PVC Speaker Adapters
Discussion in 'Audio & Video' started by tunedx, Apr 16, 2010.
  1. Apr 16, 2010 at 3:12 AM
    tunedx
    tunedx [OP] Well-Known Member
    X-Runner
    Is anyone running the pvc speaker adapters? Whats your feedback and is there any buzzing sound using them?
  2. Apr 16, 2010 at 10:17 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    As long as you install them right why would there be any buzzing? Make sure you tighten the baffle to the door and the speaker to the baffle and there will be no noise.
    I also highly encourage some weather stripping or another sealer be used between the baffle and the door as well as between the baffle and the speaker for a proper seal.
  3. Oct 28, 2010 at 10:48 PM
    meantaco
    meantaco Well-Known Member
    Andres
    2005 Prerunner. Gone,but not forgotten.
    Retrofit,bull bar,hellas and color matched grill.
    do you reccomend pvc speaker adapter or mdf adapters? are they rattle free or are mdf better?
  4. Oct 29, 2010 at 5:52 AM
    ItalynStylion
    Steven
    DFW, Tx.
    Like I said, rattling will occur when you have two hard objects vibrating against each other. You can stop this by ensuring that the two pieces fit flush/dont move and or putting something soft between them. I'd recommend doing both. Make sure your baffles are well tightened and use some sort of gasket like weather stripping between them and the door. A neat little trick is to use GE Silicone II for sealing. You lay down a line of it on the baffle, let it dry completely, then install...BAM...perfect seal.
  5. Oct 29, 2010 at 9:32 AM
    dolbytone
    dolbytone Well-Known Member
    09 TRD Off Road
    That's a decent idea.
  6. Oct 29, 2010 at 9:47 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    if you use ge silicone 2 like stylin said just wait for it to dry. If you use ge silicone 1, let it dry 24 hours because there is a chemical in there that can ruin your speakers. I forget what the chemical is called but it's only a factor within 24 hours before the silicone has cured. I used to work for ge silicones.
  7. Oct 29, 2010 at 10:34 AM
    ItalynStylion
    Steven
    DFW, Tx.
    ^Yeah, silicone 1 emits something that will eat through the speaker surround...or so I heard
  8. Oct 29, 2010 at 10:38 AM
    SilverTacoZack
    SilverTacoZack Well-Known Member
    Zack
    Elgin, SC
    2011 FJ trail teams
    I used the PVC mounts from crutchfield and have no rattles, but I did put pieces of dynamat between them and the door.
  9. Oct 29, 2010 at 10:52 AM
    sioux_hockey_guy
    sioux_hockey_guy Well-Known Member
    Bismarck, ND
    Black '08 TRD OR 2" Leveled
    Eibach front springs, Billstein 5100's set at .85" Rear blocks (1.5"?) w, TSB. To be replaced w/ AAL
    Awesome idea. I'll be doing that next week.
