PVC valve
Discussion in '1st Gen. Tacomas (1995-2004)' started by 808DAKINE, Apr 28, 2013.
  1. Apr 28, 2013 at 2:19 PM
    808DAKINE
    808DAKINE [OP] Well-Known Member
    Kai
    Lahaina, Hawai'i
    01 Taco
    Cold air, Sounds, lift, lights, exhaust and a canoe!
    Is this the PVC valve? Normal to see grease/liquid from this area? I have been having one P0420 problems with the Catalyic converter recently. Truck is going to the shop next week to have the front and rear converters checked out and replaced.
    Should I have the braddas look at this as well? Trucks got 95k miles on it so i was considering getting new plugs, wires, fuel filter.
  2. Apr 28, 2013 at 2:43 PM
    peow130
    peow130 Active Member
    Bryan
    Spokane, WA
    1998 Taco TRD w/ 2.5" Skyjacker lift and 33's
    2.5" Skyjacker Platinum
    Before you take it in, you'd be better off just checking your O2 sensors front and rear. Probably save you a ton of money.
  3. Apr 28, 2013 at 2:59 PM
    TacoSkeet
    TacoSkeet 'MERICA
    Steven
    Memphis, TN
    03 DC Tacoma
    yes that is the PCV valve. I recently replaced mine because it looked like yours. Its only like $5 at autozone
  4. Apr 28, 2013 at 3:19 PM
    808DAKINE
    Kai
    Lahaina, Hawai'i
    01 Taco
    Is it possiable that pcv valves can lead to catalytic converter problems?
  5. Apr 28, 2013 at 3:25 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    after removing it...
    shake it... if the ball is moving inside
    it's probably fine.
    It can be cleaned using sensor safe spray cleaners.
    might fail to work well when it gets dirty
    as the ball could stick and or not seal well.
    But usually new ones are only needed when you break one
    trying to pull that out
    for a test :p
    mine was tight to pull from the grommet !
    thought I was gonna break it pulling it out.
    but it didn't
    it's likely your grommet/O-ring seat is at fault
    for the residual seepage.
    Tho' a gummed up valve could assist.
    a new aft mkt pvc valve could fit tighter or looser
    as oem spec tolerances seem to vary some, that I've noticed.
  6. Apr 28, 2013 at 4:25 PM
    808DAKINE
    Kai
    Lahaina, Hawai'i
    01 Taco
    Thanks for the info my bradda, ill be heading to napa tomorrow.
  7. Apr 28, 2013 at 6:01 PM
    peow130
    Bryan
    Spokane, WA
    Unlikely. Unless it were a massive leak causing a massive misfire and a ton of fuel/air into the catalytic.
    Like i said, p0420's are usually caused by old, stock, original O2's. I had a p0420, tested out both my O2's, and found them to be bad. Replaced both, and never had another issue. Until recently.
  8. Apr 29, 2013 at 6:42 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    How do u test those sensors? I didn't know I could test them before I go out and buy new ones. I'm getting the same P0420 code as of recently
  9. Apr 29, 2013 at 7:32 PM
    peow130
    Bryan
    Spokane, WA
    Ohm them out.
    That picture applies to the 3RZ/2RZFE and 5VZFE.
    Usually if it's P0420, the rear O2 sensors are to blame.
  10. Apr 29, 2013 at 11:02 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    If you replace the PCV valve, replace the grommet in the valve cover too...it will be all dried up and hard. You can get one at autozone.
  11. Jul 25, 2014 at 3:41 PM
    netsomnia
    netsomnia Well-Known Member
    Central/Eastern Missouri
    1998 2WD Tacoma 5 lug
    Is this the resistance tolerance for both the upstream A/F and downstream O2?
  12. Aug 22, 2014 at 6:56 AM
    Saggio
    Saggio Active Member
    Sub'd!
  13. Aug 22, 2014 at 7:18 AM
    slander
    slander Well-Known Member
    I had the same code, replaced that valve and it did nothing. Mine was the rear o2 sensor, replaced that and the code went away.
