putting chains on the front tires
Discussion in 'New Members' started by grayback, Dec 6, 2009.
  1. Dec 6, 2009 at 8:33 PM
    grayback
    grayback [OP] New Member
    KLAMATH FALLS, OR
    08 TACOMA STOCK
    9,000 MILE MARKER-WARN MOUNT
    I am a firm believer in the most traction going to the front for steering. Is there any modifications that can be made so my 08 Tacoma can use chains on the front?
    I use to chain up all 4's on my Landcruiser and 2 pre Tacoma pickups. They would go just about anywhere in the mud and snow.
  2. Dec 6, 2009 at 8:56 PM
    CtryBoyInMT
    CtryBoyInMT Lifetime Member
    United States of America
    2008 4WD V6 Access Manual TRD Off-Road
    Tinted windows, Rear locker anytime, Secondary filter delete, Parking light activated Fog lights, USA▪Spec Ipod adapter, Map light mod, Relocated 7-Blade, Warn Trans4mer Brushguard & winch, Tire chains, Homelink© installed in headliner, LED lighted 4x4 Switch, Defrost w/o A/C, Heated mirrors, Bilstein 5100's (1.75") & Rear TSB, 50w Reverse lights, Pratt & Whitney PT6A-68, Will this list ever end???
    I just run the stock tire size (265/70R16).
    I got this set from a stranger for $20 several years ago. I have these chains left over from my 97 Tacoma where there were absolutely no problems. I wish I had the model number, but it's rubbed off the storage case. They're Alpine Sports but not the Heavy duty ones. I probably wouldn't have bought them if I didn't get such a great deal and could dump them for the same price as I paid for them.
    The cable is ½". The links are just over 1/2" but not quite 5/8" so I believe the links are metric.
    I can just get a 3/8 drive extension in the gap and twist it ever so slightly. If that bump on the UCA wasn't there, it'd be home free.
    All I have were two yellow pages to drive up on and there is two inches of clearance. The rear side has a lot of room and I didn't even measure. Lock to lock wasn't even close to the frame either.
    Hope that helps. I think if your running bigger tires, you probably screwed.:(
  3. Dec 7, 2009 at 7:47 AM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    Welcome to TW.
  4. Dec 7, 2009 at 7:49 AM
    28ØØ3
    28ØØ3 Well-Known Member
    boss
    somewhere endlessly searching for ways to offend B
    08 DCLB SR5 4WD
    VatoZone Especial
    chains are for the bedroom
  5. Dec 7, 2009 at 7:54 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    hmm for winter tires i want to get 235/85-16s skinny for better contact patch. I bet since the tires are so skinny the chains would clear better.
