Put Syn on my 1st Oil change, now want to change back to regular Oil ! ?!?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by moulin6801, Nov 28, 2010.
  1. Nov 28, 2010 at 10:01 AM
    moulin6801
    moulin6801 [OP] Well-Known Member
    Hey guys, I switch to Syn oil on my first oil change, and I was charged extra $38 for it. I am supposed to have FREE oil change for 2 years on my new 2010 TRD.
    It sucks, I may as well go to a lub place if I want to pay for it.. ( I don't change my own oil).
    My question is this. I want to actually use the Free oil change, and go back to regular oil. Will it be harmful for my engine???
    I am sure the TOYOTA dealer will say it is, since it will cut on their profit. But what do you all say!??
    Thanks
  2. Nov 28, 2010 at 10:08 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Ya, won't hurt a thing. After the 2 years are up its a very easy job to do yourself. Just don't drain the transmission fluid by accident. No joke, its happened alot.
  3. Nov 28, 2010 at 10:08 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    I've heard once you go full synthetic you can't go back...not from the dealer but from friends etc...
  4. Nov 28, 2010 at 10:13 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    ah haaaaaaaaa!
  5. Nov 28, 2010 at 10:35 AM
    sooner02r1
    sooner02r1 Well-Known Member
    It will be fine. These toyota V6s would probably run on tractor oil. I prefer Mobil 1 myself, and refuse to pay a bonehead to change it, it only takes about 15 minutes to do once you get your system down, it's really easy.
  6. Nov 28, 2010 at 10:43 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Go for it, no problems.
  7. Nov 28, 2010 at 11:04 AM
    joes06tacoma
    Joe
    Central Coast, CA
    I agree. I have had this exact experience with an older truck. Changed to synthetic, rear main started leaking after about 5K miles. Changed back to dino, no problems, no more leaks.
  8. Nov 28, 2010 at 11:11 AM
    kickers15l5
    kickers15l5 Member
    Kile
    Rogers, AR
    the dealer told me it had to be done at the dealership or it would void my waranty. is that true
  9. Nov 28, 2010 at 11:15 AM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    Did you really think switching to syntethic oil was going to be free of charge?
  10. Nov 28, 2010 at 11:16 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    No ...... you'll be fine.
  11. Nov 28, 2010 at 11:22 AM
    chacotaco
    chacotaco Well-Known Member
    Travis
    Albuquerque & Palo Alto
    2011 SSM TRD SPORT DCLB
    Black Snugtop XtraVision Sleep Deck.
    You need to use dino oil in the beginning becasue the piston rings need a little bit of friction to seat themselves properly. If that doesn't happen then you will have issues down the line.
    I started with dino, then went to Valvoline dura-blend for 4 years. Now I'm running Mobil 1 full synthetic.
  12. Nov 28, 2010 at 11:27 AM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    I had the same problem on my first oil change so I brought my own oil with me so I wouldn't pay stupid prices for synthetic at the dealership. Now I drop the truck off with the oil and they do all "servicing" and put the oil I choose in the truck without charging me 7 or 8 dollars a quart.
  13. Nov 28, 2010 at 11:32 AM
    hogeyphenogey
    hogeyphenogey Rotted frame = New Truck!
    Dave
    Chicopee, MA
    2015 TRD Off Road Crew Cab
    new truck... No mods yet!
    I'm pretty sure it's against the law to tell a customer they HAVE to go to the Dealership for routine maintenance. Keep ALL (I MEAN ALL) receipts of stuff done elsewhere or at home and you're ok. You must do ALL services listed in the maintenance schedule, or the manufacturer can void your warranty, but you cannot be told where to have the stuff done. But, if there IS an issue later, they will ask for proof of services to show proper maintenance. I've had portions of customers' vehicle warranties voided when they come in at 80k with no records of trans fluid changes and a new tranny is needed. If there's a question of what paperwork to keep- KEEP IT ALL! There's a "convenience factor" in going to the dealer- it's all right there, it's all OEM stuff, and sometimes they may find something to fix while the car is still covered. But, it's always more expensive. I've had customers deal with my place until the warranty ends just b/c we keep all records and such, and we're $5 more than Jiffy Lube :puke:while using OEM Filters and gaskets and such. But really- it's YOUR decision, not the dealers'.
  14. Nov 28, 2010 at 12:31 PM
    JKD
    JKD Well-Known Member
    There is really no reason you can't switch back and forth at will. Run non-synth for 10,000 miles and then switch to synthetic. No big deal. Run for another 10,000 and then switch back. No big deal.
    Engines will be cleaner on synthetic, yes. I've seen it. You might get some minor seal seeping switching a long-time non-synth engine to synthetic. The chance of developing a major leak or major problem switching back and forth is seriously exaggerated. The only engines I would even be concerned about that issue on would be very old engines (which means old, stiff seals) that already leak.
  15. Dec 5, 2010 at 10:37 AM
    southpier
    southpier Well-Known Member
    i just had my 2-011 V6 oil changed at the dealers @ 700 miles. he put in 5w-20w dino. the manual says 5w-30w. i want to believe he knows more than me, or am i getting boned?
  16. Dec 23, 2010 at 2:34 PM
    moulin6801
    Hey guys thanks for the replies! I will be switching to regular oil, since is free for the next few oil changes, later back to syn oil.
    Looking at Mobil 1 website, they state that is ok to switch back and forth, except old models...
    Cheers!
  17. Dec 23, 2010 at 5:54 PM
    smitty4853
    smitty4853 New Member
    South Carolina
    2011 PreRunner SR5 LB
    I don't think so. A lot of 5W-30's shear down to 20 weight in a short time. Most 20's are well built oils. Unless you drive like there's no tomorrow, don't lose any sleep over it.
  18. Dec 23, 2010 at 6:55 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2008 F-350 Powerstroke
    You want to switch back to dino because of the price??? You realize the selling price is also justified by a little longer oil mileage right? The dealerships will never reccommend going longer, and you know why.... but I change my synth every 6-7, depending on how busy I am. I also run a larger filter too... I believe its the 4Runner filter or something, forgot.
    Mobil 1 Full synth
  19. Dec 24, 2010 at 4:14 AM
    Potomac30
    Potomac30 Member
    SC
    2011 PreRunner
    I'm going to go with the conventional (dino) oil for the free oil changes for 25k miles and then I'm going to stay with dino for my 5k mile oil changes after that. I don't believe that synthetic oil is worth the money for a 5k mile oil change interval and I'm not going with extended drains due to warranty.
  20. Sep 29, 2011 at 5:01 PM
    Paulie
    Paulie Well-Known Member
    Paulie
    USA
    Tacoma
    Why? Amsoil will save you money.
