putting in wheel spacers, question for you guys
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ajw1986, Aug 27, 2013.
  1. Aug 27, 2013 at 8:58 AM
    ajw1986
    ajw1986 [OP] Well-Known Member
    Andrew
    Pitt Meadows, B.C.
    06 Money Pit
    I don't have a torque wrench, can I just snug everything on tight or do I absolutely need a torque wrench
  2. Aug 27, 2013 at 9:21 AM
    Nfurtado77
    Nfurtado77 Well-Known Member
    Torque wrench for sure not worth the risk of over torquing or under torquing. If you do buy a torque wrench besure to choose the medium range. If you need say 100ft lbs don't buy a wrench that is 50-100 it will be inaccurate instead buy a 50-200. You always any to be in the middle of minimum and maximum.
  3. Aug 27, 2013 at 9:22 AM
    ajw1986
    Andrew
    Pitt Meadows, B.C.
    06 Money Pit
    Do you know the average price of one?
  4. Aug 27, 2013 at 9:26 AM
    Nfurtado77
    It all depends on how good of quality you want you can buy one at canadian tire for $50-$100 but if you were to buy one from acklands it would be the $200 range.
  5. Aug 27, 2013 at 9:29 AM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Do you guys not have autozones there? Here you can rent it for 50.00 and take it back get your 50.00 back
  6. Aug 27, 2013 at 9:32 AM
    typeone
    typeone Well-Known Member
    central MA
    2013 TRD Off-Road 4x4 DCSB BLACK
    2.75" Rancho QuickLIFT Loaded coilovers, LR UCAs, Wheelers 1/4" poly top plate spacers, FBG diff drop, Toytec swaybar relocate, Wheelers 2" AAL, LRO 1" tapered blocks, RCD Bilstein 5100 rear shocks, OME carrier bearing drop, OEM roof rack, Access Literider tonneau, SCS Stealth 6 wheels, 285/70r17 Nitto Terra Grappler G2 tires
    i just installed spacers last night, i would definitely use a torque wrench and the red loctite. you want those spacers installed correctly.
    on wrench prices... Harbor Freight is the cheapest, on sale right now for $21USD BUT a crap shoot whether it will last or not. next in line is probably the Kobalt from Lowes at $60USD. Craftsman is the next step in price at about $90USD... if you want a good wrench that's accurate and lasts, i would budget at least $200.
  7. Aug 27, 2013 at 9:49 AM
    ajw1986
    Andrew
    Pitt Meadows, B.C.
    06 Money Pit
    Use loctite on the spacers? I'll get some on the way home
    We have Napa and Lordco, don't think auto zone is in canada. I'll probably just buy one from canadian tire.
  8. Aug 27, 2013 at 9:52 AM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    not meaning to thread jack or anything but i also saw the loctite comment. how would you remove it if theres loctite on it?
  9. Aug 27, 2013 at 9:54 AM
    Nfurtado77
  10. Aug 27, 2013 at 9:56 AM
    Nfurtado77
    no we don't have auto ones here I wouldn't but red locktight on, red for is permanent stuff they have other colors that arnt that strong.
  11. Aug 27, 2013 at 1:04 PM
    ajw1986
    Andrew
    Pitt Meadows, B.C.
    06 Money Pit
    I think the blue loctite is the non-permanent. Is it a must? I mean do you really think that spacer is gonna budge?
  12. Aug 28, 2013 at 4:51 AM
    typeone
    central MA
    red loctite comes with both the Spidertrax and G2 spacer kits. instructions say to use it so i did. just a dab. i dont want those spacer nuts going anywhere for a long, long time.
  13. Aug 28, 2013 at 6:02 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Just be aware that if you do use loctite, re-torquing is a waste of time. Even if you are just checking them.
