Q: Why get a lift kit when you can get 5100's?
Discussion in 'Suspension' started by 95tacos, Dec 4, 2012.
  1. Dec 4, 2012 at 11:55 PM
    95tacos
    95tacos [OP] Active Member
    Huntsville, AL
    95 Tacoma
    I might be an idiot (I AM new to this) but why would one get a lift kit when you can accomplish 2-3" of lift with 5100's? Thanks
  2. Dec 4, 2012 at 11:58 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    well you still have to get something for the rear. And if your front coils are going bad (like they could be on your 95) you would want to upgrade the coils to something more heavy duty that provides a lift. Also if you were just looking for better performance or if you needed the coils to hold more weight like a bumper or a winch....just 5100s are at the low end of lifting the truck. There are many options after that that give better and better performance and accomplish what you want out of the truck better.
  3. Dec 5, 2012 at 12:12 AM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    To get more travel than 5100's? Some companies offer extended travel coilovers that provide more wheel travel than 5100's would.
  4. Dec 5, 2012 at 12:14 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    5100's is a lift kit...
  5. Dec 5, 2012 at 12:15 AM
    numbah57
    kahai
    Maui, Hawaii
    ^^^^^^ that too
  6. Dec 5, 2012 at 12:16 AM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
  7. Dec 5, 2012 at 12:26 AM
    numbah57
    kahai
    Maui, Hawaii
    You have to take into consideration the "what do I want my truck to do?"
    1. Have a little better stance on the road or easy trails.
    2. More travel and dampening ability for harsher hits that come with a little more serious wheeling.
    Option 2 is what made me decide on my camburg coilovers. Couldn't be happier.
  8. Dec 5, 2012 at 7:42 PM
    95tacos
    Huntsville, AL
    95 Tacoma
    I was looking at OME coils, most definately. I will checkout camburg. Thanks for the great help / info. I was planning on AAL in the rear as well. Haven't picked one out yet (still learning.....)
  9. Dec 5, 2012 at 9:49 PM
    95tacos
    Huntsville, AL
    95 Tacoma
    What do you guys think of going with 5100's and OME 882's on a 95 Xtra cab 4x4? Any AAL suggestions? I'd like to be close to 3", but I'm not sure how involved it would be to extend brake lines and everything else needed to lift higher than 3". (come to think of it, what all would need to extended?) I would really like to go to a 33" tire.
  10. Dec 5, 2012 at 10:00 PM
    scocar
    scocar 42
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks groaning under boxes of parts
    Based on personal experience, I recommend that if yo uget OME coils, get OME shocks. They work best together.
    You will need to install a BPV (brake proportioning valve) extension bracket on the rear axle, likely an extended exhaust hanger so your pipe does not interfere with your leaf springs (or cut the pipe down), and the brake line extension, which is a pretty simple R&R all at the back axle, plus bleeding your brake system up front.
    If you go 3 in the front, you'll likely need to get UCAs so you can align it properly (to get enough caster) and your CV boots will be in danger of rubbing and ripping open unles yo udo the CV boot mod.
    You should be able to find all these mods/writeups here:
    http://www.tacomaworld.com/forum/1s...y-how-thread-compiled-list-helpful-links.html
    Oh, and don't try to go higher than 3.
  11. Dec 11, 2012 at 9:09 PM
    95tacos
    Huntsville, AL
    95 Tacoma
    Thanks for the info scocar! Very helpful. I don't have any real desire on going beyond 3", but I have to ask, why shouldn't I try to go higher?
    Thanks again, that is some seriously helpful info for me.
  12. Dec 12, 2012 at 7:34 AM
    ckblum
    ckblum Well-Known Member
    Cam
    Chilliwack, BC
    Tacoma
    Bilsteins, Light Racing UCA's, Alcan's, Kragen HID's
    CV angle becomes too steep higher than 3". Plus you will want to retain down travel and the closer you get to the droop stops the less your tire can droop when you hit holes and dips.
  13. Dec 12, 2012 at 6:53 PM
    95tacos
    Huntsville, AL
    95 Tacoma
    What can be done to address the cv angle issues? Anything?
  14. Dec 12, 2012 at 6:57 PM
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    Bro hoez...they love the coilovers
