QI Charger Acting Weird
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mrkabc, May 18, 2017.
  1. May 18, 2017 at 7:18 PM
    mrkabc
    mrkabc [OP] Mall Crawler with a Locker
    Art
    Corona, CA
    2017 MGM DCSB TRD OR
    Morimoto XB LED Head & Fog Lights, Cali Raised Stealth Light bar, OEM Roof Rack, Homelink Compass Mirror, Power Tailgate Lock, LED bed lights, MESO mirrors, gashole, switch panel & Stage 2 tails, PRO grille. Where's the mall?
    Yes, I already know you all are going to say RTFM! However, my manual isn't here.
    I am seeing flashing yellow and green lights on the charger and my Galaxy S7 is freaking out. I shut off the QI and restart and it charges the phone normally for a bit then starts flashing and going crazy again. When the two lights flash the phone doesn't charge.
    Anyone else seen this? What do the two lights mean? (Cue the "...a trip to the dealer" replies...)
  2. May 18, 2017 at 7:30 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Taken from the manual:
    An amber indicator is illuminated while charging is in progress. When charging is complete, a green indicator will also be illuminated. Some phones, cases or cover type wireless chargers may not cause the green indicator to illuminate even though it is fully charged.
    ■If the wireless charger LED indicators flash
    If the wireless charging surface of the tray becomes too hot, the LED indicators will flash and charging is canceled. The LED indicators will be illuminated if the surface of the tray cools down.
    If the LED indicators flash even though the surface of the tray is not hot, the wireless charger may be malfunctioning. Consult your Toyota dealer.
    BTW, you can download a PDF of the manual, it makes it a lot easier to navigate and you can read it while you are taking care of other business. :)
  3. May 18, 2017 at 7:38 PM
    mrkabc
    Art
    Corona, CA
    @daddy_o awesome thanks! Phone was warm but not hot. It Is 91 degrees here in El Centro though. A.C. was on in truck set to 74 degrees. Wonder if I have a problem.
  4. May 18, 2017 at 7:41 PM
    imdav2u
    imdav2u Well-Known Member
    St. Louis
    2016 TRD Offroad DCSB 4X4
    Mine does it if my phone battery gets hot or in the winter if I forget to turn the charger off and it sots outside in freezing weather.
  5. May 18, 2017 at 7:45 PM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    I have an s7 allso mine charges fine until I get a notification. Once the green notification light starts to flash the phone quits charging. If I clear the notification it'll charge again.
  6. May 18, 2017 at 7:45 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Mine started doing this the other day but it did not feel very hot. Just another thing going wrong on my Turd Gen is my guess.
    HutchJ likes this.
  7. Dec 11, 2017 at 12:10 PM
    sp-tech
    sp-tech Bone Stock
    Stephen
    2017 Char Grey Tacoma TRD
    I just had this happen to my ‘17 Tacoma, but the next time I started the truck up, the issue was gone.. I’ll keep an eye on it now tho.
  8. Jan 30, 2018 at 7:09 PM
    justskiit
    justskiit New Member
    trd sport Inferno 6ft dbl cab w match cap
    I had this happen recently at dealership nonetheless. Truck will be on, phone is placed on pad , charger turned on,
    Phone charges for a second, lights on pad start to blink. Charger turned off, then on again still blinking....shut truck off to reset, this works 50% of time.
