Putting bilstein 5100s on with 20"s
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 08tacoma4door, Feb 8, 2011.
  1. Feb 8, 2011 at 2:11 PM
    08tacoma4door
    08tacoma4door [OP] Active Member
    LA, Lafayette
    08 prerunner tss rims Debadged
    HIDs, TSS 20''s, Pioneer head unit in-dash screen, Tinted tails, De-badged, Foglight mod, Pioneer door speakers, 5100's and rear tsb.
    I am finally leveling my truck putting the 5100s on this weekend i am leaning toward the 1.75 and yes i have the rear tsb also after i do the install i have 275/55/20 nitto terra grapplers that will be put on my 20'' toyota tss rims. Is there anything els i need to go with the 5100s to install them and .85 setting or 1.75?
    Thanks i just want everything to go smoothly this weekend.
  2. Feb 8, 2011 at 2:16 PM
    lynyrd3
    lynyrd3 Strength ,Determination ,Merciless,Forever
    Bill
    Upstate New York ,Columbia County
    2008 SR5 AC SUPER WHITE V6 4x4
    Bilstein 6112s at top setting ,1/4" top plate spacer driver side,Total Chaos UCAs ,SS extended brake lines ,Rear 4 leaf Suspension TSB,Wheelers 2" AAL, Bilstein 5125s , SS extended brake lines rear , Toytec dif drop , Hayden high performance transmission fluid cooler,aFe pro dry filter , ,Powerstop drilled and slotted rotors.N-Fab light bar with 4 Hella OR lights , Devil horns by Andres ,Weathertecs floor protector, American Racing wheels Baja 17x8,4.5 BS , 285/70 Falken Wildpeaks AT/3W .Body Armor rear bumper . Extra D rings in bed ,Blue sea fuse block and 100amp breaker ,G-Tek Fab door sill protectors ,blacked out grille , painted pinch weld.Shorty antenna ,HVAC knob mod ,LED dome and map lights , Tri Fold bed cover ,UltraGauge ,Morimoto XB LED fog lights ,
    Do not forget to have a alignment done . My bilsteins are set at 1.75 with the TSB and I had to add a 1 1/2 AAL to raise up the rear .:rolleyes:
  3. Feb 8, 2011 at 2:17 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I think you need a spring compressor but that should be it for the install.:cool:
  4. Feb 8, 2011 at 2:20 PM
    08tacoma4door
    LA, Lafayette
    Getting the alignment when they put my tires on and my buddy has a spring compressor. so lynyrd you would recommend the .85 setting.
  5. Feb 8, 2011 at 2:28 PM
    lynyrd3
    Bill
    That is correct, unless you want more lift .It is very easy to install the AAL. I had no issues with Vibrations or alignment .
  6. Feb 8, 2011 at 2:36 PM
    Andy2010
    Andy2010 Well-Known Member
    Andy
    Bucks County, Pa
    2010 TRD Sport Mag Grey 4x4
    EGR inline vent visors, Trimmed front mud flaps, Hose clamp mod, AFE Pro-Dry S air filter, Bed mat off my '97, 5100's up front @1.75, Rear TSB, Tow package, Black TRD center caps, Weathertech Digitals, Wet Okole's in front
    It should be level at 1.75 with the rear TSB. Mine is.
  7. Feb 8, 2011 at 2:42 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    It all depends on your truck. I did 1.75 with no rear TSB and im level
  8. Feb 8, 2011 at 3:24 PM
    lynyrd3
    Bill
    I guess it depends on your truck . They are all a little different >:burnrubber:
  9. Feb 8, 2011 at 4:00 PM
    trd09
    trd09 Well-Known Member
    Chuck
    NW Ark
    17 TRD Pro 6AT
    2.5 with tsb and i'm level. nose high with 500# in the bed though
