QA1 coil overs and some Beefed parts
Discussion in 'Street Trucks' started by Beefed Taco, Aug 8, 2009.
  1. Aug 8, 2009 at 12:45 AM
    Beefed Taco
    Beefed Taco [OP] Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    Us guys with 95.5-04 mini's discovered that the QA1 racing coil overs for the 67-69 Camaro's are "almost" a direct bolt in for the front. I offer a custom plate for this. I'm doing a QA1 rear forward facing 4 link on my friends s-runner, and thought I'd show a few pictures. I'm building the parts from my truck to speed things up a bit since right now it's a once a week wrenchathon when we meet every Saturday and that doesn't make for a speedy install. These are the rear crossmembers. This entire kit is going to be bolt on. The first & 2nd pic is for the front.
    [​IMG] [​IMG]
  2. Aug 9, 2009 at 2:47 AM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    I bolted this stuff up to Chris' truck today and added the front mounts on the c/m and V brace.
  3. Aug 9, 2009 at 1:03 PM
    VooDooTrip
    VooDooTrip Defector
    Gilbert, AZ
    01' BSP S/C S-Runner
    S/C, URD fuel Upgrade, 2.2 Pulley, URD crank pulley, Truetrax locker, custom exhaust, plx, scangauge, D/P mod, amsoil drop in, 18x9.5 stern hyperblacks, ACA projectors, Grillcraft blackmesh, Performance Products valance, R/C Tails, B&M Short shifter, QA1 Coilovers all the way around, upgraded strut rod bars with heim joints, poly bushings everywhere lol, 1st model Streetacos bolt on four link!
    So sexy.. :laugh:
  4. Aug 12, 2009 at 8:13 PM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    Here are a couple updated pictures. The next time you see this stuff it'll all be painted and ready for install.
    Beefed bolt on coil over cross member & rear V Brace kit *unpainted*
    [​IMG] [​IMG]
  5. Aug 14, 2009 at 3:27 AM
    PhilC
    PhilC Member
    Phil
    Indianapolis, IN
    06 Tacoma TRD Sport
    How much do the QA1's lower the front? and did you custom fab the brace in the back? Nice work!
  6. Aug 14, 2009 at 10:46 AM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    The front lower the truck about 3" when using my arm plate. The ride height is adjustable by turning the sleeves on the shock. The shock is also adjustable by turning a knob. It's the most performance geared mod one can do to the front of these trucks. 10 times better than any coil and quality shock. These are the plasma cut plates needed for mounting the QA1's on the front.
  7. Aug 14, 2009 at 10:50 AM
    PhilC
    PhilC Member
    Phil
    Indianapolis, IN
    06 Tacoma TRD Sport
    That is awesome! how much did you find the QA1's for? and how much are you talking to do the front install? and the back? I really want to go for a 3frt and 4rr drop not sure
  8. Aug 14, 2009 at 12:05 PM
    VooDooTrip
    VooDooTrip Defector
    Gilbert, AZ
    The 10in spring for a V-6 will drop you about 3in. with a 4cyl I highly suggest the 8in spring. That will give you a better rate of adjust ability to about a 5-6in drop. The back is going to be able to be from a 4in to whatever you can imagine as long as you have a notch. :D
  9. Aug 14, 2009 at 10:33 PM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    Hey PhilC, you can also do my 3/4 kit....it's 10 times cheaper than the DJM and 100 times higher quality. It also comes with upgraded u-bolts for $14 more. PM me for details.
