Q: When attaching grill inserts...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bobcat, Sep 16, 2009.
  1. Sep 16, 2009 at 10:24 AM
    Bobcat
    Bobcat [OP] Well-Known Member
    Montana
    Some inserts require cutting and drilling. I am working on making my own and wondering how some of these are attached. What is cut and drilled and how are they attached. For example, on a billet?
    I would like several examples if possible if there are a couple ways.
    I do know about the Satoshi and Jamoshi so nothing needed on that front.
  2. Sep 16, 2009 at 10:46 AM
    Death_Stalker
    Death_Stalker " The Master Ninja"
    Talha
    Cypress, TX
    2010 4Runner Trail Premium
    search for satoshi jamoshi also go in mods there are writ ups on that
  3. Sep 16, 2009 at 10:53 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    On the billet grille the whole inside gets removed, you cut off all the plastic. Basically you have a big hole. My grille attached with 4 screws with brackets, very very easy install.
    The hardest part was doing the cutting and sanding those areas down. Make sure to mask (tape) off the chrome, or painted areas (depending on grill shell).
  4. Sep 16, 2009 at 2:21 PM
    Bobcat
    Montana
    Interesting, I am kind of surprised that the billets require cutting out of the inside, I would have thought they just go over, but then again there isn't much room.
    Any other people have different ways an aftermarket grill insert is attached?
