puzzled... squeak
Discussion in 'General Automotive' started by VixTacom, May 3, 2010.
  1. May 3, 2010 at 9:36 PM
    VixTacom
    VixTacom [OP] SYC TACO
    Victor
    Wayne, NJ
    PreRunner SR5 TRD
    LED's and Neon Glow inside, Blacked out front end, 4X4 with Locking Diff, 5spd Manual, TRD package, CB Radio, Gray Wire Mod, Thrush exhaust system, Tinted marker lights, tailights, interior lights
    ok, so i started up the truck this morning.. there was no squeak, i drove to school and there was a squeaking coming from the belts. I figured whatever. I drove to the firehouse and the squeaking was there. I hung out at the firehouse for a bout 2hrs enough time to let the engine cool down. I started the truck back up and the squeak was gone. Drove to work, and the squeak came back once the truck reached normal operating temp....
    Could it be that i need new belts? or that the tention on the belts is to loose?
  2. May 4, 2010 at 10:16 AM
    VixTacom
    Victor
    Wayne, NJ
    PreRunner SR5 TRD
  3. May 4, 2010 at 10:38 AM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    Is the squeak there when you are idling? or just when you are moving? I have a squeak that sounds like a belt, but it's there only when I'm moving and it goes away when I push in the clutch. I think it's the throw out bearing. If your belt is squeaking at idle, pour some water on it and see if it temporarily goes away. If it does, a new belt will usually cure the noise. Make sure you don't get water in the alternator, just use enough to wet the belt.
  4. May 4, 2010 at 8:32 PM
    VixTacom
    Victor
    Wayne, NJ
    PreRunner SR5 TRD
    the squeak is at idle... if i push the clutch its still there.. its kind of annoying if i wet the belts the squeak is still there tried it today
  5. May 4, 2010 at 9:09 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    It's your catalytic converter.
    I had the same thing happen. It would tick/squeak at idle.
    Took it into the dealership and it was covered under a TSB.
