket kit, seen some as low as $25 on ebay. There's a decent amount of labor so if you don't feel comfortable doing it call up a few shops and ask what the labor rate is if you buy the parts. That should save you the markup on the gaskets.
  16. Dec 1, 2011 at 4:49 PM
    AsianAnts
    AnT
    well was thinking maybe $2000obo for the condition it is in?
    nothing else is really mechanically wrong with it... i mean there are some cosmetic discrepancies but hey, its a 1997.
  17. Dec 1, 2011 at 6:35 PM
    TacoMX
    Jonathan
    Deltona, Florida
    dont sell it like it is. It will be anywhere between $500-$1000 in labor to do the gasket. The gasket itself is cheap.
    I say fix it and keep it, or fix it and sell it for a decent price.
  18. Dec 1, 2011 at 7:59 PM
    AsianAnts
    AnT
    got a friend who is interested and threw an offer of $1000 as is...hmmmmmmmmm
  19. Dec 1, 2011 at 8:54 PM
    lbrownin
    lbrownin Member
    Larry
    Pearl, Mississippi
    02 S-Runner
    Local shop quoted me $900to replace my HG. They had this bulb thingy they put in the radiator to check for combustion gases.
  20. Dec 7, 2011 at 9:31 PM
    AsianAnts
    AnT
    sold it to an old friend for $1500 as is.... hes a mechanic and he'll fix it up and use it for his mechanic shop
