Putting subs in DC Taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fowlplay1665, Mar 28, 2011.
  1. Mar 28, 2011 at 1:23 PM
    fowlplay1665
    fowlplay1665 [OP] Active Member
    Newnan, GA
    2011 Prerunner
    285/75/16 BFG A/T's, 2.5" spacers and 1.5" rear blocks, Aries Grill Guard
    Just got a new tacoma DC and was wondering if there was a way to put a sub in an inconspicuous place, without removing the storage bin from behine the back seat. Anybody know?
  2. Mar 28, 2011 at 1:26 PM
    raswank
    raswank Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    Check Tacotunes.com. Iused them for there speaker adapters and they sucked.
  3. Mar 28, 2011 at 1:32 PM
    Kingfrog
    Kingfrog Well-Known Member
    08 TRD Rugged Trail Edition
    Undercover,Pop n Lock, Hardwired GPS, Garage door opener , Scanguage II, wireless back up camera, X994 Basslink, ...Prefer stock and non invasive functional mods
    I just bought a Basslink. Easy in and out with a HD connector and it does a great job in the cab unless you want to become a neighborhood radio station. The you will need to push a whole lot more air and that requires removing panels and custom boxes and generally a lot more expense for the benefit of those who may or may not want to hear what you are listeining to. I dropped mine behind the driver seat. But it can be placed anywhere.
    http://www.google.com/products/cata...=X&ei=ivCQTcbiGs2atwfu_qmICQ&ved=0CD0Q8wIwAA#
  4. Mar 28, 2011 at 1:33 PM
    jammdogg
    jammdogg Well-Known Member
    James
    Hillsboro, OR
    13 Spruce Mica DCLB
    6" ProComp lift on 35 MT's. ARB Bumper.
    Check the preferred vendors for Mr Marv. His stuff is outstanding.
  5. Mar 28, 2011 at 1:35 PM
    Pope953
    Pope953 That's a fact Jack!
    Wesley
    Asheville, NC
    SR5 Pickup
    35% up front, 20% in the back window tint, 15" Mickey Thompson bullet hole wheels, with 31x10.5 Firestone Destination A/T tires. Glass Pack, High Flow Cat, S&B CAI, Custom Light Bar with 4 fog lights. 2 10" Rockford Fosgate P2 subs with 1000 watt Rockford Fosgate Amp, CB.
    x1000
  6. Mar 28, 2011 at 1:35 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    What kind of fabrication skills do you have? I've done it but it's not something I'd recommend unless you're skilled and patient.
    Phase 1
    Phase 2
    Phase 3 *current*
  7. Mar 28, 2011 at 1:36 PM
    fowlplay1665
    Newnan, GA
    2011 Prerunner
    Thanks guys. I'll check it out
  8. Mar 28, 2011 at 1:36 PM
    Pope953
    Wesley
    Asheville, NC
    SR5 Pickup
    What size are those in that last picture?
  9. Mar 28, 2011 at 1:37 PM
    fowlplay1665
    Newnan, GA
    2011 Prerunner
    Fab skills are 0. so that is prob not an option. Ha thanks for the input though
  10. Mar 28, 2011 at 2:22 PM
    Blu69stang
    Blu69stang Member
    Brian
    Sacramento CA
    05 Tacoma
    Wheels, Tires, Exhaust, Grill, Suspension
    You should also check out stealth box. They are pretty hidden!
  11. Mar 28, 2011 at 2:35 PM
    ItalynStylion
    Steven
    DFW, Tx.
    8's....best so far IMO
  12. Mar 28, 2011 at 3:05 PM
    lbridges
    lbridges Well-Known Member
    Lee
    Indialantic, FL
    '11 PreRunner SR5
    Did you reinforce the box somehow, i.e., is there fiberglass under the baffle plate or ???
    Was considering trying to put 8s in the rear doors, but your solution looks better. For my style of listening I don't need a lot of bass, just a bit of low end fill. So I'm trying to determine just how much effort I need to expend (I'm lazy in case you couldn't tell).
  13. Mar 28, 2011 at 9:13 PM
    ItalynStylion
    Steven
    DFW, Tx.
    The lower is fiberglassed. I did it more for sealing it than structure. I mean it's plate steel so it doesn't flex much. Problem is that it's all slotted with holes and vents so you need to seal it up somehow.
  14. Mar 29, 2011 at 2:31 PM
    lbridges
    Lee
    Indialantic, FL
    '11 PreRunner SR5
    Thanks much!
  15. Mar 29, 2011 at 2:38 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    nice work.i assume its all glass???
  16. Oct 15, 2014 at 1:08 AM
    nxrunner
    nxrunner Well-Known Member
    Nick
    Lafayette La.
    2015 Tacoma Double Cab 6 Speed
    Old thread revival. Like the stealth look of the subs in the storage below the rear seats.
