Q&A Link Tech
Discussion in 'Solid Axle Suspension' started by 4Wheel Underground, Jun 28, 2018.
  1. Jul 3, 2018 at 9:10 AM
    4Wheel Underground
    4Wheel Underground [OP] Well-Known Member
    Coilovers dont unload.
    Poorly designed link geometry does. Where we put our links affects the vehicle. Coilovers are just long springs wrapped around a long shock, they are nothing more and certainly not magical. They respond to forces put up on them and mitigate those forces as smoothly and evenly as possible based on spring and valving selections we chose. So if your front end is raising excessively while climbing an obstacle or the rear end is walking under your truck, then you need to look at the link placements and their angles in relation to the ground. Everything starts at the axle and ends at the chassis, and link placement and its relation to LEVEL ground will always control what our vehicles do. If you work with gravity instead of trying to fight it you and your truck will be much happier.
    stumbles likes this.
  2. Jul 6, 2018 at 4:43 PM
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    Are you still offering the rear radflo shocks tuned for 63's? I didn't see them at first glance on the new website (which looks sweet), and I've been contemplating ordering a set for a while now to compliment the front coilovers I got from you.
    Timbo's Customs likes this.
  3. Jul 6, 2018 at 5:51 PM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Why no second gen love haha.
  4. Jul 6, 2018 at 5:54 PM
    stumbles
    stumbles 1 eye
    bryan
    mesa
    2002 White Double Cab
    I think I saw a mention of it for the future on Instagram?
  5. Jul 6, 2018 at 6:33 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    Doing my swap next year and buying parts already. Axle is rebuilt, kings ordered, truss, moto bilt Lower link brackets upper axle bracket. Only thing left for links is Frame mounts and panhard bar mounts. Heims and tube
    stumbles[QUOTED] likes this.
  6. Jul 6, 2018 at 7:59 PM
    4Wheel Underground
    Got not room for a vehicle in the shop at the moment. I seriously need more sq. footage.
  7. Jul 6, 2018 at 8:00 PM
    4Wheel Underground
    I can build them for you yes, but as far as putting them on the site........I'll think about it. Leaf spring guys have a tendency to think that shocks dont matter for them.
    allenfab[QUOTED] likes this.
  8. Jul 6, 2018 at 8:09 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    Try working out of a 2 car garage
  9. Aug 7, 2018 at 7:52 PM
    Lostsheep
    Lostsheep Well-Known Member
    NorCal
    2015 6spd 4x4 OR
    6112s and 5160 , Dakars , Superbumps x4 , u-bolt flip , All Pro Skids (hacked and raised) , 265/70R17 KO2s, SEMA wheels, couple of machined things here and there
    Can you elaborate on this a bit for me? I'm still attempting to educate myself on link geometry so don't mean any offense in anyway shape or form. That being said, from what I think I know, it would seem to me that the relationship of the instant center (from a side view perspective) WRT the location of the center of gravity, would have more of an effect on handling behavior than link angle WRT the ground. Perhaps a greater angle affects how much the IC moves when the suspension cycles?
  10. Aug 10, 2018 at 1:05 PM
    4Wheel Underground
    The only roll the Instant Center is to us is as a tool to measure certain characteristics. It, it's self means nothing.
  11. Aug 10, 2018 at 1:10 PM
    4Wheel Underground
    It literally is the angle of the link arm to the ground that is important. The instant center is only an imaginary point in space, and should be treated as such. All we are trying to do is control the torque load of the axle back into the chassis. If those forces are being applied in a 10* upward angle while having only 5"s of upward axle movement and 9"s down and the link starts at 10*s what is it then once the suspension reaches full droop. 25*? 30*? 35*? Since the greater the angle of the link the greater the unloading of the suspension you can imagine doing everything in your power to get a flatter link at ride height would equal the greatest performance in "ALL" situations.
  12. Aug 11, 2018 at 8:37 AM
    Lostsheep
    NorCal
    2015 6spd 4x4 OR
    If you want to control torque loads on the chassis then the location of the IC absolutely matters. More specifically, the distance from the CG to the IC (height difference measured in a side view) is literally the “R” in the definition of torque. T = F x R
    (Read “ F cross R”)
  13. Aug 11, 2018 at 10:46 AM
    4Wheel Underground
    Controlling torque back to the chassis is about "force vectors". which just means the direction the force is applied. Our IC is imaginary force location not actual. The location of that force is the actual location the link is placed on the chassis. And it applies force in that direction at the location. But since you can get the same IC with several different link designs and since the IC is only a moment, its not doing anyone any favors by making the IC the focal point. And while having your IC in the same location as your CG sounds great and is, most of us are foolish enough to try and move our IC to our CG when we should be doing the opposite.
  14. Aug 11, 2018 at 3:19 PM
    Lostsheep
    NorCal
    2015 6spd 4x4 OR
    Understood on the vectors, that's basically what I am talking about. As the links are basically pin connected, they can't transmit torque through the joints, for modeling I would treat them as only being able to transmit force axially. As the IC is where the suspension pivots about in a 4 bar linkage (when viewed from the side) , the relationship between acceleration (whether it be throttle or braking) induced forces, the IC, and the CG, determine how the suspension will behave; if the acceleration vectors point directly at the IC then no moment would be created and acceleration forces shouldn't induce a moment and vise versa.
    FWIW, I have no idea how much of a moment is desirable WRT antidive and antisquat. I am still trying to figure all that crap out and it makes my brain hurt.
    I should also admit I have zero intention of linking my Taco for a very long time, it's my DD and the IFS / leaf combo works perfectly for that application. Right now I'm going through all of this debating on messing with the geometry on my heep which is currently on a Clayton 4link rear , 3 link front. I'm sure those guys did their homework but the low hanging links bug me; moving them might allow me to gain 3" of ground clearance and improve behavior.
  15. Aug 12, 2018 at 10:23 AM
    #35
    4Wheel Underground
    *Homework*...... I wouldnt bet on it.
  16. Sep 8, 2018 at 5:25 PM
    #36
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    :anonymous:
    Good explanations and very deep.
