Putting 16" wheels on a TRD Sport
Discussion in 'Wheels & Tires' started by syphon, Jul 21, 2015.
  1. Jul 21, 2015 at 10:56 PM
    syphon
    syphon [OP] Member
    Seattle
    '14 TRD Sport Access Cab
    I bought a 2014 TRD Sport that came with the 17" wheels. While shopping for new aftermarket wheels, I've decided I like the look of 16" wheels a bit better, so I'll be "down sizing".
    I see lots of people mentioning issues with putting 16" wheels on a TRD Sport. Apparently the front brake calipers are slightly bigger than those on the TRD Off-Road. As you can imagine, this causes a lot of confusion, as people whose Tacos came with 16" wheels are quick to chime in that said aftermarket wheel does indeed fit their truck (while others do not).
    So, is there any authoritative information I can find on what might fit and what won't, or should I just remove 16" wheels from my shopping list? I see a few wheels where the manufacturer has definitely said they won't fit (M/T Classic 3) but I have my eye on some other wheels and I have no way of knowing if they'll fit unless I buy!
  2. Jul 21, 2015 at 11:10 PM
    mutilatedjak
    mutilatedjak n00b waffle
    WA
    11 DC SB TRD Sport 6spd
    BP-51s, Dakar leafs, ARB bumper, 4xinnovations rear HC, 3x trail camera, pure android, lightforce 170s, Dick Cepek 255 85s extreme terrain.
    I have a 2011 TRD Sport and I swapped to the 16in TRD offroad rims no problem. Those aftermarket wheels... I haven't the slightest clue.
  3. Jul 21, 2015 at 11:16 PM
    krob32
    krob32 Well-Known Member
    Kelly
    Sierra Vista, AZ / Asheville, NC
    2012 MGM TRD Sport DCLB
    WeatherTec Digi Liners, AVS Bugflector II, TRD FJ SE Anthracite Rims, BF Goodrich AT KO2 265/75/16, AVS In-Channel Wind Deflectors, Extang Solid Fold, Pop & Lock, Color Match Grill Emblem (Anthracite), Plasti Dip Emblems, Tacoma Bed Mat, Tacoma Door Sill Protectors, ToyTec Ultimate Lift Kit, ICON UCAs, Wheeler's Progressive AAL, Wet Okoles, Sockmonkey 3rd Brake Light Cover, LED Hood/Bed Lighting w/ OTRATTW Switches, Famous Fabrication Sliders, Sockmonkey TRD Bed Decal, Proven Design 4x4 Mudflaps, BenWA's Rear Power Sliding Window, Jasper Off Road 6" Reverse LED Pod, ImMrYo Rear View Mirror Bracket, GrillCraft w/ Black Mesh and color matched Land Cruiser Emblem, LED Tail Lights, Badge Removal and Vinyl TRD/Tacoma Stickers, Bullaculla Trailer Harness Relocation.
    I put 16 inch rims on mine within a week of driving off the lot. Never had a problem.
  4. Jul 21, 2015 at 11:45 PM
    syphon
    syphon [OP] Member
    Seattle
    It looks as if Toyota wheels (or TRD) are exempt from this. Perhaps they sized them to accommodate larger calipers.
    It's looking like I'll have to avoid 16" aftermarket wheels. There's no way to know if they will fit the brakes until after I've bought them!
  5. Jul 22, 2015 at 7:53 PM
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    Georgia
    Yes
    Would spacers remedy the situation?
  6. Jul 22, 2015 at 8:27 PM
    syphon
    syphon [OP] Member
    Seattle
    Maybe... I don't know! That's why I'm asking for any details on the problem! :)
    Judging from a quick glance at my (currently stock) front wheels, the calipers are pretty close to the inner diameter of the wheel, not necessarily the inner face. Changing the offset doesn't seem like it'll help... but I could be completely wrong!
  7. Jul 22, 2015 at 8:40 PM
    AKIRA 0NE
    AKIRA 0NE Instagram- FKN.AKIRA & ALOHA.DIVISION
    AKIRA
    Oahu, Hawaii
    '05 SSM DCSB pre-runner
    Debadged weathertechs mesh grill 6000K HIDs BHLM 2.5'' front 1.5'' rear stock snowflakes 2'' wheel spacers D ring hitch plasti-dipped interior pieces
    i have a trd tacoma and i have 15x8 pro comp wheels with a 3.75'' BS i had to run spacers to clear my caliper, i bought 2'' spacers to be safe but i think 1.5'' would be okay. just buy what rims you want and buy spacers or just shave caliper. i don't advise doing so but if it works it works hope i could help.
  8. Jul 22, 2015 at 9:12 PM
    HeliMedic
    HeliMedic Off-Grid Engineering
    Erie, CO
    Constant revolving door of Toyota vehicles
    The calipers (and rotors) are the same on both models. I have both and swap wheels whenever I feel like it. You'll be fine to run either wheel.
    Edit: You'll be fine to run either TRD wheel (off road or sport). As far as aftermarket wheels... It doesn't matter if you have an Off-Road model or Sport... some fit, some don't.
  9. Jul 23, 2015 at 1:21 AM
    krob32
    Kelly
    Several folks run non-TRD aftermarket 16 inch rims. Look for ones with similar offset and backspacing and you should be fine. I'm not sure of the limits for variance.
  10. Feb 3, 2016 at 6:03 AM
    kill em all
    kill em all Active Member
    steve
    New York
    Black 09 TRD Sport SR5
    Magnaflow catback exhaust.. Until I build my own!!, somewhat debagged (not finished), built my own custom bumper
    Did you ever figure anything out? Looking for the same answer now..
  11. Oct 16, 2017 at 11:27 PM
    flinky
    flinky Well-Known Member
    2017 Black Tacoma TRD Sport
    BUILD -Window tint back windows -Clear Tint front to reduce heat -Method NV's Matte Black 16" (reduced from stock 17") -Pro grille - Prinsu Roof Rack - 40" Light Bar Cut Out - Prinsu Top Rack - ARE canopy (windoor, sliding window, roof rack) - Prinsu Load panels - Baja Designs Sport Fog lights - 2 tepui awnings LIFT -BFG K02's 265/75/R16 -2" lift 2.0 Fox Coil Overs -2.5" lift 2.0 Fox w/ resi (mounted high/ shock stone guard) -Added extra leaf
  12. Oct 19, 2017 at 3:25 PM
    syphon
    syphon [OP] Member
    Seattle
    For what it's worth, I never found any authoritative info on this. The only response I've ever gotten is anecdotal "I bought X wheels for my Y truck and they fit!" which helps not-at-all. :(
    I plan on finally replacing my stock wheels this winter, and I'm just going to buy from Discount Tire or somewhere that allows me to fit the wheel before buying it.
  13. Nov 1, 2017 at 5:21 PM
    paramud
    paramud Well-Known Member
    So Cal
    2016 White Tacoma Sport DCLB 2WD
    FYI, I have a 2016 sport.
    I bought a set of 16in rims from a 2011 Tacoma. I just test fit them and they fit.
  14. Dec 29, 2017 at 7:32 AM
    xxtavixx
    xxtavixx Well-Known Member
    Jacksonville fl
    2018 6MT
    ARB rear locker OVtune Mobtown sliders Core-shifter short throw Trd bro-phony grill Caliraised bumper light bar Caliraised ditch lights Rigid ignite back up lights FN Five Star 16x8 Et0 255/85/16 cooper st maxx MesoJDM fuse box cover MesoJDM led interior lights Bilstein 6112 fronts Bilstein 5100 rears Headstrong 3 aal Toytec 3* shims Mesjodm dome and map lights Diode dynamix ss3 pro yellow Mobtown aluminum front skid 2lo mod SOS front recovery point
    I'm going through this right now...seems to be hit or miss.
  15. Dec 29, 2017 at 7:35 AM
    EatSleepTacos
    Randy
    Hampton Roads, VA
    4x4 2005 SR5 AC 6MT
    It depends on the wheel itself, just like you mentioned. Calipers are the same size on all second gens, so the difference is the wheel itself. The Toyota 16s and aftermarket 16s are designed to clear the calipers, whereas some aftermarket are not, making it a crapshoot.
  16. Dec 29, 2017 at 7:44 AM
    xxtavixx
    Jacksonville fl
    2018 6MT
    Well, I'm waiting for a 2018 to be delivered to me. I've got a set of Procomp 7089 that I know would fit a 2nd gen (based of pics I've seen on the interwebs, so it has to be truth!), but 4wheelparts is saying that they WILL NOT clear a third gen caliper for some reason.
    I had called to order the ATs for the 16" rims and stopped, deciding I would wait to mount the rim on the truck.
  17. Dec 29, 2017 at 7:47 AM
    EatSleepTacos
    Randy
    Hampton Roads, VA
    4x4 2005 SR5 AC 6MT
    Good call on waiting. I don’t see why it wouldn’t clear the third gen if it cleared the second gen. They probably don’t know and they’re just covering their ass.
  18. Jan 4, 2018 at 11:49 AM
    FarmerJB
    FarmerJB Well-Known Member
    john
    SF Bay area, California
    2017 Toyota Tacoma TRD Sport
    meso stage 2 tail lights, morimoto fogs, meso chrome deletes, trd pro shift knob, speaker upgrades, trd pro grill, fj steelies with bfg ko2's, black out emblems/removed decals, rear front seat spacers, k&n filters, bhlm with amber covers and meso side markers, GreenLane offroad front skid plate....more to come
    I had wondered about this myself. I guess I don't worry too much about clearance issues seeing as how if i bought some rims and they didn't clear, it would at the most be off ever so slightly, which would require machining the inside of the rims a tad. like 1/32" or 1/72", maybe not even that much. I have a friend with a 15' Regal Leblond lathe that i had him use to machine some rims i bought in the past that didn't go over my locking hubs in front of my '88 toyota 4wd. it took about an hour of work and then they fit perfect. Insides of rims would be just as easy to machine to fit. Of course it would void the warranty. But it would not affect the rim integrity, at least i highly doubt it would. anyways...thats one solution to that problem.
    On another note, I quickly got rid of the ugly ass 17" rims that came on my TRD sport....butt ugly if you ask me, and swapped them out for the 16" factory Tacoma anthracite alloy rims and LOVE them. 20170901_181216.jpg
  19. Jan 5, 2018 at 5:04 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    What Backspacing will fit?
  20. Feb 20, 2018 at 7:34 AM
    greasegunner
    greasegunner Active Member
    Florida
    2014 sport TRD
    Bump! Same question down here as well.
