putting alpine type R in
Discussion in 'Audio & Video' started by delrayrasta, Feb 18, 2011.
  1. Feb 18, 2011 at 10:13 AM
    delrayrasta
    delrayrasta [OP] Well-Known Member
    Paul
    Delray Beach, FL
    2011 4X4 TRD OFF ROAD
    pro comp stage II lift kit, retro projection HID headlight and fog, bullbar, bed cover and afe S dry intake.
    i am just replacing my speakers with type R's with the SPR-17S which would be 4 tweeters, 4 speakers and 4 crossover. my question is should i rewire everything with better quality cables or will it not make a difference?
    i'm still deciding on a head unit but most likely the ALPINE INA-W900BT with the HD module added and the KTP-445 to get perfect sound.
    i'm new at changing anything to do with audio, so would this be hard to install by myself or would i be better off getting it installed professionally.
  2. Feb 18, 2011 at 12:26 PM
    mrmumbels
    mrmumbels Well-Known Member
    Land O Lakes, fl
    09 prerunner
    none
    If you're just doing speakers and no amps then keep the original wires. Heads up though, the speakers will probably sound worse than the factory speakers until you get a new head unit.
  3. Feb 18, 2011 at 12:33 PM
    delrayrasta
    Paul
    Delray Beach, FL
    yea i figured that, the head unit will have to wait a bit so i can save up for something worthy.
    do you know if i need a spacer for those speakers, i'm trying to figure it out but i don't get it at all.
  4. Feb 18, 2011 at 12:37 PM
    mrmumbels
    Land O Lakes, fl
    09 prerunner
    none
    No, the spacers it comes with are deep enough. They worked on my 17refs and they're a tiny bit deeper than yours.
  5. Feb 18, 2011 at 12:38 PM
    delrayrasta
    Paul
    Delray Beach, FL
    so i don't need a kit to change it from the stock 6x9 to the 6.5?
  6. Feb 18, 2011 at 12:43 PM
    mrmumbels
    Land O Lakes, fl
    09 prerunner
    none
    The correct mounts were in my boxes but the website doesn't say it is included for yours so i'd do some research first.
  7. Feb 18, 2011 at 12:46 PM
    mrmumbels
    Land O Lakes, fl
    09 prerunner
    none
    actually it includes one spacer kit
    Easy Installation
    Installation is made fast and easy with a shallower mounting depth, and basket design. A 6"x8" mounting adapter plate is also included for fitment, so this solution is versatile to fit in many vehicles (Only Available on SPR-17S and SPR-13S). Choose from multiple models of both components and coaxials to fit the needs of your car
  8. Feb 18, 2011 at 12:48 PM
    delrayrasta
    Paul
    Delray Beach, FL
    thanks for the info very helpful. If it says 6x8 doesnt that mean it'll be too small seeing as tacoma double cab is all 6x9?
  9. Feb 18, 2011 at 12:52 PM
    mrmumbels
    Land O Lakes, fl
    09 prerunner
    none
    All I can say is that they fit on all 4 of my doors and they sent me the 6x8 also.
  10. Feb 18, 2011 at 12:54 PM
    mrmumbels
    Land O Lakes, fl
    09 prerunner
    none
    I just read that the stock speakers are actually 6x8s
  11. Feb 18, 2011 at 12:58 PM
    delrayrasta
    Paul
    Delray Beach, FL
    bhahahaha i feel lied to by toyota because they say there speakers are 6x9 and are really 6x8. thank you so much. i'll make sure to post pictures of the install when i get everything.
  12. Feb 19, 2011 at 9:12 AM
    delrayrasta
    Paul
    Delray Beach, FL
    i looked around and have found a few decent head units but the most annoying thing is that all i want is a double din with bluetooth built in and HD radio built in as well or as a module. so far i've found only these.
    Pioneer AVH-P4300DVD for under $500
    needs Bluetooth and HD radio module. No navi
    JVC KW-AVX830 for $414.80
    built in bluetooth, navi and would need a HD radio module
    Alpine INA-W900BT for $765.00 (this one is what i'm aiming for)
    it has bluetooth and navigation but i'd need to get something for HD radio
  13. Feb 19, 2011 at 9:16 AM
    mrmumbels
    Land O Lakes, fl
    09 prerunner
    none
  14. Feb 19, 2011 at 9:53 AM
    delrayrasta
    Paul
    Delray Beach, FL
    ohh i saw the new JVC KW-NT3HD and its perfect. jsut don't know if i want to spend $700+ on it.
