Putting my 2002 Tacoma in 4 wheel drive (question)
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaFrank, Oct 29, 2011.
  1. Oct 29, 2011 at 10:11 AM
    TacomaFrank
    TacomaFrank [OP] Active Member
    tacomafrank
    MD
    2002 Tacoma double cab (4 door) 4x4
    Hi: Whats the CORRECT way to put your 2002 Tacoma (Automatic transmission) into 4 wheel drive.
    1. Do I press the 4WD button (which is located on the side of the shifter) "first" and then put it into H4 (from H2)?
    2. Does the truck have to been in NEUTRAL or PARK?
    3. Does it have to be completely stopped?
    4. I have 2 Tacoma trucks and dont use the 4WD very often and sometimes I've heard GRINDING noises, so I am very cautious......I dont want to damage the trans or transfer cases....
    5. I've looked into my OWNERS manual but its not really clear....
    THANKS for your advice.......:)
  2. Oct 29, 2011 at 10:20 AM
    CHPTR11
    CHPTR11 Team Impulse Red
    Dan
    Pacific NW
    2004 TRD Tacoma
    OME, Hankook, ARB, SCS
    If the 4WD button is on the side of the t-case shifter just push the button in and you're in 4WD.
    Mine has the button and I don't have a 4H though. Just L4 - N - H.
    It looks like this:
  3. Oct 29, 2011 at 10:33 AM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    Going into 4H can be done at any time, well I wouldn't do it going 100mph, but the point is you don't have to be in neutral or stopped. Going into 4L you should be stopped and in neutral. I know some of the Toyotas say you can do it if under 7mph but I prefer to be stopped and in neutral.
  4. Oct 29, 2011 at 2:33 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    go into 4H at any speed under 50 miles an hour, you need to stop and put it in nuetral to go into 4lo
  5. Feb 19, 2014 at 7:36 PM
    jckinnick
    jckinnick Well-Known Member
    Tn
    2002 Toyota Tacoma TRD SR5
    None
    Mine you have to completely stop just to put it in 4WD high.
  6. Feb 20, 2014 at 5:56 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    So correct me pushing the button or using the shifter to H is the same? It's 4L that you need to shift but while stopped and in neutral? Mainly is the push button vs H on the shifter? Same? If so why have H and push button?
  7. Feb 20, 2014 at 7:32 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    The H on the shifter just means that it is using the high range gears in the t-case. The button engages the front diff. I don't know if you have to have the button pushed to engage it into 4 low or not, I've never driven the push button 4wd model. On a t-case without the button (J-shift t-case), you have H2-H4-N-L4.
  8. Feb 20, 2014 at 7:52 AM
    jaymoussy
    jaymoussy Well-Known Member
    Eastern MA, US
    '12 AC Base 2.7l 4a
    The original manual, or more exactly sections, can be found on the Toyota site.
    You might as well have the "critical" sections like "Operating Transmission.." handy.
  9. Feb 20, 2014 at 8:20 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Look on the visor. There's instructions there
  10. Feb 20, 2014 at 8:25 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    foot off the gas, slam it in, foot back on gas :cool:
