Putting 2019 4Runner TRD Pro suspension on my Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MCT2T, Oct 15, 2019.
  1. Dec 31, 2019 at 11:51 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    How would you possibly have 3” more clearance? All you changed was a shock. For 3 inches of clearance you’d need to have a 6 inch increase in tire diameter.
    rlx02, Lt. Dangle and GreyBaldTaco like this.
  2. Dec 31, 2019 at 11:54 AM
    MCT2T
    MCT2T [OP] Member
    2017 Limited
    None yet. Exploring options
    Not sure. The tires are definitely bigger than the limited 18” stock tires. TRD Fox Shocks were bigger than the og shocks as well. They measured 2.75” higher than original stock. It’s noticeable on the road too. I’m sitting at a similar height to a f150.
  3. Dec 31, 2019 at 11:55 AM
    MCT2T
    MCT2T [OP] Member
    2017 Limited
    Wheels and shocks were changed.
  4. Dec 31, 2019 at 11:55 AM
    T4RFTMFW
    Wheels don’t effect tire diameter and shocks don’t increase ground clearance. Only tires do. You’re confusing lift with clearance, it seems.
  5. Dec 31, 2019 at 11:56 AM
    T4RFTMFW
    Even then, I don’t imagine you have a 3” lift with OEM shocks off a 4R Pro. Glad you enjoy the setup though, they look sharp.
  6. Dec 31, 2019 at 11:57 AM
    MCT2T
    MCT2T [OP] Member
    2017 Limited
    Ahh. Yes. 2 3/4 lift is what i have.
  7. Dec 31, 2019 at 11:58 AM
    MCT2T
    MCT2T [OP] Member
    2017 Limited
    It’s bad ass, really a huge upgrade compared to the limited original shocks and tires.
  8. Dec 31, 2019 at 11:59 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    The 4runner TRD Pro suspension lifts it 2 3/4 inches? What springs did they put in back?
    shakerhood likes this.
  9. Dec 31, 2019 at 12:03 PM
    MCT2T
    MCT2T [OP] Member
    2017 Limited
    3JOH22A and 13txtaco like this.
  10. Dec 31, 2019 at 12:04 PM
    MCT2T
    MCT2T [OP] Member
    2017 Limited
    That’s the rear.
  11. Dec 31, 2019 at 12:04 PM
    GreyBaldTaco
    2019 F150 5.0
    Yea but what spring did they put on?
  12. Dec 31, 2019 at 12:05 PM
    T4RFTMFW
    Stock leafs. If lifted, it’s a block, which isn’t installed either. So..
  13. Dec 31, 2019 at 12:05 PM
    GreyBaldTaco
    2019 F150 5.0
    Oh, he had said they out a spring in out back too.
  14. Dec 31, 2019 at 12:07 PM
    T4RFTMFW
    Doesn’t look like it. Has a 3+1 pack visible in that pic and no block installed. I don’t know many aftermarket lift packs with 3 main leafs.
    GreyBaldTaco likes this.
  15. Dec 31, 2019 at 12:08 PM
    #35
    MCT2T
    MCT2T [OP] Member
    2017 Limited
    they had to do something with the spring. I don’t remember what the installer did. He said it was necessary for the suspension to go in correctly.
    SooRunner likes this.
  16. Dec 31, 2019 at 4:54 PM
    #36
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    Seems my question caused more confusion. Did they just install the trd pro 4R suspension up front and it lifted 2 3/4”? Doesn’t seem right.
  17. Dec 31, 2019 at 5:03 PM
    #37
    T4RFTMFW
    Looks factory height to me, and OEM tires. Don’t see how it’s lifted at all in the pics posted.
    Thegenerik1 likes this.
  18. Dec 31, 2019 at 5:12 PM
    #38
    13txtaco
    13txtaco Well-Known Member
    Katy Texas
    2013 Tacoma 4x4
    If ever interested in trading for the Tacoma trd pro rear shock pm me
  19. Dec 31, 2019 at 5:12 PM
    #39
    yotahunter
    yotahunter Well-Known Member
    Central Iowa
    2020 TRD Pro
  20. Mar 20, 2020 at 7:05 PM
    #40
    Go2fast4u
    Go2fast4u Well-Known Member
    2018 Tacoma TRD Sport
    I was driving to pick up a set off of a pro 4r today when, in my infinite wisdom, decided to call Fox corp. They talked me out of it. Claiming everything is dialed in for 4r and wouldn't be optimal for Tacoma. Walked away from a set for $900 an hour and half into my drive there. UGH...Now about to pay $1,700 for a set off a Tacoma. Glad to see it worked out for you.
